Optoma UHZ65LV - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JeffG02
post #1 of 9 Old 03-24-2020, 12:07 PM - Thread Starter
JeffG02's Avatar
Optoma UHZ65LV
Currently looking for the right projector for my upcoming build. Since I'll have a little natural light, laser seemed intriguing and so I was looking at the UHZ65 or Theo UHZ65-Lite, then came across the newly released UHZ65LV. I assume since it's so new, there is zero about it online. Has anyone seen one?
https://www.optoma.com/us/product/uhz65lv/
UHZ65LV
Incredible native 4K UHD (3840 × 2160) resolution with HDR10 and HLG compatibility
PureEngine (MEMC) & UltraDetail for outstanding video performance
Bright 5,000 lumens for lights-on viewing
Vertical lens shift with 1.6x zoom
DuraCore maintenance-free laser light source up to 30,000 hours
Blu-ray 3D compatible
Extensive I/O with HDMI, 12v trigger, RS-232C and LAN control
Larger-than-life 4K UHD with stunning color and amazing clarity for lights-on viewing
Outfit your home with beautiful, 5,000 lumens and 4K UHD projections with the Optoma UHZ65LV laser projector for home cinemas. Engineered for the ultimate home theater, the incredibly bright DuraCore Laser light source delivers an amazing visual experience at any hour of the day.
Compact size, low weight and quiet operation make it easy to install in any home cinema and enjoyed with minimal noise. The high-performance DLP chipset displays 8.3-million distinct simultaneous pixels on screen and easily projects images up to 302-inches with outstanding details.
Vertical lens shift, 1.6x optical zoom and 12V trigger provide installation flexibility. RS-232C and LAN connectivity enable simple integration and control via industry standards.
BiggerPicture likes this.
JeffG02 is online now
post #2 of 9 Old 03-24-2020, 12:24 PM
kemannthey's Avatar
Quoted: 49 Post(s)
Liked: 24
I also tack lazer/led projectors.
How many lummens are you targeting ? The Theo is likely the best on for contrtast and color 3 but this one is alot brighter.
Have you also looked at the BenQ lk990/970 and ht9060/9050?
Jvc also has in interesting dlp Lazer.
kemannthey is offline
post #3 of 9 Old 03-25-2020, 11:30 AM
mckey's Avatar
UHZ65LV
I have seen that the uniformity is 70% compared to 85% of the UHZ65
mckey is offline
post #4 of 9 Old 03-25-2020, 12:50 PM
Quoted: 1077 Post(s)
Liked: 520
UHZ65LV
I think this is basically the same projector:
https://www.projectorcentral.com/Opt...tor-Review.htm
DunMunro is offline
post #5 of 9 Old 03-26-2020, 06:08 AM
Mike Garrett's Avatar
Quoted: 13402 Post(s)
Liked: 11047
Lists 5,000 lumens and yet video optimized lumens SDR is only 1,525. That is a huge hit, just to get accurate performance.
Mike Garrett is online now
post #6 of 9 Old 03-26-2020, 08:12 AM
DoctorCyclops's Avatar
Quoted: 45 Post(s)
Liked: 48
You should check out the Benq 9060.
LED light engine w/ fantastic light uniformity.
Very satisfied w/ mine.
DoctorCyclops is offline
post #7 of 9 Old 03-26-2020, 09:07 AM
Liked: 520
1525 lumens is still OK but cinema mode does much better, and HDR, which wasn't tested will do better as well.
DunMunro is offline
post #8 of 9 Old 03-26-2020, 09:55 AM
Liked: 11047
That is just a less accurate mode, which allows more light output.
post #9 of 9 Old 03-26-2020, 10:18 AM
Liked: 520
We don't actually know that as the test didn't measure colour accuracy. It implies that HDR Standard mode is pretty good:
"You can improve the 4K image significantly by experimenting with various combinations of HDR mode (HDR and HDR2); HDR Picture Mode (Bright, Standard, Film, and Detail); Gamma; and Dynamic Black (the equivalent of an auto iris). I settled on HDR, Standard Picture Mode, Gamma 2.4, and Dynamic Black 1."
and that mode is probably somewhere over 2000 lumens.
DunMunro is offline
