San Jose, CA: Which antenna to get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-09-2012, 08:18 AM - Thread Starter
hitman408's Avatar
I was thinking of getting Direct C5 ClearStream http://www.amazon.com/Antennas-Direct-C5-ClearStream-Combiner/dp/B002E1UNWS/ref=pd_cp_e_2 , from searching I think I need to have both uhf and vhf to get all the local channels in san jose. What outside antenna do guys recommend?
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5ed69b9eb30b1d
hitman408 is offline
Reply HDTV Technical
