Cleaning a CM 4228 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Postmoderndesign
  • 1 Post By thool
  • 1 Post By Ratman
post #1 of 12 Old 09-30-2016, 01:37 PM - Thread Starter
Liked: 1
Cleaning a CM 4228
Hello, I have a ChannelMaster 4228 (the old style, not the "HD" model) that is about 7 years old. Love the antenna! It is mounted on a piece of electrical conduit that I made into a mast, and from the ground, I see a fair amount of rust on the whiskers. I'd like to take it down and clean it, and also service the connectors. A couple stations I normally get from 70 miles have slowly gotten worse, so I suspect corrosion creeping in.
What are some good practices to clean it up? I was thinking of sanding the whiskers and then putting some sort of light coating on them, such as a dielectric grease. Also, the balun to coax interface is not sealed, just screwed in...is there a good tape or sealant for this? Finally, the balun leads to the antenna side is just connected by 2 screws, dielectric grease here?
The location is upstate NY, and we get a decent amount of rain and snow, so I'd like to find a solution that will hold up to the elements. I'd like to get as much in order so that it is down for only a day or so. Any advice is greatly appreciated.
thool is offline
post #2 of 12 Old 09-30-2016, 01:50 PM
Ratman's Avatar
Quoted: 2590 Post(s)
Liked: 2424
IMO... don't worry about the antenna "oxidation".
Concentrate on cleaning the contacts, replacing the balun and properly weatherproofing all connections. Weatherboots and perhaps a dab of silicone can help keeping the weather out on the connectors.
Ratman is offline
post #3 of 12 Old 09-30-2016, 02:28 PM
Postmoderndesign's Avatar
Quoted: 565 Post(s)
Liked: 335
Or just get the new model. It cost you less than $20 a year. Take a nice nap and when the new one comes take the old one down and replace it with the new one. If the antenna had left you out in your weather for 7 years the antenna would replace you.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Display: LG OLED 65e6p, Player: OPPO UDP-203, AVR:Yamaha TSR 7810, Streaming: Comcast 60Mbps RG6 to Cat6a, Speakers: Mains Vandersteen IIC, Center, Surrounds, Rears Klipsch
Postmoderndesign is offline
post #4 of 12 Old 09-30-2016, 02:57 PM
jjeff's Avatar
Quoted: 904 Post(s)
Liked: 349
Although I thought the old 4228 was actually better than the new Chinese made model? While your correct that a new one isn't that expensive, if it only takes one an hour(very max) to clean the connections, I'd gladly do that for $60+/hr, besides I hate just tossing things that can be easily repaired.....maybe it's just me
Of course if you don't like doing such DIY projects, I agree for <$20/year you can't beat using an outdoor antenna!
jjeff is offline
post #5 of 12 Old 09-30-2016, 03:59 PM
rabbit73's Avatar
Quoted: 1009 Post(s)
Liked: 448
Keep in mind the electromotive series. Two dissimilar metals in contact should be close together in the series to reduce the chance of corrosion. The zinc coating on the steel whiskers and the vertical aluminum vertical phasing line wires of the original 4221 (AKA 3021) and 4228 are close in the series.
https://www.google.com/?gws_rd=ssl#q...ries+corrosion
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #6 of 12 Old 09-30-2016, 05:00 PM
Quoted: 565 Post(s)
Liked: 335
I have an old 4228 that is in my tower and has never been outside. The 4228 is mostly a sort of hardware mesh grid of thin metal. It has been a good antenna but I would imagine seven years outside on a pole in New York would constitute its lifespan.
Today I am using an old 4221 inside connected directly to my 2008 Panasonic Plasma and to my HDHR3. Reception is great. I am getting much better reception than I used to get. I have a lot of multi-path signal issue that require trial and error to overcome.
I can remove the 4221 antenna and with just the coax cable get all but the public television stations.
One of the public television stations needs a directional antenna for my coming whole house RG6 coax antenna network. But the 4228 may be of no use for the five drop system. I am still experimenting
noshank likes this.
post #7 of 12 Old 09-30-2016, 06:32 PM - Thread Starter
Liked: 1
I don't want to get rid of my 4228, it is a very good antenna.
So my takeaway is to clean the contacts. Rather than boots, I found a coaxial tape, self-bonding silicone tape, that looks like a good solution for the connections. Does the balun really need replacing? I've read some posts about using plasti-dip to cover the terminals.
noshank likes this.
thool is offline
post #8 of 12 Old 10-01-2016, 06:17 AM
Ratman's Avatar
Liked: 2424
Originally Posted by thool View Post
Does the balun really need replacing? .
Is it really that expensive?
While you're up there, just replace it with a new one.
Ratman is offline
post #9 of 12 Old 10-01-2016, 06:40 AM - Thread Starter
Liked: 1
Nah, do they wear out or become less effective over time? If not, then why replace?
thool is offline
post #10 of 12 Old 10-01-2016, 07:36 AM
Ratman's Avatar
Liked: 2424
Anything is possible. Do as you like.
Ratman is offline
post #11 of 12 Old 03-11-2020, 09:09 AM
videobruce's Avatar
Quoted: 880 Post(s)
Liked: 343
RF wise, probably the #1 potential problem area other than the actual connection to the antenna leads themselves. An analogy would be; replacing tire valve stems when you get new tires (non-pressure sensing).
Recording free OTA TV for 'time shifting' has been here since 1975. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #12 of 12 Old 03-11-2020, 09:47 AM
Ratman's Avatar
Liked: 2424
Whatever he did or didn't do, it's still good advice, even 4 1/2 years later.
DrDon likes this.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply HDTV Technical
