CM-7777 / 7778: "New & Improved"? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #151 of 155 Old 10-18-2019, 09:35 AM
rabbit73's Avatar
Quoted: 913 Post(s)
Liked: 401
Originally Posted by abnutcracker View Post
We shall see with the new production coming out of Bulgaria for the V3 on these.
What makes you think they will be made in Bulgaria? I thought it would be in the PCT Yantai, PRC factory.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #152 of 155 Old 10-19-2019, 06:32 AM
abnutcracker's Avatar
Liked: 0
There has been an severe issue getting hardware these past months ,so I can only advise based what I was told .The issue of tariffs has played a factor into decisions being made . In fact I was told it lead to the 9521HD being discontinued . So hopefully next month when the V3 units start to become available through distribution we will get an idea how well this next change is received .
abnutcracker is offline
post #153 of 155 Old 10-29-2019, 05:13 AM
Quoted: 28 Post(s)
As always, CM will produce them where they can make maximum profit with little concern with creating US jobs.
That's why i have used nothing but made in USA Winegard for 40 years.
old tv guy is offline
post #154 of 155 Old 10-29-2019, 07:45 AM
tylerSC's Avatar
Quoted: 1359 Post(s)
Liked: 252
About 10 years ago Channel Master shut down their North Carolina manufacturing facility and moved their headquarters to Arizona. Now their antennas are made in China. Some of their original antenna designs are no longer manufactured. As for Winegard, their primary antennas are still made in the USA, but their amplifiers may also be made overseas as well. But I do wish Winegard would still make some of their UHF yagi antennas and the 4bay and 8bay versions.
tylerSC is offline
post #155 of 155 Old 10-29-2019, 07:47 AM
tylerSC's Avatar
Liked: 252
Also I notice in the specs the new version 3 of the 7777 preamp has the gain lowered to 26db, so maybe overload issues won't be as problematic as before when it was 30db.
tylerSC is offline
Reply HDTV Technical
Channel Master Cm 7777 Titan2 Uhf Vhf Preamplifier Cm7777
