OTA - Adding Second Amplifier - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Calaveras
post #1 of 4 Old 08-21-2019, 09:11 PM - Thread Starter
RParkerMU's Avatar
In my current setup, I have the antenna on the 2nd Floor attached to an 8 port amplifier which works great for most of the TVs. We have one television which isn't pulling in some of the channels the other TVs get and I'm trying to remedy the situation. Would a 2nd amplifier, used for this TV only be a possible solution?
RParkerMU is offline
post #2 of 4 Old 08-21-2019, 10:34 PM
Calaveras's Avatar
Quoted: 1752 Post(s)
Liked: 403
I'd try swapping a TV that receives all the channels for the one that's having a problem to see if the symptoms are the same. Unless the problem TV has a very long cable compared to all the others it's unlikely another amplifier will do anything.
videobruce likes this.
Calaveras is offline
post #3 of 4 Old 09-18-2019, 03:04 PM
videobruce's Avatar
Quoted: 855 Post(s)
Liked: 334
I wouldn't 'stack' amps.
I would consider swapping that combo you have for a separate DA (not a preamp) and separate splitters also to vary levels to sets further away (to make up for any possible loss).
Also, this unknown 8 port DA, are the outputs the same level? There could be a variance between them on top of longer cable runs.
Recording free OTA TV for 'time shifting' has been here since 1975. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #4 of 4 Old 09-29-2019, 12:38 PM
Quoted: 28 Post(s)
Yes it is in fact possible
If for example that tv has a deaf receiver, another low gain(under 6db)distribution amplifier may recover the lost channels.
old tv guy is offline
Reply HDTV Technical
