TSReader source selection not being saved - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-20-2019, 02:52 PM - Thread Starter
ncsercs's Avatar
Quoted: 178 Post(s)
Liked: 101
Hi,
Installed TSReader 2.8.47.c under Windows 10 x64.
Have 2 Hauppauge HVR-1250 PCIe cards.
Selected source 'Hauppauge Generic ATSC'.
Program works as intended - I exit program - I re-enter program.
Need to select source again. Why is selected source not being saved?
Nick
Every day I beat my own previous record for the number of consecutive
days I've stayed alive. - George Carlin - 1996
ncsercs is offline
post #2 of 5 Old 10-22-2019, 04:03 AM - Thread Starter
ncsercs's Avatar
Quoted: 178 Post(s)
Liked: 101
Not getting much help here.
Am I posting in the wrong forum?
Nick
ncsercs is offline
post #3 of 5 Old 10-22-2019, 06:03 AM
Trip in VA's Avatar
Quoted: 1661 Post(s)
Liked: 703
I can only speak for myself, but I haven't said anything because I don't know. I have my installations set up to do that intentionally, and I don't use Windows 10.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #4 of 5 Old 10-22-2019, 06:23 AM
Super Moderator
DrDon's Avatar
Quoted: 2337 Post(s)
Liked: 4448
I have a similar setup running under Win7x64 and haven't encountered the issue.
Generally speaking, if a program won't save settings, there's either a bug in the program, the installation didn't complete properly or the file/directory the information is stored in is corrupt. You can try a re-install but you may need to dig a bit to tear out all the remnants uninstall leaves behind or - if you can find the directory where the data is stored - delete the files therein. The program should recreate them. Emphasis on "should."
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #5 of 5 Old 10-22-2019, 07:06 PM
Nitewatchman's Avatar
Quoted: 51 Post(s)
Liked: 44
fwiw, I'm using TSR 2.8.55, Win10x64 (1903), just 1 HVR-1265 (uses same generic hauppauge ATSC source), and like Doc don't have that issue, didn't have it with earlier TSreader version either ...
However, I seem to vaguely recall having that issue many moons ago(probably back as far as XP days with a different card), don't remember how I fixed it, probably what doc said regarding re-install ..
Do note that when you open TSreader, if you hold down "Ctrl" when double-clicking on Tsreader Icon on desktop it will allow you to select the source first, before TSR runs ...
Jeff
Last edited by Nitewatchman; 10-22-2019 at 07:09 PM. Reason: fix winver 1903, not 1910
Nitewatchman is offline
Reply HDTV Technical
