Anyone recognize this antenna? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By old tv guy
post #1 of 11 Old 01-05-2020, 07:00 PM - Thread Starter
Liked: 0
Does anyone recognize the brand and type of antenna this is? I just got this for free. Person had their roof re-did and decided to get rid of it.
Bob Heinemann is offline
post #2 of 11 Old 01-05-2020, 07:04 PM - Thread Starter
Liked: 0
Sorry, here is a link to the picture of the antenna. I tried having the picture inline on the last post but whatever I did, did not work.
https:// imgur.com/a/HNW2UXg
post #3 of 11 Old 01-05-2020, 07:48 PM
ctdish's Avatar
Quoted: 101 Post(s)
Liked: 44
ctdish is offline
post #4 of 11 Old 01-05-2020, 07:58 PM
rabbit73's Avatar
Quoted: 1009 Post(s)
Liked: 448
https://i.imgur.com/O5NPYHH.png
Name:	Bob HeinemannAVSmysteryAntenna2.jpg
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #5 of 11 Old 01-06-2020, 12:13 AM
Ken H's Avatar
Quoted: 54 Post(s)
Liked: 94
My best guess is that's two yagi antennas, a UHF and VHF, custom joined. It would have taken a bit of engineering to make this work and it probably is for a location that is close to the terrestrial limit of 60 miles from the broadcasting towers.
Maybe.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #6 of 11 Old 01-06-2020, 06:45 AM
Super Moderator
DrDon's Avatar
Quoted: 2440 Post(s)
Liked: 4772
Maybe.
This looks a LOT like the array I had in Kentucky. VHF/UHF combo and a UHF yagi. The combo and the UHF yagi are closer together than I had them. The goal was getting Dayton, OH, stations as Cincinnati stations didn't always remember to "throw the switch" for HD (circa 2002). Both sets of towers were in the same direction from my KY house.
Yeah, it took some effort to make that work. Lots of trips up and down stairs and ladders adjusting the UHF Yagi until I had it in the right position. Good times.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #7 of 11 Old 01-06-2020, 06:59 PM - Thread Starter
Liked: 0
Little more info.
I picked this up for free. Person had their roof replaced and had the roofers take this antenna down since he doesn't use it anymore. He was about 20 miles from the DC broadcast towers. He said this is about 20 years old.
The VHF array (top antenna) has an 11 foot boom length. One of the elements towards the back broke off. I suspect it is a VHF Lo element. I hooked this antenna up at ground level to test it and it performed very well. Surprising to me was that it picked up both VHF and UHF stations. I'm about 18 miles from DC towers and 30 miles from Baltimore towers. Got both, with a strong signal. Made me believe in the adage "metal in the air".
I tested the UHF Antenna (bottom antenna). I received channels from this as well, but this appeared to be highly directional.
I also scored a Alliance U-100 rotor with control box. A quick bench test showed that to be operational as well. It was fun to breathe life back into that and hear that ker-chunk sound from the control box. I never played with a rotor before, so it was quite the delight.
post #8 of 11 Old 01-07-2020, 06:32 AM
Super Moderator
DrDon's Avatar
Liked: 4772
That's because it's a combo, not a VHF Only. It SHOULD pick up both.
DrDon is offline
post #9 of 11 Old 01-07-2020, 06:12 PM
Quoted: 29 Post(s)
The lower antenna may be 20 or so years old but the big vhf/uhf combo appears to be a much older Jerrold antenna built back when they still used round aluminum booms and that type of boom support.
They were built MUCH better than today's antennas so they could easily last 40 or more years.
videobruce likes this.
old tv guy is offline
post #10 of 11 Old 02-25-2020, 11:55 AM
Liked: 0
Denny's antennas HD Stacker
This looks like a Denny's antennas HD Stacker. You can find it on his website,
zortan is offline
post #11 of 11 Old 02-26-2020, 09:26 AM
tshaff09's Avatar
Looks like a denny's stacker, except the stacker is not nearly that long.
tshaff09 is offline
Reply HDTV Technical
