I'll just go and buy a TV, honestly... - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #181 of 189 Old 04-25-2020, 03:23 PM
Mike Garrett's Avatar
Quoted: 14054 Post(s)
Liked: 11733
Originally Posted by Vitus4K View Post
The problem really is my GREEN, it's 2-3 pixels off horizontally to the LEFT, nothing wrong with the vertical axis.
Since it's fixed, it'll never really match up with the white lines, it's insanely visible on sharpness patterns and text in general.
To minimize the effects and drawbacks of this I need to adjust RED and BLUE to meet the GREEN, but then again nothing really lines up with the white pattern.
Kinda confusing.
You are not understanding what I am saying. You move red and blue to match the green. If you get red and blue to match the green, you have perfect white lines. Green is the target you match to. If all three moved, you would not have a target to hit.
Added
As many complaints as you have, perhaps you should just buy a TV, because all you are doing is looking for problems.
Mike Garrett is offline
post #182 of 189 Old 04-25-2020, 03:25 PM - Thread Starter
Quoted: 227 Post(s)
Liked: 27
Thanks for the clarification.
How much would the green be allowed to differentiate from the white pattern without having to call the unit defect?
Is there such a thing as a defective unit, or bad convergence?
What would be an example of one?
Vitus4K is offline
post #183 of 189 Old 04-25-2020, 03:29 PM
Liked: 11733
Just return the projector and buy a TV.
Added
You do know that you should be viewing convergence from your seat, not at the screen. If it appears white and sharp from your seat, then adjusting anything is not going to improve your image.
ivanhoek likes this.
post #184 of 189 Old 04-25-2020, 04:02 PM
Javs's Avatar
Quoted: 7222 Post(s)
Liked: 6908
Here are some photos of a machine I returned. My issue was that convergence was out in a non-uniform way. There are also screenshots there of the convergence pattern with eshift OFF.
By the way, adjust, and assess your convergence with Eshift OFF only. If its on, it will be very difficult to see what's really going on with the panel.
Also, I wonder if the green line you are seeing is the Low Latency bug I discovered, which is linked to CMD actually. Toggle Low Latency ON and see if the green line goes away.
https://www.avsforum.com/forum/24-di...l#post54903834
https://www.avsforum.com/forum/24-di...l#post55115602
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #185 of 189 Old 04-25-2020, 04:13 PM - Thread Starter
Quoted: 227 Post(s)
Liked: 27
Looks very much like so, Javs.
But my green is not on the right hand side as yours, mine is on the left hand side.
It looks terrible, there's a green outline to everything on screen, sharpness patterns are really horrible to look at.
You mean just enabling Low Latency Mode will fix it?
Enabling it won't affect 24hz performance?
Vitus4K is offline
post #186 of 189 Old 04-25-2020, 04:17 PM - Thread Starter
Quoted: 227 Post(s)
Liked: 27
My firmware says 12.1.
Vitus4K is offline
post #187 of 189 Old 04-25-2020, 04:18 PM
Javs's Avatar
Liked: 6908
Low latency does not affect the image as much as it does on the JVC that I have, the one before it.
CMD affects the image more than Low Latency does, but you have to study images HARD to see any affects and even then you have to be looking at photos of your screen to make out the difference.
I would enable Low Latency (which forces the CMD bug OFF) and see if there is improvement.
I also have the CMD bug on my X9500 which appears to the left on text in the menu and cycling CMD on and off solves it in my case, though its rare to pop up. Not many people know that even that model is affected.
Javs is offline
post #188 of 189 Old 04-25-2020, 04:27 PM - Thread Starter
Quoted: 227 Post(s)
Liked: 27
Right, I'll come back after testing, loads of cheers!
Vitus4K is offline
post #189 of 189 Old 04-26-2020, 03:07 AM
markmon1's Avatar
Quoted: 6841 Post(s)
Liked: 4966
How did I go about noticing this?
Well, when my room is being as dark as possible, I chose to project a black background and not blue (JVC menus), and the 'black' is like, a couple percent gray.
If I stand in front of the projector, blocking the light onto the wall, my shadow from my body is much darker and more black then the 'black' coming out of the JVC.
Am I doing something wrong?
I have no HDMI devices connected to it, just shooting the JVC menus onto my wall.
Yes, this is not a good test. The auto iris will not react to the black background of the JVC. It needs an input signal for that. If you feed it a signal and send it a black screen and make sure that the iris is set to auto 1 then you'll get a far deeper black than your test above. Even then it's not the best test. If you sit in a totally black room, your eyes start to adjust. Instead, try playing something like interstellar and scan to 53:30 into the movie for the star field.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is online now
