Conversion lens calculator? Advice? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By jjcook
  • 1 Post By kemannthey
post #1 of 12 Old 03-16-2020, 09:22 AM - Thread Starter
Dennis Moore's Avatar
Quoted: 86 Post(s)
Yo. I have a JVC RS 4910. If I put one of the Navitar Mini Screenstar .65X lenses in front of it (which I think will work?), what is the best way to do the math for that?
It gives a 50% increase... have I read that correctly?
So if I'm looking to project a 110" x 62" image from the closest possible distance... and the Projector Calculator tells me that is 12' 10"...
And here is where I get confused. Do I just multiply 12' 10" by .65? Or by 50%? Or?
Or is there a limitation based on the size of the Mini lens that prevents me from placing the projector as close as possible?
Dennis Moore is offline
post #2 of 12 Old 03-16-2020, 07:30 PM
bdht's Avatar
Quoted: 487 Post(s)
Liked: 206
You would multiply by the throw ratio. The minimum throw ratio of the projector is 1.4, so you would multiply 1.4 x 0.65 for 0.91. Though Ive read with these lenses you can induce vignetting at or below a 1.0 throw ratio. So instead say you went with a 1.1 throw ratio and a 110" wide image you would place the projector with the lens 121" from the screen.
Note the lens will also reduce lens shift by that 0.65 as well.
bdht is offline
post #3 of 12 Old 03-16-2020, 08:22 PM - Thread Starter
Quoted: 86 Post(s)
Duh. That makes too much sense.
Next stupid question... has anybody ever put one of these things in front of an A lens?
post #4 of 12 Old 03-16-2020, 08:45 PM - Thread Starter
Quoted: 86 Post(s)
Or would you want to put the A lens in front of it?
post #5 of 12 Old 03-16-2020, 09:03 PM
jjcook's Avatar
Quoted: 492 Post(s)
Liked: 202
For the HDSSW065+JVC (with using 0% lens shift with the Navitar about as close to the primary lens as possible) my measurement was that I was able to achieve a throw ratio of 1.02 without vignette and for 2.35 material a throw ratio down to 0.96 without vignette of the 2.35 portion of the image. If you use lens shift you need to align the lens to the image axis which causes the Navitar lens to be further from the primary lens which will further reduce your achievable effective throw ratio (sorry, I did not measure for this case).
The Navitar Mini lens will be woefully insufficient for your JVC.
You would not be able to then place an anamorphic lens in front of the conversion lens, even the huge ISCO 1.25x is too small for this; nor would it work the other way around.
bdht likes this.
jjcook is offline
post #6 of 12 Old 03-16-2020, 11:25 PM
bdht's Avatar
Quoted: 487 Post(s)
Liked: 206
Originally Posted by jjcook View Post
For the HDSSW065+
Are you aware of anyone using these lenses, the hdssw065/08, with 0.95 dmd projectors? Even better with the LED versions?
bdht is offline
post #7 of 12 Old 03-17-2020, 06:37 AM - Thread Starter
Quoted: 86 Post(s)
Yeah? Hmmm. Because of the size, you mean?
post #8 of 12 Old 03-17-2020, 01:34 PM
jjcook's Avatar
Quoted: 492 Post(s)
Liked: 202
No, sorry, I'm not -- generally both the HD065/08 would be a good fit (again maybe not to the maximum expansion ratio like the JVC).
Yes because of the size of the entry/exit lens.
I didn't look at your requirements but the SSW08 has a reasonable-sized lens that can work in many scenarios if you're not able to step up to the HD-sized lenses.
jjcook is offline
post #9 of 12 Old 03-17-2020, 01:54 PM
kemannthey's Avatar
Quoted: 55 Post(s)
Liked: 27
You should measure beam size.
At min throw ratio there is a vary large beam that does not fit anything but the super large lens.
Adjust your zoom to max brightness and put a piece of paper in front of the projector where the lens would go.
Mark the paper and measure how wide the image is the see if the beam would even fit the lens.
bdht likes this.
kemannthey is offline
post #10 of 12 Old 03-17-2020, 02:30 PM
Mike Garrett's Avatar
Quoted: 13489 Post(s)
Liked: 11118
Would not work. The image exiting the A-lens would be way to large for the Conversion lens.
Mike Garrett is offline
post #11 of 12 Old 03-17-2020, 02:32 PM
Liked: 11118
Same problem. Exist image would be too large to fit into the other.
post #12 of 12 Old 03-17-2020, 02:33 PM
Liked: 11118
He can save some time. I can already tell you you can't use a mini with the projector at short throw, wide angle.
