Biloxi, MS: Best UHF rf amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-03-2020, 03:59 PM - Thread Starter
nondropframe's Avatar
I'm looking for the best UHF antenna amp for the price. The rf channels I need to amplify are 16, 25, and 32. There are no VHF channels. Need to have power injected. Amp will be at the outdoor antenna (I assume that's the best choice), so it needs to be rated for outdoor use.
nondropframe is offline
post #2 of 6 Old 06-03-2020, 06:30 PM
Calaveras's Avatar
Quoted: 1966 Post(s)
Liked: 486
The answer to this depends on what your requirements are. We'd need to see your Rabbitears report and some details about your antenna system; ie, antenna, coax length, splitter, etc.
Calaveras is offline
post #3 of 6 Old 06-03-2020, 09:49 PM - Thread Starter
Here's the Rabbitears report
https://www.rabbitears.info/searchma...study_id=97622
Antenna is a Antennas Direct DB2E Multidirectional Bowtie UHF Dtv Antenna
The cable run is 53ft. rg6.
No splitters.
Only a lightning arrester.
Anything else?
post #4 of 6 Old 06-04-2020, 05:34 AM
Super Moderator
DrDon's Avatar
Quoted: 2564 Post(s)
Liked: 5025
Anything else?
https://www.avsforum.com/forum/25-hd...-1st-post.html
We put that thread together to save the time of asking the same questions over and over of every member with a question about OTA issues. Start with the information from that thread and it'll really speed things along.
Doc
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #5 of 6 Old 06-04-2020, 05:39 AM
rabbit73's Avatar
Quoted: 1091 Post(s)
Liked: 482
No splitters.
Anything else?
Thank you for the signal report from Gulfport. The channels that you want are very strong and shouldn't need any amplification unless the antenna isn't in the clear. Why do you think you need a preamp, trees to the north?
The Antennas Direct Juice preamp would match your specs. It can tolerate overload, but your tuner might not.
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #6 of 6 Old 06-04-2020, 07:07 AM
Calaveras's Avatar
Liked: 486
The stations you want are extremely strong and don't need a preamp. It may cause overload. If you're having trouble with those stations then we need to look into that further.
I looked at the terrain plot for all those New Orleans stations. The curvature of the Earth makes that a tropo path. Such a path will never be reliable no matter what antenna is used.
Reply HDTV Technical
