Can't receive OTA signals anymore (solved with rescan) - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Jim McC
  • 1 Post By rogersmj
post #1 of 5 Old 11-10-2019, 02:26 PM - Thread Starter
rogersmj's Avatar
Quoted: 57 Post(s)
Liked: 45
A couple weeks ago, my HDTV antenna setup that has worked fine for years just...stopped working. I flipped on my TV a couple weeks ago and none of them can get a signal.
I have an externally-mounted directional antenna, which connects to about 50 feet of coaxial cable that runs down to my basement. There, I have a small signal amplifier, then a junction panel that splits the signal to 5 rooms.
Here's what I've done:
1. Tested coaxial cable with a cable tester I have. It says it's good. I've tested from the antenna all the way through to one of my TVs. As long as the signal amp isn't in the line, the tester says a-OK.
2. Took the junction panel out of the equation and connected antenna -> signal amp -> one of my TVs. Nothing. Tried without the signal amp. Nothing.
3. Replaced signal amplifier with a different/new model. Nothing.
4. Replaced antenna (did this today). Nothing.
I am honestly at a loss here. I'm getting absolutely nothing, no signal whatsoever. Whereas before I had super strong signal, no issues at all. I've replaced or tried bypassing every component involved, and my cable tester says the signal is fine. What else can I do to figure out what the problem is?
rogersmj is offline
post #2 of 5 Old 11-10-2019, 02:35 PM
Jim McC's Avatar
Quoted: 420 Post(s)
Liked: 124
Do a channel re-scan. This same thing happened to me a few weeks ago. It was because they put up a new antenna tower though in Milwaukee.
Tschmidt likes this.
Jim McC is online now
post #3 of 5 Old 11-10-2019, 03:48 PM - Thread Starter
rogersmj's Avatar
Quoted: 57 Post(s)
Liked: 45
I...I think I love you.
Holy crap. That worked. ARRRGH! Thank you!
DrDon likes this.
rogersmj is offline
post #4 of 5 Old 11-12-2019, 12:30 AM
Jim McC's Avatar
Quoted: 420 Post(s)
Liked: 124
You're welcome !
post #5 of 5 Old 11-12-2019, 12:56 PM
BiggAW's Avatar
Quoted: 837 Post(s)
Liked: 253
Most likely repack-related. As long as the repack is going on, re-scan, re-scan, re-scan.
BiggAW is offline
Reply HDTV Technical
