Hughes HTL-HD! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #61 of 1251 Old 11-05-2003, 01:00 PM
bhambrad's Avatar
Quoted: 45 Post(s)
Originally posted by blackmax2k1
So picking up OTA stations works just as well as the HD300?
yes - the same for me.
bhambrad is offline
post #62 of 1251 Old 11-05-2003, 01:01 PM
HD_JUNKIE's Avatar
No format button on the remote? Can't even switch modes from 1080i to 480i?
No OTA signal meter? I assume youa re trying to tune OTA ATSC stations? No meter would really stink!! Its very helpful when setting up your antenna....
The skrink feature you're referring to is also on the HD300. I assume you don't have an HD300 to compare it to??
Any chance of you taking a photo of the front, back and remote and posting here?
If you would please go into the MENU then go to SYSTEM > SYSTEM INFO > SYSTEM UPGRADE and tell us the software version.
Originally posted by bhambrad
This box is aesome with the exception of the RF remote and being able to change the format from 1080i to 720p from the remote - and not looking anywhere near as cool as the sony does. One feature that is included is the new Shrik feature that you can shrink channels like ESPN HD and it fits into the 4x3 instead of the stretch mode. The only complaint I have is not being able to see a OTA signal meter. I am on the phone with support to see why.
HD_JUNKIE is offline
post #63 of 1251 Old 11-05-2003, 01:46 PM
bhambrad's Avatar
Quoted: 45 Post(s)
I have the sony hd300 and no format button.
The signal meter is unknown at this point
yes the shrink feature is there
As iposted above it is the same software info but it was posted on 8/20/03 instead of 8/22/03.
bhambrad is offline
post #64 of 1251 Old 11-05-2003, 01:51 PM
beaudot's Avatar
How do you switch from 1080 to 720?
beaudot is offline
post #65 of 1251 Old 11-05-2003, 02:04 PM
blackmax2k1's Avatar
So bhambrad, do you think it's worth stepping down from the HD300 to the
HTL-HD for $200?
blackmax2k1 is offline
post #66 of 1251 Old 11-05-2003, 02:11 PM
sunlover's Avatar
Does this new hughes box have the same guide "look" as all previous hughes models..ie green for sports, red for movies, etc??
Is pageing up/down in the guide as fast as prior hughes models?
Do you have aspect control on a SD ota signal, to expand picture to fill entire screen?? Thanks in advance.
sunlover is offline
post #67 of 1251 Old 11-05-2003, 02:12 PM
budiman's Avatar
bhambrad:
Does it have a DVI-D port or RGB port on the back? I have a CRT FP PJ, so only accepts RGB.
Ciao.
Muljadi Budiman
budiman is offline
post #68 of 1251 Old 11-05-2003, 02:14 PM
This is not like the older Hughes boxes. It's based off of the last gen LG/Sony boxes.
post #69 of 1251 Old 11-05-2003, 02:28 PM
Originally posted by budiman
bhambrad:
Only DVI-D.
post #70 of 1251 Old 11-05-2003, 02:32 PM
Uther's Avatar
Quoted: 29 Post(s)
So, in your first post you indicated you can change AR from the remote, just not the HD format? Just clarifying.
Is this something that can be done from the HD300 remote? If so, I would not be surprised if the remote code works as long as you have a programmable remote and someone can post the code.
Uther is offline
post #71 of 1251 Old 11-05-2003, 03:03 PM
AlxStevens's Avatar
Only DVI-D.
This is actually not the case, there is a switchable RBG/DVI-D output on the back, as well as S-Video and composite. Only optical audio, no coax.
AS
AlxStevens is offline
post #72 of 1251 Old 11-05-2003, 03:14 PM
bhambrad's Avatar
Quoted: 45 Post(s)
HTL-HD for $200?
I have both. I have one downstairs and one in my office. I really don't care for the copper color of the hughes so I would pay more for the silver sony with the format button and the rf remote but I am anal about liking silver stuff. My tv is silver my dvd player is silver and all my stuff downstairs is sony - last time i opted for the zenith 520 because it was cheaper and loved it - now this is replacing it. Hope this helps.
bhambrad is offline
post #73 of 1251 Old 11-05-2003, 03:17 PM
bhambrad's Avatar
Quoted: 45 Post(s)
The format button on the far right on the front of the box.
bhambrad is offline
post #74 of 1251 Old 11-05-2003, 03:24 PM
bhambrad's Avatar
Quoted: 45 Post(s)
Does anyone else have one yet? When the input button on the remote is pressed - does it show the signal meter like it is supposed to?
bhambrad is offline
post #75 of 1251 Old 11-05-2003, 03:37 PM
beaudot's Avatar
How does the SD upconversion look? Is it using the same scaling/deinterlacing as the HD300? What output formats does it have? 480I 480P 720P 1080i? Is there a native passthru option?
beaudot is offline
post #76 of 1251 Old 11-05-2003, 04:26 PM
HD_JUNKIE's Avatar
There's no SIGNAL button on the remote or the front faceplate? I cannot believe they would omit that feature of all things.....
post #77 of 1251 Old 11-05-2003, 05:18 PM
Uther's Avatar
Quoted: 29 Post(s)
HD_JUNKIE, Brad said that the signal button is on the right side of the faceplate.
Uther is offline
post #78 of 1251 Old 11-05-2003, 05:44 PM
bhambrad's Avatar
Quoted: 45 Post(s)
no the signal button on the remote is supposed to be the "input" button on the remote but it doesn't work. If someone else gets this box and it doesn't work , Hughes is going to report it to engineering.
bhambrad is offline
post #79 of 1251 Old 11-05-2003, 05:46 PM
bhambrad's Avatar
Quoted: 45 Post(s)
Oh yeah comes with a DVI Cable
bhambrad is offline
post #80 of 1251 Old 11-05-2003, 05:55 PM
SJinBoise's Avatar
Does it have simultaneous output on the s-video jack?
SJinBoise is offline
post #81 of 1251 Old 11-05-2003, 06:31 PM
robert123's Avatar
The owner's manual can be dowloaded here (it's big though ~35MB):
http://us.lgservice.com/
Click on 'Owner's Manuals', then select 'Set Top Box' and search for 'HTL-HD'.
Robert
robert123 is offline
post #82 of 1251 Old 11-05-2003, 06:35 PM
HD_JUNKIE's Avatar
To me it does not make sense that the INPUT button would be the signal button. On the HD300 I beleive the INPUT button is designed to change inputs on your TV assuming you have your TV preprogrammed into the remote.
What does it say in the instruction manual?
Did you try pressing every button on the remote?
What are the other buttons on the front panel. It looks like there's a few from the tiny picture I have from Circuit City's website.
It would be excellent of you if you could post pictures of this box, front, back and remote. I know it might be a pain, but it would be real helpful.
post #83 of 1251 Old 11-05-2003, 07:22 PM
SJinBoise's Avatar
Robert
Thanks for the link. According to the manual, it DOES have simultaneous output, closed captioning, and the advanced program guide. (?!)
post #84 of 1251 Old 11-05-2003, 07:28 PM
jaypb's Avatar
But no one line guide ?!?! For me, that's a feature of the Hughes boxes I've come to enjoy....especially the APG versions that have it. :(
jaypb is offline
post #85 of 1251 Old 11-05-2003, 07:34 PM
It also says it has RGB and DVI. It does NOT have a "signal" button. It also does not have a "format" button on the remote. Only a "ratio" button for changing picture aspect ratio. The "format" button is only on the box itself.
Other than that it's exactly the same as my Sony HD300. I can live without the "format" button cause my TV doesn't do 720 only 1080. RF I can live without also. It definitely does not look as nice as the Sony. It has that ugly Hughes style to it like the Tivo box.
post #86 of 1251 Old 11-05-2003, 07:41 PM
chiliman's Avatar
Robert
Well that settles it. The manual is identical to the HD300 I have. I haven't decided if I like it over the E86 (300 gets less OTA channels but has superior SD material). But if I keep I do decide to go with it the 300 is going back and I'm saving $200!! The only difference is no RF remote
Randy
chiliman is offline
post #87 of 1251 Old 11-05-2003, 08:13 PM
I don't like the channel and volume buttons on the Hughes either compared to the Sony remote. The Sony remote is the best out of the group.
post #88 of 1251 Old 11-05-2003, 08:32 PM
Uther's Avatar
Quoted: 29 Post(s)
Do you really even need the signal button? Doesn't the box convert to whatever signal you choose for HD material (e.g., if it is broadcast in 1080i, the box will convert to 720p if that is what you have chosen)?
Uther is offline
post #89 of 1251 Old 11-05-2003, 08:48 PM
Uther's Avatar
Quoted: 29 Post(s)
One other quesiton, does anyone know if this receiver is HDCP compliant??
Uther is offline
post #90 of 1251 Old 11-05-2003, 08:55 PM
Uther's Avatar
Quoted: 29 Post(s)
Doh, just answered my own question (manual finally finished downloading), it IS HDCP compliant.
Uther is offline
Closed Thread HDTV Technical
