Pre-amp: separate VHF & UHF 75 ohm inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-03-2014, 04:55 PM - Thread Starter
richart's Avatar
Quoted: 162 Post(s)
Liked: 68
Is anyone still making good quality pre-amps with separate VHF & UHF inputs?
richart is offline
post #2 of 4 Old 12-03-2014, 05:17 PM
pamajestic's Avatar
Quoted: 17 Post(s)
The RCA TVPRAMP1R can be switched from combined to separate and is very affordable with generally positive reviews.
And the AntennaCraft 10G222 is a dual input only with a very high gain suitable for fringe only. Reviews are also very positive but fewer of them due to the fringe only application.
pamajestic is offline
post #3 of 4 Old 12-03-2014, 05:54 PM
Calaveras's Avatar
Quoted: 1679 Post(s)
Liked: 379
Radio Shack shows a lower gain version:
http://www.radioshack.com/antennacra...l#.VH-70L5Nx0A
16dB VHF and 22 dB UHF gain with separate inputs. Same noise figure.
Calaveras is offline
post #4 of 4 Old 12-04-2014, 12:32 PM
ADTech's Avatar
Quoted: 176 Post(s)
Liked: 90
RCA and AntennaCraft (Radio Shack) are the only ones that still offer dual inputs. The AntennaCrafts are always dual input, the RCA is switchable between combined and separate.
Everything else out there is ultra wideband with the exception of the Winegard LNA200. That one has a single input and a U/V diplexer built in so that there are separate internal amplification paths internally. That extra diplexer and other input filtering is also why the measured noise figure is well under their claims (on the unit I've tested).
Tech support for Antennas Direct
ADTech is offline
Reply HDTV Technical
