Panning Bright Artifacts - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Imatk
post #1 of 11 Old 06-20-2020, 01:32 PM - Thread Starter
Imatk's Avatar
Quoted: 47 Post(s)
I have a new NX5 but have had other projectors before RS-20 and a VW90.
I've never noticed this on any of the other projectors, but I'm starting to wonder if it happens on all projectors and I simply didn't notice it... OR it's only happening on my current projector and it's either "normal" or a problem.
Basically it only happens with flesh tones (at least that's what I've observed) when the camera pans, there are these very bright... pretty much white highlights that trail behind slightly during the pan.
It's fairly annoying when I see it, but I don't see it all the time.
Is this just a normal thing with all projectors or is this a problem.
I'm using no motion enhance whatsoever BTW.
Imatk is offline
post #2 of 11 Old 06-20-2020, 08:47 PM
bdht's Avatar
Quoted: 790 Post(s)
Liked: 377
Sounds like inverse ghosting(overshooting), the native 2160p lcos panels low ansi contrast may be accentuating it in certain scenes.
bdht is online now
post #3 of 11 Old 06-21-2020, 01:29 PM
MDesigns's Avatar
Quoted: 296 Post(s)
Liked: 149
Sounds just like the JVCs motion enhance that shouldn't be used. Are you sure it is not On?
Lähetetty minun LM-G710 laitteesta Tapatalkilla
JVC DLA-RS500
MDesigns is offline
post #4 of 11 Old 06-21-2020, 01:56 PM
bdht's Avatar
Quoted: 790 Post(s)
Liked: 377
What's interesting is I think the pixel shifting actually improved motion performance on the JVCs due to operating at a higher internal refresh rate in order to accomplish the shifting and avoiding sample and hold which exaggerates ghosting. That in combination with the overshoot compensation. If he's seeing bright ghosting than I would imagine there's an issue with the overshoot compensation with the native 2160p panels and the lack of shifting reducing sample and hold artifacts.
I would recommend trying frame interpolation on low or black frame insertion if the newer JVCs have it.
Here's an example of voltage overshoot with and without compensation.
bdht is online now
post #5 of 11 Old 06-21-2020, 06:02 PM
Mike Garrett's Avatar
Quoted: 14048 Post(s)
Liked: 11723
Sounds like motion enhance is turned on to me.
Mike Garrett is offline
post #6 of 11 Old 06-21-2020, 06:04 PM
Liked: 11723
Don't think so. I think he is using settings that is causing the problem.
post #7 of 11 Old 06-22-2020, 12:39 PM - Thread Starter
Imatk's Avatar
Quoted: 47 Post(s)
You guys were right. I thought I had the motion control off... it was set to low.
All fixed now!
Mike Garrett and MDesigns like this.
Imatk is offline
post #8 of 11 Old 06-22-2020, 02:28 PM
bdht's Avatar
Quoted: 790 Post(s)
Liked: 377
You guys were right. I thought I had the motion control off... it was set to low. All fixed now!
lol
So was seeing interpolation artifacts as bright ghosting?
bdht is online now
post #9 of 11 Old 06-22-2020, 03:24 PM
Debonaire's Avatar
Quoted: 349 Post(s)
Liked: 77
Frame interpolation converts 24p to 60p? If they would convert to 72p, would we still see the soap opera effect?
With my CRT I'd use 1080i72. But there wasn't any FI going on, I'd just show the same frame three times. That would get rid of the strobing effect with 3:2 at 1080p60, but wouldn't make the motion any smoother.
Anyway, 1080i72 never did bother me, and actually looked better than 1080p24/48, etc using LCOS or LCD, which just looked jarring.
Debonaire is online now
post #10 of 11 Old 06-23-2020, 01:06 AM
MDesigns's Avatar
Quoted: 296 Post(s)
Liked: 149
lol
JVC's "Motion Enhance" setting is not interpolation. It's somekind of "panel overdrive".
Interpolation is called Clear Motion Drive, aka. CMD. That doesn't cause the phenomenon described.
JVC DLA-RS500
MDesigns is offline
post #11 of 11 Old 06-23-2020, 10:15 AM
bdht's Avatar
Quoted: 790 Post(s)
Liked: 377
JVC's "Motion Enhance" setting is not interpolation. It's somekind of "panel overdrive". Interpolation is called Clear Motion Drive, aka. CMD. That doesn't cause the phenomenon described.
Oh, hmm.. I have a 144hz AMVA panel and motion acceleration helps with ghosting. That panels response is slower than LCOS though at 12ms black to white. Maybe due to JVCs overshoot compensation adding voltage overdrive causes inverse ghosting.
Originally Posted by Debonaire View Post
Frame interpolation converts 24p to 60p? If they would convert to 72p, would we still see the soap opera effect? With my CRT I'd use 1080i72. But there wasn't any FI going on, I'd just show the same frame three times. That would get rid of the strobing effect with 3:2 at 1080p60, but wouldn't make the motion any smoother. Anyway, 1080i72 never did bother me, and actually looked better than 1080p24/48, etc using LCOS or LCD, which just looked jarring.
3/2p at 60hz does look different than 23p not just considering the artifacting. If youre accustomed to 3/2 and switch to 23p it will look like a bit of soapy effect and take some getting used to. Frame interpolation will probably always have a soapy look due to the high frame rate look. Like Hobbit HFR looked very different.
bdht is online now
