Lost OTA signal after static from touching coax connector - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tylerSC
post #1 of 8 Old 03-08-2020, 07:43 PM - Thread Starter
Liked: 0
I was getting 51 channels until a static charge from my finger hit the coax connector. Lost all channels, tried re-scan, reset and new antenna. Could I have caused a short to the RF connector?
Jerry Mayes is offline
post #2 of 8 Old 03-08-2020, 09:46 PM
Calaveras's Avatar
Quoted: 1798 Post(s)
Liked: 427
Sounds like you may have blown out the tuner in whatever device you were using to receive your stations. Do you have another tuner to try?
Calaveras is offline
post #3 of 8 Old 03-09-2020, 06:33 AM
Super Moderator
DrDon's Avatar
Quoted: 2445 Post(s)
Liked: 4786
Title edited to make more specific. Might also help to know just what device we're talking about. A TV? TiVo? Some other tuner? Make and model numbers always help.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4 of 8 Old 03-09-2020, 09:46 AM
tylerSC's Avatar
Quoted: 1439 Post(s)
Liked: 272
May need to replace the coax cable. I have lost signal due to power surges and had to replace the cable and all was good. Also make sure the tuner wasn't zapped or an amplifier may have failed.
DrDon likes this.
tylerSC is offline
post #5 of 8 Old 03-09-2020, 12:27 PM
Ratman's Avatar
Quoted: 2590 Post(s)
Liked: 2424
The way I read the opening post, the OP may be using an indoor antenna as he stated "... tried re-scan, reset and new antenna". So, that eliminates the coax cable itself or an amplifier if it's a powered antenna.
Also, not saying you're wrong, but I find it unlikely that a static discharge would harm copper and steel to create an open or short in the coax. It's not the same as a nasty power surge.
IMO, as stated, the tuner probably got zapped.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #6 of 8 Old 03-09-2020, 04:39 PM
Channel99's Avatar
Quoted: 175 Post(s)
Liked: 91
This might be a bit on the obvious side - but could the scan options have changed to search only for cable channels?
Channel99 is offline
post #7 of 8 Old 03-22-2020, 08:29 AM
douglasturci's Avatar
Liked: 0
The solutions is to change the tuner since this is the one that responds to that OTA, in many devices that tuner is usually damaged. Try it
douglasturci is offline
post #8 of 8 Old 03-22-2020, 10:54 AM
Ratman's Avatar
Liked: 2424
May be an option if it's an external/standalone tuner. If it's a TV, that may not be an easy remedy.
Ratman is offline
Reply HDTV Technical
