Grounding antenna masts and coax cable - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #121 of 138 Old 06-19-2019, 06:51 AM
Quoted: 29 Post(s)
Actually,you should always ground a attic mounted antenna the same as one on the roof.
Lightning travels miles through open air so 3\4 inch of plywood and shingles won't stop it.
And even though the NEC has finally began to improve their grounding codes after decades of people like me complaining, they still have room for improvement on antenna grounding which may take another decade or two for them to finally change
old tv guy is offline
post #122 of 138 Old 06-19-2019, 07:01 AM
Quoted: 29 Post(s)
Originally Posted by J_ph View Post
What happened to my coax?
I have a CM4228hd antenna and CM7777 amp. There is a ground from the antenna and on the block that enters the house. This "burned" or corroded coax is at a coupling in the external coax cable. The black on the outside is just residue from electrical tape. It was sealed with the tape, and neither the tape or outer coax showed any signs of distress, just the inside. I've replaced the coupling and packed the connection with dielectric grease. Is this the result of water in the cable?
thanks in advance!
Water and current are a bad mix inside a connection.
And if you are using steel center conductor coax it makes it even worse.
Always seal coax connections with "coax seal" or similar butyl rubber coax wrap.
The connections atop every 400 foot cell tower are always sealed that way for good reason.
And they don't ever use grease in connectors.
Primestar31 likes this.
post #123 of 138 Old 06-21-2019, 11:06 AM
AntAltMike's Avatar
Quoted: 179 Post(s)
Liked: 86
I followed the evolution of the code from 1999 to 2011. Mast grounded with 10 gauge copper, 8 gauge aluminum or 17 gauge copper clad steel, to an 8' x 1/2" dia ground rod, bonded to the ground electrode system with 6 gauge copper wire.. Outer coax grounded to the ground electrode system as near as possible to the point where it enters the building with wire approximately equal in current carrying capacity as the shield itself.
They did prohibit using the copper water pipe for that ground I think in 2002, not because it was technically deficient, but rather, because it's ground path could be broached by subsequent plumbing repair with plastic pipe. I think that in 2011 they put a limit on how far the ground wire path of the mast ground could veer laterally from straight down, but that really wasn't an improvement because the purpose of that wire was to drain static discharge, not to draw the lightning current away from other paths.
An antenna in an attic doesn't tend to "attract" lightning because it is not the highest metallic object and is not subject to developing a static charge due to the wind blowing across its elements.
AntAltMike is offline
post #124 of 138 Old 06-21-2019, 06:35 PM
Quoted: 29 Post(s)
I was doing single point grounding years before the NEC finally woke up and corrected their grounding codes and i still feel they have plenty of room for improvement when it
comes to gounding of antennas.
While the NEC has completely different grounding codes for air terminals, they still havn't recognized that roof mounted antennas act just like air terminals when hit by lightning.
Tschmidt likes this.
post #125 of 138 Old 09-08-2019, 08:20 AM
Tschmidt's Avatar
Quoted: 51 Post(s)
Liked: 58
I'm late to the party but I didn't think the NEC (NFPA 70) addresses lightning, it is an electrical safety spec. Lightning protection is covered by NFPA 780.
Tschmidt is offline
post #126 of 138 Old 10-09-2019, 04:52 PM
Liked: 0
I'm getting different NEC standards on this, so I nwated to ask on the forutm, syould you only run a ground to the mast and ground block / lightning artrestor, or should the mount also have a dedicated ground wire ran to it? Or only for certain types of mounts (if so, which m ount types require a dedicated ground wire)?
scott55t is offline
post #127 of 138 Old 10-09-2019, 07:15 PM
Liked: 0
I realize the coax cable should be grounded by a ground block or lightning arresstor per NEC code and also the bottom of the mast should be grounded. What about the mount that holes the mast? I found a few old manuals that mention it, but everythign recent doesn't even mentioned also grounding the mount. Is it necessary?
scott55t is offline
post #128 of 138 Old 10-10-2019, 07:28 AM
rabbit73's Avatar
Quoted: 1091 Post(s)
Liked: 482
Hello, scott55t; welcome to the forum.
NFPA 70®
National Electrical Code®
2014 Edition
810.15 Grounding. Masts and metal structures supporting
antennas shall be grounded in accordance with 810.21.
810.20 Antenna Discharge Units - Receiving Stations.
(C) Grounding. The antenna discharge unit shall be
The code is ambiguous. I'm not a code expert, but my interpretation is that you only need two grounding conductors, one for the grounding block (ADU) and one for the mast, because the mast is higher than the mount and the mount is already bonded to the mast. However, the interpretation by the AHJ (Authority Having Jurisdiction), who is usually the local electrical inspector, becomes the local law that is binding on you.
If the antenna is outside, the coax shield should be grounded with a grounding block that is connected to the house electrical system ground with 10 gauge copper wire for electrical safety and to reject interference. For further compliance with the electrical code (NEC), the mast should also be grounded in a similar manner to drain any buildup of static charge which will tend to discourage a strike, but the system will not survive a direct strike.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #129 of 138 Old 10-10-2019, 02:23 PM
Quoted: 41 Post(s)
Liked: 7
Outdoor channel master tv antenna grounding question
Hello all and thanks for having me. I need some advice and joined this forum hoping to be pointed in the right direction.
First off I am not an electrician and dont know the first thing about grounding or wiring. I will try to explain it the best I can.
I recently moved to Middle Tennessee in a very rural area. No cable tv or internet is currently available at the home we purchased with a few acres. Did I mention cell phones barely get a signal out here and only ar&t work we had to switch over upon moving here.
I bought a small indoor tv antenna and stuck it in the window and we were able to pull in only 4 channels. On some days if I rescan we can get 7 or 8 but can rarely watch them as they pixelize and disaapear.
I talked to a couple people at a local market who have old school tv antennas (not cheap modern chinese crap) and are picking up 50-70 channels from nashville and even some from Huntsville Alabama. I stopped by my nearest neighbors house to see his set up and he does in fact pull in far more channels than I imagined.
Out in my yard I have a antenna mast tower approx. 20 ft high with no antenna on it. Its heavy duty and in the perfect place on the property to pull in a signal from Nashville 60 miles away to the north. 100 ft from the antenna mast is my living room wall where our tv is located.
So I went to channelmaster and purchased the longest range outdoor antenna they had (after weeks of researching antennas) I will attach a photo of the antenna. Its rated at 100 miles, im aware its debatable if a vhf signal can reach an antenna at 100 miles but I wanted the best chance at doing so. The transmission towers im after are 60-70 miles and Im getting a few with a $20 walmart indoor antenna. Buying this big boy for outside and having it high up on a mast has to increase my chances to pick up the signals.
The antenna I purchased does not have a motorized rotor as I didnt want to run electricity to the mast. Just point it in the degrees of Nashville and bolt it down as my neighbors have done. I purchased the antenna and a pre amp booster suggested for my zip code by channel master. The pre amp does not require its own electric as it works by taking electric it receives from the coaxial cable it uses to attach to the antenna. Antenna and booster arriving tomorrow.
I then started thinking about the need for grounding the antenna and the coaxial cable so purchased a coax ground block and a spool of #10 solid copper grounding wire. I also purchased a 5 ft copper grounding rod to ground both the antenna mast and the coaxial cable at the mast and have 120 ft of burial coaxial cable running to the house under ground. I thought everything out carefully as fas as parts and supplies I would need. Today I went out and sunk the grounding rod into the soil near the mast leaving only the top 6" sticking up so I can attach my copper.
I came in the house and started reading a little about grounding to make sure I would do it right and now I am not confident that I am. Most articles I find pertain to antennas mounted on the roof of the home. And the antennas are grounded to the homes main ground under the electric panel outside of the house.
My antenna is going to be on a stand alone mast 100+ feet away from the house all by itself out in the field nowhere near the homes main ground. The electric panel and main ground for the house couldn't be any further away than they are, completely on the opposite end of the property's. Im talking polar opposites! I am also now reading that 8' ground rods are needed?
So keep in mind this antenna is on a stand alone mast and not powered. The little booster add on is powered but from the coaxial cable that carries a charge from inside the house where an ac adapter is plugged in that the coaxial cable runs through.
I had it all planned out for a clean neat install of an antenna that besides the coaxial just had 2 U clamps . Now this simple tv antenna is turning into a whole big thing.
Can someone tell me that its ok to ground the mast (pictured) and coax to its own grounding rod and not have to buy a country mile of copper wire and dig for a week to tie it in to the main ground of the home. I have to make sure this is safe and will work.
I know to an electrician this stuff sounds simple but again I am no electrician and I will appreciate whatever advice you can give me.
Also I would like to place the full blame for this project getting started on Eva Gabor. With only 4 channels I got hooked on Green Acres and devoloped a little crush on Miss Gabor. Now they switched networks and the new transmitter with green acres is a little further out. If you ever saw Miss Gabor you can understand my urgency.
Thanks to anyone who helps bring Eve Gabor back into my life
ID:	2626304   Click image for larger version
ID:	2626306   Click image for larger version
ID:	2626308   Click image for larger version
ID:	2626310   Click image for larger version
Joev1983 is offline
post #130 of 138 Old 10-11-2019, 06:24 AM
Super Moderator
DrDon's Avatar
Quoted: 2564 Post(s)
Liked: 5025
Merged
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #131 of 138 Old 10-11-2019, 09:22 AM
MeatChicken's Avatar
Quoted: 350 Post(s)
Liked: 296
I'm sure others will chime in with additional info, but as I understand it, 8ft Ground rods are UL listed, while 4ft are not, although both are sold as ground rods and "can" be used ... If sticking with 4ft, you may want to put 2 or 3 in and bond them to each other ....
As far as the electrical ground being 58 thousand yards from the TV mast, there are many TV AC outlet "surge supressors/EMI filters" that also have an "F" coax in/out on them, that grounds your lead in coax to the outlet's/electrical system ground ... I'd probably do that, & combined with your separate grounding at the mast site of both the lead in coax and mast, you would be good to go ...
It's not 100% by the book, but by no means inadequate ...
MeatChicken is offline
post #132 of 138 Old 02-13-2020, 12:32 PM
HDdoggy's Avatar
Quoted: 14 Post(s)
I have a question on grounding an attic antenna. I realize it's a debated topic, but having experienced induced voltage from a nearby lightning strike I'm choosing to err on the side of caution.
If my attic antenna is mounted on a pvc post and sitting on a plastic stand, it doesn't really have a mast per se, would it be sufficient to run the coax down through the wall to my basement, attach it to a grounding block there, attach that to the main electric panel ground, and then (obviously) send the other side of the coax back up the wall to my TV? If so, how long can the grounding wire be? Would it be better to run the coax 25ft across my basement and mount the grounding block right next the panel, or can the grounding wire travel that far? The former would cause more signal loss, but I imagine that might be the safest way.
Any input?
edit: As an easier alternative, would something like this item, plugged in near the TV right before the coax enters it be sufficient for an attic antenna coax line? https://www.amazon.com/Leviton-5350-.../dp/B003AU3D06
HDdoggy is offline
post #133 of 138 Old 05-31-2020, 11:36 PM
Liked: 0
Originally Posted by acesat View Post
Just run 10 gauge solid copper from the antenna mast to the ground block and call it done.
Hi. I'm new here and I know this thread is more than a few yeas old. The instructions told me not to start a new thread and to find one covering my topic.
I noticed this comment and I hope I can ground my antenna the way you mentioned here.
My situation is very complicated. I'm in the city in a tall narrow 3 story brownstone. So Instead of running 2 ground wires (shield and mast) that need to be separate from each other, I was hoping to run a single ground starting from the mast then going through the ground screw on the block(splitter) then continuing down to where my electrical system is grounded on the main water pipe coming out from underground. because appearance is of importance since these houses are attached.
My other question is; I have 2 splitters, 1 splitter is at the mast feeding a cable going all the way down to a window on the main floor and another cable going to a second splitter near the roof gutter which feeds 2 cables going to 2 different windows on the top floor. So, should I ground from the bottom splitteer since it's closer to the entryways, or the one near the mast since I feel it will ground all 3 TV connections?
fxcamera1 is offline
post #134 of 138 Old 06-01-2020, 11:56 AM
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Is it ok to put 2 grounding clamps on the same copper grounding rod ? I put one for the antenna, and one for the coaxial cable.
Jim McC is offline
post #135 of 138 Old 06-01-2020, 06:14 PM
nathill's Avatar
Quoted: 297 Post(s)
Liked: 197
Doesn't post 128 above show that as being acceptable?
nathill is offline
post #136 of 138 Old 06-01-2020, 08:59 PM
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Oops ! Thanks.
Jim McC is offline
post #137 of 138 Old 06-03-2020, 09:49 AM
Liked: 0
Is it ok to run the mast ground wire to the ground screw on the block/splitter that's already grounded to the electrical system/main water pipe in the basement?
(I'm on the top floor apt. in a very tall narrow attached brownstone house in the city, and the owner doesn't want any more or my antenna wires running down in front of the house.)
post #138 of 138 Old 06-03-2020, 01:02 PM
rabbit73's Avatar
Liked: 482
It's not according to code, but it is the way some dish installers do it.
There is an alternate method used by dish installers, called the "piggy-back" method, but it doesn't meet code. It uses coax that has an attached 17 gauge copper clad steel messenger wire. That coax runs from the antenna to the grounding block, with the grounding block connected to the house electrical system ground with 10 gauge copper wire. The steel wire runs from the mast to the grounding block.
http://www.dbsinstall.com/diy/Grounding-2.asp
Todd Humphrey doesn't speak for the NFPA that publishes the NEC code, but he has some ideas that are helpful. The local electrical inspector (AHJ, authority having jurisdiction) has the final say if you are willing to get him involved. Some inspectors are more friendly than others; a local electrician could tell you.
Lord Kelvin, 1883
rabbit73 is offline
Reply HDTV Technical
ANT751R , antenna mounting , ground wire routing
