Thread Tools |
Sponsored Links | |||
Advertisement |
I speculated earlier that it wouldn't surprise me to see them change WNJU's call letters to WNBC. You just don't dump flagship call letters in market number one.
There are some people (Like me) that have "some" equipment that displays the RF channel.
I just displayed KNTV 11.3 on my last years Sony and 11.3 has the call letters KNTV but is 720p HD 16:9 on RF channel 49.5 where 11.1 KNTV is 1080i HD 16:9 on RF channel 12.3. The RF channel is not displayed but I can dig into the setup screens to find the RF channel, but it is hard and most viewers never will do unless someone in the know tells them how.
KNTV 11.3 will have a new RF channel 19.5 after the repack.
11.1 12.3 13.3 KNTV NBC San Jose Mt. San Bruno 103.1 1236 H - M - nbcbayarea.com 11.2 12.4 13.4 Cozi-TV Mt. San Bruno 11.3 49.5 19.5 KNTV-NBC Mt. Allison
Advertisement |
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Locally some of the stations do not even include their call letters in what viewers normally see, KAXT VC 1 (Not a typo, the FCC said OK), KKPX VC 65, KMMC VC 40, KCNS VC 38, KRON VC 4 (Larry needs to check).
Other stations call letters appear often on other's sub-channel's PSIP.
For a complete list see Larry's sig line for results from his antenna farm and his great list of stations (Both VC and RF sorts)
The list for my main antenna is attached, sorry I never completed the AWK program for ascending order.
SHF
For legal ID (Which I never have seen for years) is that still in the law?
SHF
The TSID is assigned to each station and is unique.
https://www.rabbitears.info/oddsande...p?request=tsid
SHF
https://www.law.cornell.edu/cfr/text/47/73.1201
You made me tune around and watch a lot of subchannels I don't normally watch
Even watching the "network simulcast" DirecTV channel during golf, you'll see KCBS' legal ID at the bottom of the screen (since that's the feed D* is using) right at the top of the hour.
I will defer to Trip regarding legal IDs under channel-sharing rules. Which may alleviate the need to file for a call-letter change.
- Trip
N4MJC
RabbitEars
- Trip
For Non-Commercial stations it appears not to be true, but as they ID so often at the end of programs the requirement must be met. And when they are begging, so many times.
"normal fashion", do you mean:
I see that format only on KOFY, the other Commercial stations seem to put it at the bottom with call letters and Cities Served.
SHF
Except of course when they make public statements.
I think that there is a quick way to check for the Form 2100 filing each day or get a report on those that have been filed. I never got the details but posts elsewhere appear to be based on those methods.
Or they private until granted?
SHF
- Trip
N4MJC
RabbitEars
- Trip
Of course the most interesting items are not attached.
https://enterpriseefiling.fcc.gov/da...5bb6274b9e0766
I have captured the TSReader data for KCNS so a comparison can be made after the sharing is started.
https://www.avsforum.com/forum/45-loc...l#post52628569
WAIT! It has already started and has been going on for years.
SCANNING: 623000000 (us-bcast:39)
LOCK: 8vsb (ss=100 snq=85 seq=100)
TSID: 0x0189
PROGRAM 1: 38.1 SBN
PROGRAM 2: 38.2 Sino TV
PROGRAM 3: 38.3 KTNC
PROGRAM 4: 38.4 Comet
PROGRAM 5: 38.5 NTD
Note the host station does not display it's call letters but KTNC does.
It appears that by entering a starting date and an ending date plus California gives good results and matches what I have seen posted before elsewhere.
SHF
SHF
BTW, LPTVs often do not have unique TSIDs. A default TSID of 1 is used by many of them.
One thing I'd be worried about with channel-sharing is the loss of subchannels. There's still only 19.39Mbps to go around, and if you put two HD .1 channels on one carrier, there's barely room for even one SD .2 subchannel. Stations can still jam them in if they wish, but PQ is likely to suffer noticeably.
Of course, I suppose one of the stations may decide to switch from HD back to SD, and keep their subchannels; that could be OK if their HD channel is one of the smaller networks (like My) that airs mostly reruns. I wouldn't expect major networks like NBC or Telemundo to switch to SD though.
Call Letters appear to not be required but the FCC could change that.
I looked at the TSReader output and did not see a place for the channel shares / sharer's TSID but got the feeling that there are places. Time to reread the ATSC 1.0 spec (And the ATSC 3.0 spec as that is in the FCC's channel sharing agreement document.). Only license holders need TSID or it's replacement but the other sub-channels need not apply.
I was going to say something about "LPTVs often do not have unique TSIDs" but seeing RabbitEars's current list I was unsure.
The sub-channels will need to come to new agreements, that must be in what they signed with the stations. Some may be dropped or have very low rates.
The FCC has said that two 16:9 streams plus four other streams have been demonstrated, About six stations are on the air here right now.
Look at the TSReader output for KCNS - KTNC. There are two 16:9 streams and three (3) 4:3 streams.
The data rate and resolution are what was negotiated, 30%, 25%, 10% and two 12% data rates for the video streams were in the ten (10) minute capture.
Low PQ, you need to look at KAXT with Twelve (12) Video streams. I consider the quality to be adequate for the streams but YMMV.
SHF
This was a very flawed capture, I do not currently have an antenna pointed in the right direction and did not wish to disturb the bookshelf top TERK HDTVa which has to look through trees anyway.
There are currently Twelve (12) Video Streams and one Audio Only Stream.
The Video rates go from ~ 12% down to 5%.
Previously I did watch one stream which had a higher data rate and the programs were fine and similar to what was on another station before I caused it to be taken off by requesting program listings.
SHF
- KATA/50: TSID=1 (BTW, not particularly relevant but interesting: this is a Class A channel, so they did participate in the auction and is one of the few stations nationwide to be going off the air completely.)
- KLEG/44: TSID=1 (Another Class A station, but this one will be moved to RF 28. The following stations are not Class A and their post-repacking fate has yet to be determined)
- KHFD/51: TSID=1
- KVFW/38: TSID=0 (This may change though; they have numerous technical issues and change their configuration often. I'm pretty sure I've seen them use a TSID of 100 at some point.)
- KJJM/34: TSID=1
- K31GL: TSID=0
- KHPK/28: TSID=1
- KODF/26: TSID=1 (Actually on RF 27; virtual channel 26)
- K25FW: TSID=1
- KWDA/30: TSID=0 (Actually on RF 21; virtual channel 30)
- KBOP/20: TSID=7021 (That looks like an assigned number, so I'm thinking the FCC does assign TSIDs for LPTVs but they aren't required to use them? Maybe Trip can clarify)
- KPFW/18: TSID=1
- KXDA/41: TSID=1 (Actually on RF 5 - currently DFW's only digital VHF-Lo station)
SHF
Worst case in DFW is probably KAZD/55 with 7 subchannels, one of which is HD. The HD channel looks OK but some of the SD channels get pretty "blocky" at times.
I believe it. A lot depends on the programming, though. If it's mostly talking heads (e.g., preachers, infomercials) then MPEG/2 can do a pretty decent job compressing the data, and everything will look OK. But put a couple of football (soccer or American) games on the two HDTV stations and something's gonna give, although a statmux (with minimum and maximum data rates as negotiated) can help a little.
- People wanting to sell us new $$$$ equipment.
- Head of the FCC wanting ATSC 3.0, or his boss for the first reason.
- Viewers wanting to see the fleas on the whiskers of an ant. (4096TV)
- Wireless companies wanting the TV channels for wireless.
- Number of Smart Phones sold rising exponentially, see previous reason.
Many sub-channels will accept the poor quality just to stay on the air for their viewers. Note the ever later date for NTSC Analog stations to go off the air. Their viewers cannot afford new sets. I rode past many of their homes away from Silicon Valley on my motorcycle.
SHF
- Trip
Larry
My complete SF Bay Area DTV Station Lists: http://www.larrykenney.com/sfonair.html
Lots of Broadcasting links and information: http://www.larrykenney.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Here in the SF Bay Area we have two HD channels plus one or more SD channels on:
KGO 7
KSBW 8
KNTV 11
KDTV 14
KUVS 19
KRCB 22
KEZT 23
KTSF 26
KSTS 48
KQCA 58
KTFK 64
KFSF 66
Larry
- Trip
N4MJC
RabbitEars
What affect does the repack have on Public Safety Sharing?
Personally I think two 6 MHz guard bands for one 6 MHz public safety channel is outrageous overkill. Couldn't they have designed the public safety radio system to straddle the middle of channels 15-16 and have two 3 MHz guard bands? But, they designed it way back in the analog era, when there were 67 (2-69 minus ch.37) available channels and most were vacant, and it's too late to change it now
- Trip
N4MJC
RabbitEars
https://transition.fcc.gov/pshs/docs...t_July2016.pdf
Ron
I suppose a TV station could bid for a 6-MHz channel just as easily as anyone, but I didn't see anything in the .pdf that says the spectrum has to go to TV. Also, the deadline to start the auction is 2021, so not likely to provide any short-term relief to the upcoming TV spectrum crunch.
Recording free OTA TV for 'time shifting' has been here since 1975. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
https://www.fcc.gov/public-safety/pu...afety-spectrum [ALL Bands]
https://www.fcc.gov/document/fcc-ado...afety-spectrum [700 MHz "D Block" Rules]
https://www.fcc.gov/general/700-mhz-...ety-spectrum-0 [6.25 kHz Narrowband & LTE Wideband Allocations]
FirstNet Status: [Licensed to use 700 MHz "D Block"]
https://www.firstnet.gov
Also the report says stations moving to a new channel have until July 12 to file for a construction permit. I haven't seen any of my local stations or adjacent market stations file yet.
Advertisement |
Thread Tools | |
Posting Rules | |
