Buying New TV Need Advice Plz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-06-2016, 11:22 PM - Thread Starter
Liked: 0
Hello,this is me posting my first post so if i have any issues with it plz point it out. Now getting to the point im a bit confused on what tv to purchase. I have researched quite a bit but am still confused. I am pretty sure im going in the 4k direction. My budget is 1200$ and i am aiming at a HDTV from 48 to 50 inches. I plan on using the tv mostly for pc use watching movies playing games and internet. I cant decide between the samsung Ju6500,Ju7000 or the Sony x830c. I previously bought the m50-c1 but it makes me nervous having only 1 hdmi 2.0 port and its bad 720p upscaling isnt making me want it more. I like the Ju 7000 but the bestbuy store has crappy content on it so i cant really tell how good it is. Anyways basically im just asking for some good advice from the pros here about making a smart hdtv buy. Also im open to any suggestions about 1080p HDTVs if u believe it to be of great quality rivaling 4k tvs.
sirking101 is offline
post #2 of 3 Old 01-07-2016, 02:57 AM
bac522's Avatar
Quoted: 226 Post(s)
Liked: 124
Wrong forum, you want to post in https://www.avsforum.com/forum/166-lc...anel-displays/ as listed in the forum sticky's.
bac522 is offline
post #3 of 3 Old 01-07-2016, 04:01 AM
Super Moderator
teachsac's Avatar
Quoted: 1241 Post(s)
Liked: 2051
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread HDTV Technical
4kres , computer , hdtv , Samsung , Sony
