Havre de Grace, MD: reception issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-23-2019, 07:14 PM - Thread Starter
rviele's Avatar
Quoted: 228 Post(s)
Liked: 49
why can i get hd fm radio in the woods up here in harford county but not tv reception. tv is fine in the winter with no leaves.
rjv
rviele is offline
post #2 of 15 Old 05-23-2019, 08:32 PM
Super Moderator
DrDon's Avatar
Quoted: 2133 Post(s)
Liked: 4044
https://www.avsforum.com/forum/25-hd...-1st-post.html
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #3 of 15 Old 05-23-2019, 08:34 PM
Calaveras's Avatar
Quoted: 1678 Post(s)
Liked: 378
Leaves absorb signals on high VHF and especially UHF. They're much less problematic on low VHF where FM radio is.
Calaveras is offline
post #4 of 15 Old 05-24-2019, 02:39 AM
holl_ands's Avatar
Quoted: 916 Post(s)
Liked: 489
You should provide your Location (Zipcode + nearest cross-streets or LAT/LONG to nearest minute) so that we can enter into below websites.
Alternatively, YOU can enter your street address into www.tvfool.com and post the results URL (web address at top of Browser) so we can see it.
Do the same at www.fmfool.com but you'll have to first Right-Click on the image and [in Firefox] select "View Background Image" before copying THAT web address into a post.
In IE, posting FMFool Results is more complicated: you can click on "Save Image" and then save that image file to your HDD...and then you'll have figure out HOW to upload THAT image file to your image storage area on this Forum...and then post the Image link into a post....or simply Download and Install Firefox to save a LOT of time!!!!
It would also help if you could list which TV Call Letters....and FM-HD stations you DO (and Do NOT) Receive that you would LIKE to. And describe your TV and FM Antenna(s), if on a Rotator(s) and how signals are distributed incl. Model Number for Preamp or DistroAmp, and how many drops. It's possible/likely that we can suggest how to improve your system.
holl_ands is offline
post #5 of 15 Old 05-24-2019, 07:03 AM
rabbit73's Avatar
Quoted: 822 Post(s)
Liked: 348
His previous thread:
Havre de Grace, MD: Trees and preamp question
https://www.avsforum.com/forum/45-lo...l#post56410118
previous report OK if he still lives at 2211......:
http://www.tvfool.com/?option=com_wr...90381e553d941e
ran it again
http://www.tvfool.com/?option=com_wr...9038f027fd0fdb
This is a report from rabbitears.info that should be a little more accurate:
He might not do that: I don't think he even came back to give us a report after adding a preamp.
FM Report:
http://www.fmfool.com/modeling/tmp/f...a/Radar-FM.png
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #6 of 15 Old 05-24-2019, 11:59 AM
holl_ands's Avatar
Quoted: 916 Post(s)
Liked: 489
Well, RabbitEars Report certainly explains why his TV Reception is so poor [but WHY is it much worse than TVFool Report???] Hence should be using a [UHF-Only] 8-Bay Bowtie of his choice [e.g. CM4228] plus EITHER of the fol. Hi-VHF Yagis....and a VHF/UHF Combiner from Antennas-Direct with a Preamp:
https://www.amazon.com/30-2475-Fring.../dp/B014M0XXES [9-Element Hi-VHF]
https://www.amazon.com/30-2476-Fring.../dp/B07R69QJ3Q [12-Element Hi-VHF]
https://www.amazon.com/Antennas-Dire.../dp/B008PBTPN4
OTOH: Below. is FMFool Report for his street address....the very plentiful "Green Zone" stations "should" be receivable with a TRUE OMNI FM Antenna (such as Stellar Labs Double Hoop), since they are coming from many different directions (most of us are "surrounded" by FM stations). And "Yellow Zone" stations would likely require a Medium Gain FM Antenna on a ROTATOR to receive. For convenience, I would use an RF A/B Switch to select either TRUE-OMNI or Rotating FM Antenna:
https://www.amazon.com/Stellar-Labs-.../dp/B00DHHOZBI [TRUE-OMNI Double Hoop Antenna]
https://www.amazon.com/OUTDOOR-ANTEN.../dp/B00NRHAV2K [4-El Medium Gain FM Antenna]
https://www.amazon.com/Radio-Shack-R.../dp/B000H50L9S [R-S A/B Switch with Remote Control]
https://www.ebay.com/p/RadioShack-21...tch/1000132531 [Ditto]
FM signals should preferably be distributed via a separate Coax and NOT going through a Preamp or DistroAmp, as I discussed in fol. post...this is esp. true for your location, with EXTREMELY strong [and VERY Strong] FM Stations very close to you, which could readily overload a shared TV/FM Preamp/DistroAmp, blocking reception of some weak FM Stations as well as possibly some Hi-VHF Stations:
https://www.avsforum.com/forum/154-h...l#post58025938
post #7 of 15 Old 05-24-2019, 12:15 PM
rabbit73's Avatar
Quoted: 822 Post(s)
Liked: 348
Well, that certainly explains why his TV Reception is so poor....
OTOH: Below. is FMFool Report for his Zipcode (which would be more accurate if he entered his own street address)....
The reports that I gave above DO use his exact address. He gave it in a previous thread.
Originally Posted by rviele View Post
mike- since i don't know to do a tv fool. my physical address is 2211 sherwood lane havre de grace,md 21078. i live out in the country about 5 miles fromthe town of aberdeen. description of the house is a single story rancher in the woods. antenna is a channelmaster with two bent elements. i believe it is a 4428. funny thing is i get every channel i want except for chan 13 yet they are all on the same heading.
Lord Kelvin, 1883
rabbit73 is offline
post #8 of 15 Old 05-24-2019, 12:41 PM
holl_ands's Avatar
Quoted: 916 Post(s)
Liked: 489
I updated rviele's FMFool Report in my earlier post, using his actual street address. Number of "Green Zone" stations is less, but still plentiful...and in many different directions....number of "Yellow Zone" stations is also less with LOTS in "Red Zone", which may or may NOT be receivable with Medium-Gain FM Antenna.
post #9 of 15 Old 05-24-2019, 07:01 PM
tylerSC's Avatar
Quoted: 1141 Post(s)
Liked: 218
Trees may be blocking reception in fringe area. Major DC and Baltimore stations are High VHF and UHF. Also may be on fringe for Philly as well, but I would focus primarily on DC and Baltimore.
tylerSC is online now
post #10 of 15 Old 05-25-2019, 09:35 AM - Thread Starter
rviele's Avatar
Quoted: 228 Post(s)
Liked: 49
ran it again
FM Report:
FYI- i added a antenna direct "juice" and a radio shack distrabution amp also.
rjv
rviele is offline
post #11 of 15 Old 05-25-2019, 05:59 PM
rabbit73's Avatar
Quoted: 822 Post(s)
Liked: 348
rjv
Good; did they improve your reception?
Lord Kelvin, 1883
rabbit73 is offline
post #12 of 15 Old 05-25-2019, 06:40 PM
rabbit73's Avatar
Quoted: 822 Post(s)
Liked: 348
Lots of tall trees at rviele's location.
Lord Kelvin, 1883
rabbit73 is offline
post #13 of 15 Old 05-25-2019, 06:54 PM - Thread Starter
rviele's Avatar
Quoted: 228 Post(s)
Liked: 49
reception is fine in the winter. goes away in the summer. only thing i get now is the baltimore channels wbal channel 11 and wjz channel 13.
rjv
rviele is offline
post #14 of 15 Old 05-25-2019, 07:22 PM
rabbit73's Avatar
Quoted: 822 Post(s)
Liked: 348
rjv
That is to be expected. VHF signals can make it through the trees better than UHF signals.
http://www.hdtvprimer.com/ANTENNAS/siting.html
scroll down to
Trees and VHF-high
Lord Kelvin, 1883
rabbit73 is offline
post #15 of 15 Old 05-26-2019, 10:56 AM
rabbit73's Avatar
Quoted: 822 Post(s)
Liked: 348
At the moment I only see two possible ways to receive VHF and UHF channels all year.
1. Cutting back the trees directly in front of the antenna in the Baltimore path and raising the antenna. There are trees further out in the path, but they might not be as harmful to UHF signals.
2. Putting up a smaller antenna for UHF only on a mast so that it will be above the trees. The UHF signals from that antenna can be combined with the VHF signals from your present antenna.
Can you show us a photo of your present antenna?
There will be channel changes because of UHF Repack by the FCC.
WMAR ABC will move from 38 to 27 during Phase 9, 3/14/2020 to 5/1/2020
https://www.rabbitears.info/market.p...&callsign=WMAR
https://www.rabbitears.info/repackch...=&lss=&status=
https://www.fcc.gov/about-fcc/fcc-in...ition-schedule
WMPT PBS will move from 42 to 21
https://www.rabbitears.info/market.p...n=WMPT#station
WJZ CBS from 13 to 11
https://www.rabbitears.info/market.p...gn=WJZ#station
WBAL NBC from 11 to 12
https://www.rabbitears.info/market.p...n=WBAL#station
WPXW ION from 34 to 35
https://www.rabbitears.info/market.p...n=WPXW#station
WBFF Fox 46 to 26
https://www.rabbitears.info/market.p...n=WBFF#station
ID:	2572072   Click image for larger version
ID:	2572084   Click image for larger version
ID:	2572086   Click image for larger version
Lord Kelvin, 1883
rabbit73 is offline
Reply HDTV Technical
