AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   HDTV Technical (https://www.avsforum.com/forum/25-hdtv-technical/)
-   -   Direct tv losing "signal on satelite in 1" only at certain times of day..... (https://www.avsforum.com/forum/25-hdtv-technical/1428433-direct-tv-losing-signal-satelite-1-only-certain-times-day.html)
Crazedhick3 09-08-2012 02:08 PM
Not sure if I am posting this in the right forum but, I have a Direct Tv HD DVR in my living room and the one in my garage that is losing channels such as all my local HD channels, ESPN, ESPN2, FX TNT and others. But Im only losing them in the afternoons of each day. Also, I never lose signal to my bedroom box. All 3 are HD recievers. The one in the garage is only HD too. Not a dvr. Checked signals. Im at 95% on 101. and pretty high on others. I tried to realign to see if that would make a difference but nothing. No trees in the line of sight of dish. honestly, my neighbor just took down alot of trees and should be getting BETTER signal. I dont understand why its during certain time of day and I never lose anything in the bedroom. Any guidance on this would be greatly appreciated. Thanks.
joed32 09-09-2012 04:46 AM
Could be a problem with the receiver or the wiring, can you switch the receivers and see if the problem stays in the garage or if it follows the receiver into the living room? If you don't want to bother with it just call Directv and let them fix it.
NetworkTV 09-09-2012 06:33 AM
Maybe in the afternoon, the line leading to your garage TV is getting hot and causing a bad crimp or some other cable issue to manifest itself. Or, the garage is getting humid during the day.
I'd try the advice listed above and swap boxes to see if the problem either follows the box or stays at the location. If it follows the box, it's a bad box. If it stays in the same place, it's probably bad wiring. If it goes away, it's likely conditions in the location that have not yet affected the box you moved there - i.e., the humidity in the gargage hasn't affected the bedroom box you moved out there yet.
Crazedhick3 09-09-2012 08:36 AM
So, a wiring issue to the garage can affect the reciever/DVR in the living room? That is actually the first place i was gonna start because the coax to the garage is buried and more likely I guess to have an issue. Just didnt understand why it would affect the living room box.
Crazedhick3 09-09-2012 08:38 AM
Also, another thing I didnt bring up before. I can tune to one of the affected channels while I still have a signal but as long as I dont change channels, Its fine all day. But if I change to a different channel and then try and come back, NOTHING!
NetworkTV 09-09-2012 09:11 AM
Ah, it wasn't sounding like the problem was also in the living room:
I have a Direct Tv HD DVR in my living room and the one in my garage that is losing channels such as all my local HD channels, ESPN, ESPN2, FX TNT and others..
I thought you were just noting that you had a box in the living room, but the one in the garage was losing channels. It was that use of "is" verses "are" after you mentioned the garage unit that confused me.
Is it safe to assume you have lines running directly from the dish to each box? If so, maybe the multiswitch in the dish is failing.
Crazedhick3 09-09-2012 10:23 AM
sorry. after rereading that I can see where you could be confused. Yes, both boxes are doing the same thing. 4 cables coming off of dish going to, what I assume is a grounding block. Then two to the DVR in living room, One to garage and one to box in bedroom. Bedroom has no issues at all. And like I said, as long as I am tuned to one of the channels before it loses signal, Im good until I change the channel. Like right now, We have been tuned to FOX for the football game in the living room. All is good, but nothing in the garage. Thank goodness for Red Zone Channel.
retiredengineer 09-09-2012 03:46 PM
The looks-like-a-grounding block is the 'multiswitch'. It sends the appropriate signal from the dish to the correct receiver. You need to have DirecTV come out and have it checked out.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
