BIG BAD NEWS
well the code not work.
i am may to stupid or benq change it or something else.
so i cant do what i origial like to do but i found a very strange bad thing.
when you read all my post in this thead i say yes with the sony bd player
and the ps3 the
pr. can do 24p right.
THIS IS WRONG BUT IN A VERY BAD WAY!
the
pr. shows 24p but this 24p still have the same 3:2 motion bug inside like the
normally 60p have.
i was in the beginning not 100% sure about it but thanks that i have 2 ps3 here i connect both
via hdmi one with 24p force and the other one 60p.
the
pr. shows the one with 24p at 24p and the one at 60p at 60p but
both have the same 3:2 pulldown bug inside that the 24p not have anymore!
to make it 1000% sure i switch my big 3 chip on and there you can easy see a difference in motion
when i switch between 60p and 24p.
with both ps3 to the w 5000 there is no difference between 24p and 60p.
the w5000 for some reason take the 24p and bring this signal with no motion bug somehow to 60p with the motion bug.
so it add the motion bug that is not anymore there with 24p.
THAT IS VERY VERY BAD
btw a very good test is the bd "the day ater tomorror" the beginning seq.first 50 sec. with the fligh over the iceberg.
this is no screen shot!
i have the light on to show the w5000 and left and right a ps3.
on top the big picture is my 3 chip dlp(dim down to min. light out about 4000 lumen)
and down the w5000 picture both on a small 3m test screen that i
normally use only for 3d.
