JVC RS20 to NX5 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By blee0120
  • 1 Post By Mike Garrett
  • 1 Post By xrtdr
  • 1 Post By Imatk
  • 1 Post By Imatk
  • 2 Post By coderguy
  • 1 Post By coderguy
post #1 of 23 Old 02-12-2020, 02:17 PM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
JVC RS20 to NX5
I currently have an RS20 and love the projector.
Been running it for like 8 years or so.
I keep reading about the loss of contrast in the NX5 compared to the RS540.
I'm guessing (but I'm not sure which is why I post this) that the contrast on the NX5 is going to be much better than my RS20 so it won't really matter to me contrast-wise since I'm used to the RS20.
Would that be a fair assessment?
Imatk is online now
post #2 of 23 Old 02-12-2020, 02:37 PM
blee0120's Avatar
Quoted: 995 Post(s)
Liked: 722
The RS1000/NX5 is in a totally different category than the RS20. Every single aspect is better on the RS1000/NX5.
Craig Peer likes this.
blee0120 is offline
post #3 of 23 Old 02-12-2020, 04:24 PM
Mike Garrett's Avatar
Quoted: 13152 Post(s)
Liked: 10790
The RS1000/NX5 easily beats the RS20 in all areas. The difference will be night and day.
Azekecse likes this.
Mike Garrett is online now
post #4 of 23 Old 02-13-2020, 06:49 AM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
Thanks guys, that's kind of what I figured
Imatk is online now
post #5 of 23 Old 02-13-2020, 09:32 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7134 Post(s)
Liked: 7175
You will be in for a HUGE upgrade, I do see you comparing the RS540U and NX5:
Keep in mind to the naked eye, many can not see the contrast loss. Just a FYI, 540U/X790R is actually still a current unit.
RS1000/NX5 advantages over the RS540/X790
***Improved lens.
***Beefed up lens support, so that lens memory is more accurate. This is why you see so much difference in weight between the two models.
***Native 4K.
***Cleaner,crisper image with more depth perception due to true 4K.
***Dynamic tone mapping. ( This is probably the most noticeable difference )
***Installation memory that allows you to store more settings.
Cleveland Plasma is online now
post #6 of 23 Old 02-13-2020, 10:56 AM
rads03's Avatar
Liked: 1
thx for the pm. looking into it. was getting close to replacing my 4-5 year old rs57u with nx5 but now im unsure if nx5 or nx7 would be better.
rads03 is online now
post #7 of 23 Old 02-13-2020, 11:17 AM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
No problem man
I would have gone with an NX7, but out of my budget. I was initially looking to do an RS520 or 540 but then kept reading and since I tend to keep my projectors a LONG time I decided on the NX5.
Imatk is online now
post #8 of 23 Old 02-13-2020, 11:23 AM
rads03's Avatar
Liked: 1
No problem man
have you setup the nx5 and used it yet or waiting for delivery?
post #9 of 23 Old 02-13-2020, 12:09 PM
Azekecse's Avatar
Quoted: 158 Post(s)
Liked: 107
Upgraded from my Epson 6040UB, which I thoroughly enjoyed and now I have had the NX-5 for about two weeks,, once I upgraded the f/w to 3.10 for DTM, it is an amazing projector in a light controlled room, without a lot of menu adjustments. Then, I ran across a heck of a deal for the NX-7, which has WCG and an extra lamp, etc., so I took it, because I couldn't afford it previously either. It is arriving soon, at which time I'll be returning the NX-5, hopefully someone will give it a great home, as well as my 6040UB.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX5/Elite Lunette 2 120"
Azekecse is online now
post #10 of 23 Old 02-13-2020, 12:46 PM
xrtdr's Avatar
Quoted: 26 Post(s)
I was in the same boat (but coming from an even older RS4800.)
When I factored in the need to upgrade AVR to allow 4K pass-through and a 4K Bluray the RS540 just seemed to make the most sense.
It was a tough decision though.
I figured I'd spend ~3-4K on the projector and wait for an even better native 4K in a few years.
rossandwendy likes this.
xrtdr is online now
post #11 of 23 Old 02-13-2020, 02:04 PM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
So... it depends on the AVR.
What I'm going to do is just run mine in ARC and let the projector do the switching.
If I would have had to get a receiver as well then I wouldn't have been buying anything just yet.
So you could connect your Bluray and Roko or whatever directly to the projector and you'd be good
Is arriving tomorrow by "end of day" according to FedEx.
xrtdr likes this.
Imatk is online now
post #12 of 23 Old 02-13-2020, 03:16 PM
xrtdr's Avatar
Quoted: 26 Post(s)
Congratulations. Mine is supposed to arrive by end of day tomorrow also!
Would you mind walking me through that? I am not sure what ARC means. The only option I could think of besides getting a new AVR is to run the Bluray HDMI to the projector and the Bluray HDMI audio to the receiver. But then I'm not sure how I'd get 4K streaming from AppleTV or Roku.
I've got CAT wiring in the walls and baluns on each end. The company that put in my theater in 2012 no longer exists. I can call someone else but thought maybe I could get some quick advice here.
xrtdr is online now
post #13 of 23 Old 02-13-2020, 05:43 PM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
Well I'm glad you asked me that.
I was all confident because I hooked up my 4k tv with a soundbar with the "ARC" output or Audio Return Channel.
But looks like my receiver only does optical and the projector (from what I can see) does not have an ARC output... nor does my Roku.
Sigh... so looks like I might be looking for a receiver after all... my wife is gonna kill me :/
Imatk is online now
post #14 of 23 Old 02-13-2020, 06:01 PM
xrtdr's Avatar
Quoted: 26 Post(s)
Sorry, but that me laugh.
My plan was to get a UBD (such as Panasonic U8xx) that has 2 HDMI outputs. Run the HDMI2.x to the projector (hoping that the CAT cabling in the walls supports 4k...one guy that came out to the house said it would) and run the 2nd HDMI1.4 ouput to the receiver for audio.
I don't know how to get 4K AppleTV or Roku yet with this setup.
I can't stomach the thought of dropping another $1200 or so to replace a receiver that works perfectly other than no 4K switching.
xrtdr is online now
post #15 of 23 Old 02-13-2020, 06:07 PM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
I'm with you man. I love my Pioneer SC-37, but sigh.
Gonna take a look at that Panasonic though.
Imatk is online now
post #16 of 23 Old 02-13-2020, 06:36 PM
Liked: 10790
I would plan on buying the AVR. A good HDBaseT system costs about as much as the AVR. A cheap one often times costs more, when you factor in the time for returning it and buying a good one. You don't have to spend $1,200 to get an AVR to take care of what you need.
xrtdr likes this.
post #17 of 23 Old 02-14-2020, 07:04 AM - Thread Starter
Imatk's Avatar
Quoted: 13 Post(s)
Yeah I'm looking at the Denon X3500H seems to have a lot of good reviews.
It's an older model, but heck my Pioneer is WAY older
xrtdr likes this.
Imatk is online now
post #18 of 23 Old 02-14-2020, 02:27 PM
coderguy's Avatar
Quoted: 2963 Post(s)
Liked: 1560
I have a few different receivers including the Denon x3400h, it's good, but I had to disable the volume OSD or it was causing a chroma error. It also won't accept my longer HDMI run (which is mainly fiber HDMI), even though the long HDMI 4k works directly on the JVC, though that might be some settings I need to fiddle with again for the Denon (didn't try very hard). You might not have any of those issues on the NX projectors. The x3500h is barely an older model, it's fine. I also have an Onkyo 676 (newer one is 686/696) which doesn't have that issue, the Onkyo worked more flawlessly with the OSD stuff and has a better UI. However, the Onkyo has a less neutral sound and adds a slight harshness to vocals which I didn't like. They are both similar power, if you don't mind the slightly colored sound of the Onkyo, which I wasn't able to EQ or otherwise tune out (tried everything).
xrtdr and Imatk like this.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #19 of 23 Old 02-14-2020, 06:57 PM
xrtdr's Avatar
Quoted: 26 Post(s)
I know this is a projector thread, but speaking of AVRs to pass 4K video, what do you folks think of the Denon S95OH? 7.2, 8 HDMI in, 2 HDMI out, 125 W per channel, MSRP $599?
xrtdr is online now
post #20 of 23 Old 02-14-2020, 07:13 PM
coderguy's Avatar
Liked: 1560
I wouldn't personally bother with anything less than the 3400/3500/3600, but cannot answer the question as there are too many variables without going into it all. Best to ask the audio guys in other threads, few of us keep up with new receiver models once we are done with the initial purchase. Again, the Denons handle 4k just fine, but I think they purposefully nerf'd some of the OSD options on the lower-end models, not sure about the latest newer versions of each iteration. You can get a refurb 3400h really cheap, look on Ebay.
xrtdr likes this.
coderguy is offline
post #21 of 23 Old Yesterday, 08:11 AM
archipaolo's Avatar
Liked: 0
I recently purchased NX5 and still own jvc rs25
In favor of NX5:
- much greater brightness
- much higher sharpness
- overall superior image even with 1080p bluray.
Much better with regards to watching sports on hdtv.
As for black and contrast, I think they are similar, but I am unable to measure them
JVC DLA NX5 - JVC DLA RS25
archipaolo is offline
post #22 of 23 Old Today, 07:48 AM
xrtdr's Avatar
Quoted: 26 Post(s)
Mike, I need an Hd extender set anyway for the long run of cat6 to the projector (25-30ft est).
But I guess I do need to get the new AVR as well.
xrtdr is online now
post #23 of 23 Old Today, 07:54 AM
xrtdr's Avatar
Quoted: 26 Post(s)
So did you get your Nx5? How is it?
And have you configured for any 4K sources and sound?
My RS540 is in, looks great but only in 1080p so far. Panasonic UB420 enroute from Crutchfield on sale. Still looking at AVR options.
xrtdr is online now
