Optoma HD81 1080p DLP official discussion - Page 162 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4831 of 4837 Old 06-21-2019, 05:36 AM
Liked: 0
Sorry for reviving an old thread on an ancient projector.
My HD81 was working perfectly until yesterday. The VXP control unit will not power up at all. I was wondering if anyone had any suggestions.
PrimitiveLondon is offline
post #4832 of 4837 Old 06-21-2019, 11:27 PM
Liked: 1
Is your control unit's red standby light on and won't turn on (to blue)?
Do you have a standby light on the projector unit itself?
Or is the control unit completely dead-dead even after unplugging and re-plugging a couple times?
Alan
alzullig is offline
post #4833 of 4837 Old 07-04-2019, 12:53 PM
Liked: 0
Hi guys, I was wondering has anyone figured out how to access the projector menu without the av box? I just got my hands on this but it only came with the projector it self. I did open it up and used the internal power switch to turn it on and it's running fine just trying to figure out if anyone had any luck getting into the menu. Is there a way to use the service port to maybe configure the settings? Any help will be great. Thanks.
Aizensama is offline
post #4834 of 4837 Old 07-04-2019, 01:23 PM
Liked: 1
I’m pretty sure you can fully control the projector including bringing the menus up by using the RS-232 Serial Port. Normally this serial cable comes from the scalar unit which also has both serial input & output ports that just pass through serial commands.
You would hook a computer to the serial port using a null-modem serial cable. Then open a Terminal program on the computer and issue the appropriate serial commands....Two problems though, most modern computers don’t have a serial port. This is easily remedied with an inexpensive USB-Serial Port dongle. Null-modem serial cables are also very inexpensive.
The second problem is finding what the various serial port control commands are. These are usually used by pro-installers in a whole integrated theater control system like Crestron... You might be able to find these commands on the internet or more likely, direct from Optima customer service....
Good luck,
Alan
alzullig is offline
post #4835 of 4837 Old 07-04-2019, 05:54 PM
Liked: 0
Good luck,
Alan
Thanks for the help. I will look into getting the serial cable. I got few old pc's laying around so serial port wont be a issue.
I did come across few websites that have the codes but I'm not too sure if they're specifically made for a certain model or optoma uses them for all of their projectors.
post #4836 of 4837 Old 08-14-2019, 08:08 PM
Liked: 0
I'm a complete noob at this, I did find some hex commands from optoma but they don't seem to be working or maybe I'm not using them correctly. I'm currently running them through perl to communicate with the rs232 port, but I'm not getting any response. Does anyone know of any program that might be better at communication with rs232? And sorry if this sounds dumb, but I found protocol for optoma HD81, can those be used to communicate with it or is that only through a certain receiver. I also wanted to know if 81-lv video receiver is compatible with HD81?
post #4837 of 4837 Old 09-17-2019, 02:49 PM
Liked: 1
I’m pretty sure your serial cable has to be a null-modem cable...You are using that instead of a regular serial cable...right? Are you not getting any response from the unit whatsoever?
alzullig is offline
Optoma , Vivitek D950hd 3000 Lumen 1080p Office And Home Theater Projector , Casio Rs 232 Adapter Catalog Category Projectors Accessories
