JVC DLA-RS1/DLA-HD1 firmware - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 09-20-2007, 03:24 PM - Thread Starter
ResOGlas's Avatar
Hello, I downloaded version 62 from a link someone posted in a thread here on AVS. Is version 62 (HD1_062.jvc) the newest available, and can we have a sticky thread for RS1 firmware since it's such a popular PJ?
here's the link for firmware version 62:
http://interactive-av.co.uk/instruct..._v62_setup.zip
ResOGlas is offline
post #2 of 28 Old 09-20-2007, 04:11 PM
upnorth's Avatar
I am runnning everthing over HDMI through a DVDO-VP30 do I need the firmware upgrade and will it help with anything?
Just one more upgrade honey, I promise!!
upnorth is offline
post #3 of 28 Old 09-20-2007, 04:49 PM - Thread Starter
ResOGlas's Avatar
press "UP, DOWN, RIGHT, LEFT, Enter" really fast to enter the service menu. It should display the current firmware version you're running. Press exit to exit the service menu.
There are improvements to the chroma level with analog inputs with newer firmware. (Composite, S-Video, Component)
ResOGlas is offline
post #4 of 28 Old 09-20-2007, 07:15 PM
Lylepdx's Avatar
So how do you use the data to actually complete the update? Thx
Don't lose sight of the Big Picture
Lylepdx is offline
post #5 of 28 Old 09-20-2007, 08:13 PM - Thread Starter
ResOGlas's Avatar
You hook up the PJ to a Windows XP compatible PC with an RS-232 cable. The ZIP file contains the exe program and the firmware file. Instructions are given in the included PDF files.
ResOGlas is offline
post #6 of 28 Old 09-20-2007, 10:49 PM
Lylepdx's Avatar
Thanks, Res.
Lylepdx is offline
post #7 of 28 Old 09-21-2007, 02:54 AM
GaryB_UK's Avatar
You need a cross-connected RS232 cable. A straight RS232 cable, like the ones used for modems, won't work. It is in the instructions, but I thought I should mention it just in case you go to buy the cable before you read them.
GaryB_UK is offline
post #8 of 28 Old 09-21-2007, 03:49 AM
Mr.D's Avatar
Liked: 26
You also need windows XP. The update software installs and runs but doesn't actually work on W2k.
digital film janitor
Mr.D is offline
post #9 of 28 Old 09-21-2007, 04:18 AM
GaryB_UK's Avatar
I've used it on 2K with no problems.
GaryB_UK is offline
post #10 of 28 Old 09-21-2007, 04:28 AM
Mr.D's Avatar
Liked: 26
Didn't work for me , sat there for a bit and verified it was communicating then just hung . Nasty little xp ( not even sp2) laptop worked fine though.
Mr.D is offline
post #11 of 28 Old 09-21-2007, 10:19 AM
takisot's Avatar
I upgaded via Vista without problem.
A Never Ending Quest Τowards Visual Nirvana..
takisot is online now
post #12 of 28 Old 09-22-2007, 03:14 PM - Thread Starter
ResOGlas's Avatar
Nice to know.
Has anybody used a USB RS-232 cable? Both the computers in my house don't have serial ports.
ResOGlas is offline
post #13 of 28 Old 09-22-2007, 04:17 PM
GaryB_UK's Avatar
Nice to know.
Take a look at this post on the UK forum. Seems to work OK.
GaryB_UK is offline
post #14 of 28 Old 09-22-2007, 06:10 PM - Thread Starter
ResOGlas's Avatar
There's no difference between UK firmware and other territories, correct?
ResOGlas is offline
post #15 of 28 Old 09-23-2007, 05:42 AM
GaryB_UK's Avatar
Correct
GaryB_UK is offline
post #16 of 28 Old 06-20-2010, 04:15 PM
jstromberg's Avatar
Hello everyone,
I know this is a very old thread however I own this projector, this thread talks about the firmware to it, and it discusses updating the firmware for the device. Could someone please tell me if this is the latest firmware or not (JVC's website for my projector seems to be down... )
If this is the latest version, fine, however is it safe to use the firmware provided above?
Thank you in advance and sorry about the old topic bump,
jstromberg
jstromberg is offline
post #17 of 28 Old 06-21-2010, 02:27 AM
GaryB_UK's Avatar
V62 is still the latest software for the HD1.
I've taken a look at the firmware above. The zip file is a slightly different size from the one I originally distributed (I work for JVC UK and wrote and distributed the installer), but the exe file in the zip file is the correct size.
If you want a guaranteed good copy, PM me your email address and I'll send it over.
GaryB_UK is offline
post #18 of 28 Old 06-21-2010, 04:35 AM
Freewheeler's Avatar
Hi, any updates for HD100 / RS2?
Freewheeler is offline
post #19 of 28 Old 06-21-2010, 05:00 AM
GaryB_UK's Avatar
There were no updates released for the HD100/RS2. The standard firmware incorporated all of the tweaks that were added to the HD1/RS1 at the time of release.
GaryB_UK is offline
post #20 of 28 Old 06-21-2010, 08:43 AM
Jason Turk's Avatar
To add...do this on the unit itself, not the remote.
Jason Turk is offline
post #21 of 28 Old 06-24-2010, 10:34 PM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
I always do the [up, down, right, left , enter] on the remote ... Is there a reason we shouldn't?
stumlad is offline
post #22 of 28 Old 06-26-2010, 03:35 AM
GaryB_UK's Avatar
You can do this on the Remote Control or on the PJ. It makes no difference.
GaryB_UK is offline
post #23 of 28 Old 07-30-2013, 08:40 AM
Tracey Braun's Avatar
Is there a new update or somewhere I can find this one. No longer available on the site
Tracey Braun is offline
post #24 of 28 Old 08-19-2015, 03:08 AM
Liked: 0
This is a very old topic but i have this info in service menu: Gary can you Help me understand What version of rs1 is this?
Thanks a lot !
Superduca is offline
post #25 of 28 Old 08-20-2015, 12:47 AM
Liked: 0
Informative post
Michael Bainn is offline
post #26 of 28 Old 09-02-2015, 01:35 AM
oventurini's Avatar
Hi Can you upgrade the firmware from a Mac?
oventurini is offline
post #27 of 28 Old 11-11-2015, 09:44 AM
Ed Rogers's Avatar
Any new link for the RS1 firmware?
Ed Rogers is offline
post #28 of 28 Old 03-18-2017, 10:15 AM
Liked: 0
JVC HD1 software update
Hi Gary
I came accross the older post on v62 software for HD1, however the indicated link doesn't work anymore.
Any chance one could still update an HD1 to latest software and if so how.
Cheers
mitzi
mitzi is offline
Jvc Dla Rs1 Projector
