Quoted: 3741 Post(s)
Liked: 905
Greg - since many of us will be calibrating our units very shortly, could you please comment on how the RGB controls work compared to the offset controls.
Someone reading this at first glance may think the answer is obvious - gain controls the high end, offset controls the low end. However its been stated many times that the offset control does not do what one things it would do, and actually impacts the entire range.
So I was hoping you can elaborate on this a bit. Specifically, if the offset control impacts the whole range, and so does the RGB control, that do these controls serve any different purpose on this unit, and if so, what? When doing your calibration was it sufficent to use just the RGB control or was it a combo of RGB and offset? Thanks!
