PVI VeCOAX MicroMod - Experiences? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #181 of 193 Old 09-26-2019, 10:58 AM
Liked: 6
Are there any other modulators people can recommend? I see Thor has a single channel model for under $300 now and there are some cheaper ones on Ebay that look the same.
I have really cheap modulator that I paid about $100 for that sort of works but not with all tuners and I have a PVI Pro 1 that works pretty well but It is a lot more expensive than I would want to pay for a modulator again.
WDB123 is offline
post #182 of 193 Old 09-28-2019, 09:20 AM
rabbit73's Avatar
Quoted: 903 Post(s)
Liked: 394
It does look interesting.
https://thorbroadcast.com/product/pe...modulator.html
manual:
https://thorbroadcast.com/upload/fil...-modulator.pdf
Name:	Thor Petit HDMI RF MODULATOR1_1.jpg
ID:	2620966   Click image for larger version
Name:	Thor Petit HDMI RF MODULATOR2_1.jpg
ID:	2620968   Click image for larger version
Name:	Thor Petit HDMI RF MODULATOR3_1.jpg
jockeypete likes this.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #183 of 193 Old 09-28-2019, 06:19 PM
Channel99's Avatar
Quoted: 157 Post(s)
Liked: 81
Originally Posted by rabbit73 View Post
It is interesting that the licensing costs - MPEG, Dolby, HDCP, Zenith/LG, etc., were long blamed for these hovering near the $1000 mark, and now they have dropped so much.
AliExpress has a very basic one for $219. Typical of their web site - you have to select the color as HDMI to see it....
https://www.aliexpress.com/item/32847163905.html
Channel99 is offline
post #184 of 193 Old 09-28-2019, 10:02 PM
Liked: 6
I like those, makes for a nice compact rack if you have a bunch of them, just not enough feedback on how well they work.
I have that same modulator saved on my Ebay watch list but I am waiting to find reviews.
WDB123 is offline
post #185 of 193 Old 09-29-2019, 07:27 AM
rabbit73's Avatar
Quoted: 903 Post(s)
Liked: 394
That looks promising. The modulation output stated in the description is ambiguous. Is it ATSC QAM or ATSC 8VSB or both? 8VSB is ATSC, OTA; QAM is SCTE, cable.
QUESTION:
If I mix OTA 8VSB signals with QAM signals from the modulator, can my TV tuner handle it if it is set to AIR?
This modulator looks more like the Thor Petit:
https://www.aliexpress.com/item/33015285409.html?spm=a2g0o.detail.1000014.1.73c140 faJqJ85U&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.13338.12 8125.0&scm_id=1007.13338.128125.0&scm-url=1007.13338.128125.0&pvid=cec900d5-9431-43b4-907b-52dc64e08f1b
also:
https://www.ebay.com/itm/ATSC-modula...QAAOSwMrJc3Bx3
Lord Kelvin, 1883
rabbit73 is offline
post #186 of 193 Old 09-29-2019, 07:38 AM
rabbit73's Avatar
Quoted: 903 Post(s)
Liked: 394
Yes, not enough feedback. As usual, someone will have to be the first tester (guinea pig) for us.
Dictionary
guin·ea pig
/ˈɡinē ˌpiɡ/
noun
noun: guinea pig; plural noun: guinea pigs; noun: guineapig; plural noun: guineapigs
  1. 1.
    a tailless South American rodent of the cavy family. Originally raised for food, it no longer occurs in the wild and is now typically kept as a pet or for laboratory research.
  2. 2.
    a person or thing used as a subject for experiment.
    "we were used as guinea pigs to test the effects of radiation on human beings"
Lord Kelvin, 1883
rabbit73 is offline
post #187 of 193 Old 10-17-2019, 08:13 PM
JHBrandt's Avatar
Quoted: 2855 Post(s)
Liked: 1387
Some TV tuners (LG, for instance) can handle it, so I guess you'd just have to try it and see.
I have a cheap iView STB that I wanted to clear the channel memory on, so I set it to Cable and ran a full scan, expecting nothing since it was connected to OTA signals. RF 2-13 are the same frequencies for OTA and cable, but I figured it would ignore the 8VSB modulation and only scan in (nonexistent) QAM signals, leaving me with an empty channel list. But surprisingly, it still picked up my VHF OTA channels! So apparently it will tune either modulation in either setting. The Cable/Air setting just controls which frequencies to scan for channels 14 and up.
An iView (and presumably other Mstar-based tuners like HomeWorx, ViewTV, etc.) can also add Cable channels to an OTA channel list. You just have to switch it to Cable and do a manual scan of the QAM channel you wanted to add.
JHBrandt is offline
post #188 of 193 Old 10-18-2019, 07:08 AM
rabbit73's Avatar
Quoted: 903 Post(s)
Liked: 394
Very interesting. Thank you for your answer based on your extensive experience with converter boxes.
Lord Kelvin, 1883
rabbit73 is offline
post #189 of 193 Old 10-23-2019, 09:34 AM
Liked: 0
I tried
I admit I tried to go cheap, I bought one of Thor, but it did not work. I could not connect with all my televisions, just some of them. it was just cheap. I guess that the extra money you pay for is called quality. I saw another forum where other customers could not connect to all Tvs so I guess it's not just me is a bug of Thor. Bought Minimod 2 and connected all my Tv first try.
Joshua Dixons is offline
post #190 of 193 Old 10-23-2019, 09:44 AM
Liked: 0
cheap
yes it sucks to spend money for a micromod, but I tried Petit and does not work.
post #191 of 193 Old 10-23-2019, 11:10 AM
rabbit73's Avatar
Quoted: 903 Post(s)
Liked: 394
Please give me the link to the forum where other customers had a problem connecting the Thor to their TVs. Since I have a Thor that so far is working well for me, I would like to know about it.
Lord Kelvin, 1883
rabbit73 is offline
post #192 of 193 Old 10-23-2019, 11:16 AM
Super Moderator
markrubin's Avatar
Quoted: 1811 Post(s)
Liked: 3582
after making programming changes with the MicroMod, I have seen where some TV's in the house do not pick up the channel even after a rescan
however a hard reboot of the TV (pull AC power plug/wait 10 seconds or so, plug back in/ rescan) may resolve the issue
rabbit73 likes this.
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess HDCP = Hollywood's Draconian Copy Protection system
LG C9 OLED owner
markrubin is offline
post #193 of 193 Old 11-14-2019, 11:55 AM
Liked: 1
Sounds like Joshua is doing free Promo's for the company he works for, meanwhile trashing another companies units that work terrific.
WoodieLA is offline
Reply HDTV Technical
