Cable box Compatible with AV receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-02-2017, 06:54 PM - Thread Starter
fozzy77's Avatar
Liked: 0
I recently just switched over from Verizon fios to optimum. With Fios, I had it run into my onyko nr646. When I hooked up the same way to the Samsung cable box thats comes with optimum, I do not get any video or sound. I get snow. Could it be possible that the box is not compatible with my setup? I can't understand how one box worked and not the other. any help would be great thanks!
fozzy77 is offline
post #2 of 4 Old 10-02-2017, 07:28 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 48
We need more information. How is the cable box connected to the Onyko?
HDMI Guy is offline
post #3 of 4 Old 10-02-2017, 07:32 PM - Thread Starter
fozzy77's Avatar
Liked: 0
the cable box is connected via hdmi to the hdcp 2.2 cable/sat input.
fozzy77 is offline
post #4 of 4 Old 10-10-2017, 09:16 AM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 48
Did you check the settings on the cable box? Make sure the cable box is set to output over HDMI.
HDMI Guy is offline
Reply HDTV Technical
