Antenna cable routing: what sealant to use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-17-2020, 12:23 PM - Thread Starter
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
MY plan is to install an antenna in the ground on a 4x4 post, about 3' from the side of my house. The coax would enter a PVC conduit 90 degree elbow at the bottom of the post, then go 3' underground thru PVC conduit, before going straight thru the concrete block foundation. I will use one of those small plastic coax bushings where it enters the block wall. My questions:
1) The top of elbow will probably be above ground. What should I use to seal around the coax cable in the conduit to keep out rain, etc. ?
2) And the same question for the other end of the underground coax before it enters the block wall. Where the coax exits the conduit underground, I assume I should seal the gap between the coax and conduit ?
Thanks for any advice.
Jim McC is offline
post #2 of 7 Old 05-17-2020, 05:09 PM
Channel99's Avatar
Quoted: 182 Post(s)
Liked: 114
This will work. It is a very sticky putty-like material that can be pushed in place around the cable and will stay flexible:
https://www.summitsource.com/Bishop-...32-P10086.aspx
Channel99 is online now
post #3 of 7 Old 05-17-2020, 10:46 PM - Thread Starter
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Thanks. Does anyone have advice on finding the wood framing behind my soffit's fascia board ? My stud finder is not working properly, apparently because the fascia is covered by aluminum trim.
Jim McC is offline
post #4 of 7 Old 05-18-2020, 12:53 PM
gbynum's Avatar
Quoted: 110 Post(s)
Liked: 42
I don't know how thick your fascia is, but I've had pretty good luck with a small coin-shaped magnet on a string. Once you find 2 or 3, you can determine the spacing and do pretty well.
gbynum is offline
post #5 of 7 Old 05-18-2020, 07:38 PM - Thread Starter
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Thanks. So you're method is to find the nails thru the fascia board into the framing members behind it ? The fascia board is 3/4" thick. My house is a ranch built in 1975. Would the framing behind the fascia more likely be 16" or 24" apart ?
Jim McC is offline
post #6 of 7 Old 05-19-2020, 07:24 AM
gbynum's Avatar
Quoted: 110 Post(s)
Liked: 42
Yes, find the nails. As to 16" or 24", yes https://www.avsforum.com/forum/images/smilies/smile.gif.
As to which, no way to know. Here in the southeast, 16" 2x4 was almost all of individual home construction then. The only place I saw (from the street, I'm not a builder) 24" anything was ceiling joists and rafters. Today is different with 2x6 used for thicker insulation sometimes ... but spray foam gets those insulation levels in 2x4 construction.
gbynum is offline
post #7 of 7 Old 05-19-2020, 02:51 PM - Thread Starter
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Thanks. I will see what I can figure out. If I have to, I can remove one of the aluminum trim pieces and reinstall it. The problem I see is only one of the 12" standoff bracket holes will be able to be screwed into the framing.
Jim McC is offline
Reply HDTV Technical
