RG6 splitting and wiring for cable TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-28-2019, 09:06 AM - Thread Starter
Liked: 0
I want 4 cable TV connections.I have connected all 4 sockets to a single wire.Total Coaxial Cable length is 70 feet long which is passing inside the walls of my house (It is indoor cable length of my house).I don't know about the outside length of the Cable from where the cable TV provider give me connection from distributor.Problem is that 1st coaxial wall socket shows clear picture as usual but 2nd one is weaker picture than 1st one.Similarly it happens with 3rd and 4th.Am I doing wrong?Which amplifier can works in this scenario?
Second thing is that i have no dish TV or antenna connection, I have cable TV provider who provide me TV Channels. Thanks In Advance.
Sheheryar Moazzam is offline
post #2 of 8 Old 11-28-2019, 09:19 AM
Charles Tintera's Avatar
Quoted: 110 Post(s)
Liked: 32
How are you connecting the cables?
You probably need a one-in, 4-out splitter with an amplifier.
Charles Tintera is offline
post #3 of 8 Old 11-28-2019, 09:50 AM
Ratman's Avatar
Quoted: 2438 Post(s)
Liked: 2279
https://www.amazon.com/Channel-Maste.../dp/B001PI09SE
https://www.amazon.com/Port-DTV-Dist.../dp/B0082ZJNW6
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 8 Old 11-28-2019, 09:57 AM
Otto Pylot's Avatar
Quoted: 3571 Post(s)
Liked: 2570
+1. I have three tv's on one in-coming cable connection, and the pq is flawless on all three (an LCD, an LED, and an OLED).
I never trust an atom, they make up everything.
Otto Pylot is offline
post #5 of 8 Old 11-28-2019, 02:10 PM
tveli's Avatar
Quoted: 92 Post(s)
Liked: 55
Connecting in series with taps as described is appropriate for old school ethernet on coax but not for TV.
For TV you need to wire “home run” from each socket to a splitter.
tveli is offline
post #6 of 8 Old 11-29-2019, 04:00 AM
Quoted: 110 Post(s)
Liked: 32
If that Amazon splitter doesn't do the trick I'd return it for another (other than use I don't know how to test them) and if a replacement won't fix it you've got some other problem.
Sidebar: there must be a technology to measure the quality of an incoming TV signal but I've never seen anything like that.
post #7 of 8 Old 11-29-2019, 07:22 AM
Super Moderator
DrDon's Avatar
Quoted: 2336 Post(s)
Liked: 4445
Thread title edited to be more specific.
Second, when you say "weaker picture," what does that mean?
If this is digital HDTV, you either get a picture or you don't. Clarity isn't affected beyond pixellation from a weak signal.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #8 of 8 Old 11-29-2019, 07:34 AM
Liked: 0
Exactly what i am confused of if its digital either you receive it or not there is nothing in the middle
shobian is offline
Reply HDTV Technical
cable tv , coaxial cable , coaxial wall sockets , multiple connections in single wire
