Testing the Thor Petit HDMI RF MODULATOR - AVS Forum | Home Theater Discussions And Reviews
 18Likes
  • 4 Post By rabbit73
  • 2 Post By DrDon
  • 2 Post By WDB123
  • 1 Post By WoodieLA
  • 1 Post By Rob-Houston
post #1 of 18 Old 10-12-2019, 04:53 PM - Thread Starter
rabbit73's Avatar
Quoted: 1009 Post(s)
Liked: 448
In the PVI VeCOAX MicroMod thread, WDB123 mentioned the new Thor Petit HDMI RF Modulator.
https://www.avsforum.com/forum/25-hdtv-technical/1656321-pvi-vecoax-micromod-experiences-7.html#post58609642
modulator:
https://thorbroadcast.com/product/pe...modulator.html
manual:
https://thorbroadcast.com/upload/fil...-modulator.pdf
It looked like it would be suitable for two applications I have in mind, so I decided to test it, since it is currently on sale at 40% off.
When it came, I turned it on and it booted up. I was able to set it to ATSC 8VSB channel 3 output with the buttons on the front panel, but I couldn't make a network connection to the modulator with my computer. I got the message that the Local Area Connection doesn't have a valid IP configuration.
The manual says
Notice: Please make sure your computer is in the same IP range as the modulator is.
Well, I really didn't understand what that meant, so I called Thor support and got some excellent help from Stan who showed me how to set the network adapter in my HP laptop.
It turns out that the IP address had to be a Private address also in Class C.
https://geek-university.com/ccna/private-ip-addresses/
https://www.computerhope.com/jargon/i/ip.htm
When I typed 192.168.1.10 in my browser and pressed Enter, I was in the menu after entering default username and password.
In the menu, I saw where I should be able change the Virtual channel number if there was a conflict, but I left it at the default 2.1 for the channel 3 RF output.
Name:	Thor Petit HDMI RF MODULATOR1_1.jpg
ID:	2627166   Click image for larger version
Name:	Thor Petit HDMI RF MODULATOR2_1.jpg
ID:	2627168   Click image for larger version
Name:	Thor Petit HDMI RF MODULATOR3_1.jpg
ID:	2627170   Click image for larger version
Name:	Thor Connection Problem.JPG
ID:	2627172   Click image for larger version
Name:	Thor Network Connection2.jpg
Name:	Thor Modulation Parameters.JPG
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #2 of 18 Old 10-12-2019, 05:31 PM - Thread Starter
rabbit73's Avatar
Liked: 448
Using the Thor Modulator to Add a Channel
This is what the output of the modulator looks like on my SDR dongle with spectrum analyzer software that I finally figured out how to assemble with a lot of help from Pete Higgins.
Inexpensive Software Defined Radio Spectrum Analyzer < $10.00
https://www.highdefforum.com/local-h...r-10-00-a.html
You have to login to see all images on Pete's thread.
One of the applications I have in mind for the Thor Modulator is to add an HD channel to an existing list of OTA channels. This is often necessary when you have a second antenna in a different direction.
A less expensive way would be with an A/B switch or a separate tuner with its output connected to an HDMI input of the TV. But a separate tuner connected to the Thor modulator makes it possible to have all channels combined on one coax. For my test, I added RF 33 converted to RF channel 3, using a Channel Master 7004 converter box. This shows the RF channel 3 picture with the Sony (32") Diagnostics Screen. Note the 2.1 virtual channel and SNR of 34 dB:
The only problem I see with the picture quality is with the digital photo of the screen which shows scanning artifacts. It's in all of my photos of TV screens to a greater or lesser extent. Since I don't see the artifacts when I look directly at the screen, I attribute it to the interaction between the TV screen pixels and the camera digital sensor.
This channel 3 picture has the channel 33 INFO from the 7004:
ID:	2627186   Click image for larger version
ID:	2627188   Click image for larger version
ID:	2627190   Click image for larger version
ID:	2627376   Click image for larger version
Name:	RTL-SDR.COM Dongle2.jpg
Lord Kelvin, 1883
rabbit73 is offline
post #3 of 18 Old 10-12-2019, 06:34 PM - Thread Starter
rabbit73's Avatar
Liked: 448
Using the Thor Modulator to Generate an HD Test Signal on VHF-Low
The second application I have in mind is to try to simulate a VHF-Low channel to see how strong it needs to be to have an SNR greater than 15 dB above the local electrical noise level. Repack has forced some channels to move down to VHF-Low, making it difficult to receive channels that were previously easy to receive.
I don't have a VHF-Low channel in this area, but I previously made some noise measurements and estimated how strong a VHF-Low signal would need to be for reception. I live in a retirement home, and the noise varies from about -10 to -28 dBmV (-59 to -77 dBm) on channel 3, which means that the signal must be at least + 5 to -13 dBmV (-44 to -62 dBm):
The Thor Modulator now makes it possible for me to generate a low power HD digital test signal on channel 3, or any other channel I want, but I already had two folded dipole antennas cut for that channel. The output of the modulator was adjusted to +5 dBmV for the transmitting antenna with 30 dB of external attenuation (20 dB + 10 dB fixed attenuators):
The signal from the receiving antenna (which picked up the test signal AND the ambient noise) for the TV was -10 dBmV (-59 dBm) for an SNR of 15 dB that showed pixelation at the Digital Cliff. Obviously, when I increased the strength of the test signal, the SNR increased and the uncorrected errors dropped to zero for a perfect picture, but I wanted to find the Dropout point. Since the level of the noise is constantly changing, the signal must be strong enough to tolerate the highest noise level for reliable reception.
It was necessary to increase the signal strength to the TV to -8 dBmV (-57 dBm) to make the reception more reliable, because the noise level is very high on VHF-Low at my location:
I used external attenuation, 20 dB fixed + 0-10 adjustable step attenuator on the output of the modulator:
The Thor modulator performs well, the support is excellent, and the price is very reasonable. I could have bought the modulator from another dealer, a similar one on eBay, or from overseas, but good support is very important to me. No, they didn't give it to me, I paid for it when I ordered it, which gave me the freedom to make an unbiased evaluation.
ID:	2627194   Click image for larger version
ID:	2627196   Click image for larger version
ID:	2627538   Click image for larger version
ID:	2627540   Click image for larger version
ID:	2627756   Click image for larger version
Name:	SMA to F Adapter Cable.jpg
Lord Kelvin, 1883
rabbit73 is offline
post #4 of 18 Old 10-13-2019, 07:00 AM
Super Moderator
DrDon's Avatar
Quoted: 2445 Post(s)
Liked: 4786
Great work and thanks for sharing it all!!
Trip in VA and rabbit73 like this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #5 of 18 Old 10-13-2019, 11:46 AM
Quoted: 168 Post(s)
Liked: 63
Good evaluation! HDHomeRun had a dual input tuner years ago(HDHR-US) that could use 2 antennas but it is long obsolete. Needing two antenna inputs is a common problem but no affordable consumer product to address it.
ID:	2627442   Click image for larger version
johnny antenna is offline
post #6 of 18 Old 10-14-2019, 12:21 PM
Liked: 6
Nice review.
WDB123 is offline
post #7 of 18 Old 10-14-2019, 12:24 PM
Liked: 6
I wish Silicon Dust would make a new model with dual antenna inputs, I can use multiple HDHomerun devices but it would be nice to have an all in one unit.
JHBrandt and GaitherBill like this.
WDB123 is offline
post #8 of 18 Old 10-23-2019, 08:39 AM
Liked: 0
Unhappy same issue
Petit did not work on all televisions and the network connection software is defective. now I know that is cheap and you get what you pay for.
Joshua Dixons is offline
post #9 of 18 Old 10-23-2019, 09:57 AM - Thread Starter
rabbit73's Avatar
Liked: 448
It works fine on my Sony TVs, but I did have a problem with the network connection until Stan of Thor support showed me how.
If you are having problems with your Thor Petit Modulator, you should call their support; it has a 5-year warranty. You owe it to them, other users, and yourself to have the problem resolved. If you are still not satisfied, return it, Joshua.
Lord Kelvin, 1883
rabbit73 is offline
post #10 of 18 Old 11-06-2019, 08:36 AM
Rob-Houston's Avatar
Quoted: 145 Post(s)
Liked: 99
Thanks, rabbit73 for the post! I've been looking at this product for 4 or 5 months. Only found one short review.
I've been using a 2 channel ChannelPlus modulator (stereo, composite/SVHS) for over 20 years to modulate a front door camera and a backyard camera onto my local tvs. I just recently upgraded 1 camera from 480p to 1080p. I'm using a TVI-HD to HDMI converter which works well. I need two of these, another TVI-HD converter and a HDMI audio signal
inserter to upgrade everything to 1080p with front door audio.
Again thanks for posting this review.
Rob-Houston is offline
post #11 of 18 Old 11-06-2019, 10:07 AM - Thread Starter
rabbit73's Avatar
Liked: 448
Thanks for the report. I'm glad you found my review helpful.
That sounds like a good solution for HD. Hope it works well for you.
I had been using TV tuners for reception and wondered if my SiliconDust HDHR4-2US Connect Duo tuner would recognize the Thor RF signal. It didn't at first, but I realized I had made a connection error that involved my computer for viewing and then it was OK. This proved to me that the Thor could add a channel to an existing coax that carried RF channels not just for TV tuners but also for HDHR tuners.
Lord Kelvin, 1883
rabbit73 is offline
post #12 of 18 Old 11-14-2019, 10:45 AM
Liked: 1
Joshua, what's your serial number on that unit?
Did you buy from Thor? Did you call their Tech Support?
This looks like a very bitter competitor doing some dishonest slander...
rabbit73 likes this.
WoodieLA is offline
post #13 of 18 Old 12-02-2019, 02:23 PM
videobruce's Avatar
Quoted: 880 Post(s)
Liked: 343
I'm considering this, but not at their $570 'list' price on their web site. rabbit73 pointed me to Amazon that has it for $285.
That vs the one with the 'Silica Tek' name shipped from China on eBay for $237.
Recording free OTA TV for 'time shifting' has been here since 1975. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #14 of 18 Old 01-22-2020, 08:34 AM
Quoted: 145 Post(s)
Liked: 99
Thumbs up
I've had one for more than a month now. It works well.
The only problem I had was that it came shipped with cable as a default. I couldn't program it through the front buttons. I used rabbit73's post to program it quickly. I'm using it to send my security DVR output to broadcast channel 3.1. The output is as good as any broadcast channel! I'll be buying another to send a different source to 3.2.
THANKS RABBIT73!!! You've always provided a lot of good useful posts! Thanks again.
post #15 of 18 Old 01-22-2020, 09:58 AM - Thread Starter
rabbit73's Avatar
Liked: 448
Thank you for your kind words. Glad to hear it's working well for you; I would hate to mislead anyone on expensive equipment.
Lord Kelvin, 1883
rabbit73 is offline
post #16 of 18 Old 01-22-2020, 02:25 PM
videobruce's Avatar
Quoted: 880 Post(s)
Liked: 343
I bought the version that I mentioned on ebay. The seller was very open to communication which I wasn't expecting since this was shipped fro China. In that thread I posted pics of the PCB.
For someone here that has one, how about doing the same? I'd be willing tpo bet they are the same boards based on the location of the ports.
https://www.avsforum.com/forum/25-hd...tit-clone.html
post #17 of 18 Old 04-03-2020, 07:39 AM
Quoted: 145 Post(s)
Liked: 99
Update: The Thor Petit is working flawlessly. I've changed a lot of things. Moved everything from my testing location to my equipment closet. Added a remote control Hdmi switcher to select my security system output or two other Hdmi sources.
All works well.
Just noticed the Thor Petit has gone up $70 where I bought it. $100 or more at other places!
Should have bought a DOZEN!
post #18 of 18 Old 04-03-2020, 04:02 PM - Thread Starter
rabbit73's Avatar
Liked: 448
Thank you for the good news; we need all the good news we can find at this stage of the world's history.
Lord Kelvin, 1883
rabbit73 is offline
Reply HDTV Technical
