SA 8300 HDC "Record to VCR" problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-21-2009, 04:46 PM - Thread Starter
Ronin1's Avatar
I switched from a SA 8300 HD to a SA 8300 HDC (Cable Card) DVR which on on TWC and has the SARA OS. The problem I have encountered is that when I select a recorded program to output by the "Record to VCR" function, the program plays back on the TV and I am unable to do anything else. With the SA 8300 HD I was able to either watch a live program or another previously recorded program. The 8300 HDC box is more or less unresponsive to input with the remote control. When I press the "Last" (channel) button the display on the front of the box shows it changing channels, but it still continues to display the program being played on the "Record to VCR".
Is there anything I can do to change this?
Any suggestions would be appreciated!
Ronin1 is offline
Reply HDTV Technical
