The Official AVS Antenna and Related Hardware Topic! - Page 601 - AVS Forum | Home Theater Discussions And Reviews
 414Likes
post #18001 of 18323 Old 01-21-2020, 12:12 PM
labjr's Avatar
I'm about 24 miles west of Needham MA where most of the Boston stations broadcast from. But there's a hill about a mile from here and trees etc. I've never tried OTA reception from my location. I probably won't be trying to set up an antenna here for some time yet. I have helped a few friends set up for OTA reception in various locations locally. There always seems to be a problem with pixelation, which IMO, is the biggest problem that discourages more people from OTA reception.
To me ATSC 3.0 is attractive because the signal is supposed to be more immune to multi-path interference and also the ability to stream it throughout the building using the right tuner box.
labjr is offline
post #18002 of 18323 Old 01-21-2020, 02:56 PM
Calaveras's Avatar
Quoted: 1798 Post(s)
Liked: 427
Originally Posted by rabbit73 View Post
The current designs would need to be modified to give more gain at the low end of UHF. The gain curve of a UHF antenna is not constant at all frequencies; it rises as the frequency increases. The max gain of the current designs is above channel 36. If you make the antenna a little larger, this will move the peak of the gain curve down in frequency.
If the gain curves for these UHF antennas are referenced at each frequency along the curve to a dipole or an isotropic source, then the curves are misleading. A channel 14 dipole will generate 3.3 dB more signal than a channel 51 dipole in the same RF field because of the dipole factor. I don't know how the models handle the dipole factor. The dipole factor is much of the reason that the high VHF transmitters are so much lower power than UHF transmitters.
Calaveras is offline
post #18003 of 18323 Old 01-21-2020, 03:06 PM
Calaveras's Avatar
Liked: 427
Originally Posted by Steve347 View Post
I guess that this brings up another question... What kind of performance increase could be expected if the design was optimized for 14-36 vs. 14-51?
If the overall antenna size is kept the same then optimizing will only produce a small gain increase. In order to get a significant gain increase the antenna will have to be much larger.
post #18004 of 18323 Old 01-21-2020, 03:43 PM
rabbit73's Avatar
Quoted: 1009 Post(s)
Liked: 448
Computer models give results in dBi, to compare the predicted performance of different designs.
Yes, but an antenna designed for the UHF band is usually modeled at a frequency at the center of the band. This will make the antenna less efficient at channel 14 which is away from the design frequency, causing the gain curve to fall at the low end. The gain curve will rise above the design frequency because the elements are longer than a halfwave.
I'm not sure how the computer models deal with the antenna factor. I don't do modeling and prefer to make performance measurements of antennas.
My guess is that the antenna factor only needs to be considered when using the field strength in dBuV/m just before the signal touches the antenna (as in converting dBuV/m to dBm). The model includes the antenna factor because the antenna size is scaled to frequency and includes the feedpoint where signal power is measured.
dBuV/m to dBm calculator
http://www.g4axx.com/
click on Downloads
click on dBuV to dBm calculator (xlsx 20kB)
Trip in VA uses a conversion factor of 130 for dBuV/m to dBm for his rabbitears.info Signal Search Map reports for UHF signals. For VHF signals, he adds a negative correction factor (to field strength; signal margin remains unchanged IIRC) to allow for the higher noise levels on VHF-High and VHF-Low. This makes them listed a little lower in the report.
This document shows that the FCC Planning Factors include the Antenna Factors for UHF, VHF-High, and VHF-Low. It also allows a higher noise figure for a VHF tuner, but it does not allow for the higher ambient noise level on VHF, which is why Trip added a correction factor to his signal reports that use the FCC TVStudy software.
Federal Communications Commission FCC 05-199
Report To Congress
The Satellite Home Viewer Extension And Reauthorization Act Of 2004
Study Of Digital Television Field Strength Standards And Testing Procedures
https://transition.fcc.gov/oet/info/...FCC-05-199.pdf
Name:	dBuVperm to dBm at 473 MHz3.jpg
ID:	2674228   Click image for larger version
Name:	dBuVperm to dBm at 695 MHz3.jpg
ID:	2674230   Click image for larger version
Name:	FCC Planning Factor Chart4.jpg
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #18005 of 18323 Old 01-21-2020, 03:53 PM
rabbit73's Avatar
Liked: 448
Yes, when an antenna design is scaled to a new frequency, ALL dimensions are multiplied by the same scaling factor, so the overall size will change.
https://www.digitalhome.ca/forum/3098227-post10.html
https://www.digitalhome.ca/forum/3098283-post12.html
Lord Kelvin, 1883
rabbit73 is offline
post #18006 of 18323 Old 01-23-2020, 02:23 PM
DeweyNC's Avatar
Quoted: 21 Post(s)
Liked: 4
The forums new format is gonna be a BIG change.
https://www.avsforum.com/forum/43-fo...l#post59143586
DeweyNC is offline
post #18007 of 18323 Old 01-24-2020, 06:48 AM
Calaveras's Avatar
Liked: 427
Obviously that's true but that's not what I meant. There is a tradeoff for gain and frequency coverage for a given sized antenna. You can get a little more gain for a narrowband antenna over a wideband antenna when both are the same size. If you're reducing the frequency coverage from channels 14-51 to 14-36 but not changing the size, the 14-36 optimized antenna should have a little more gain. As always though, for the 14-36 antenna to have significantly more gain, it'll need to be much larger.
post #18008 of 18323 Old 01-24-2020, 07:14 AM
rabbit73's Avatar
Liked: 448
I agree.
Lord Kelvin, 1883
rabbit73 is offline
post #18009 of 18323 Old 01-24-2020, 07:24 AM
Calaveras's Avatar
Liked: 427
They could just as well use dBd. I don't like dBi for the same reason most of the ham radio world doesn't use it. It's an antenna that can't be built and inflates the gain of real antennas.
After thinking about this for a couple of days I don't think this is true. I don't think the models consider the dipole factor at all. They simple model a configuration of pieces of metal over a frequency range in frequency steps.
click on Downloads
This conversion makes sense. Start with a 1 meter long antenna in an RF field of a certain strength (dBuV/m) and convert that to the actual signal the antenna will generate at its terminals.
post #18010 of 18323 Old 01-24-2020, 07:43 AM
rabbit73's Avatar
Liked: 448
Yeah, that's why QST doesn't allow gain figures in antenna ads.
I understand your point.
I couldn't find the link to the last converter I used; I like this one better.
Lord Kelvin, 1883
rabbit73 is offline
post #18011 of 18323 Old 01-28-2020, 08:55 AM
Primestar31's Avatar
Quoted: 219 Post(s)
Liked: 113
The newest Channel Master LTE filter is listed as now going down to 600Mhz, passing 5 - 599Mhz. Which means right about at channel RF36. Not sure if it'll kill channel 36 or not, and I actually have a channel using that. I just ordered one at $19 and free shipping. Not sure how you can really TELL if LTE is affecting your antenna, but $19 isn't that bad to try it out.
https://www.channelmaster.com/TV_Ant..._p/cm-3201.htm
Primestar31 is offline
post #18012 of 18323 Old 01-28-2020, 10:02 AM
rabbit73's Avatar
Liked: 448
Something is not right. If they actually did change the filter, they should have changed the model number. They didn't change the model number of the 7777 preamp when they changed the design.
The description does say
Electrical Specifications
Frequencies Pass 5 - 599 MHz
Frequencies Block 600 - 2000 MHz
But if you look at the Product Sheet download it says:
LTE FilterSpecifications
Frequencies Pass: 5 - 699 MHz
Frequencies Block: 700 - 2000 MHz
That is correct for the 14-51 band.
If it really is 5-599, that would mess up 35 and 36.
35: 596 to 602
36: 602 to 608.
My test of the filter I bought:
If the CM-3201 filter has been redesigned to attenuate transmitters above channel 36, I would need to test it as I did previously. Just trying it out to see if it helps to improve reception isn't sufficient; it's not conclusive.
Lord Kelvin, 1883
rabbit73 is offline
post #18013 of 18323 Old 01-31-2020, 11:50 AM
Quoted: 219 Post(s)
Liked: 113
I received this in the mail today, a couple hours ago. It's the new version as pictured on the page above. Unfortunately, I can't install it right now. My antenna is on a 25' mast above my garage, and I have to get on the roof to install this. The roof still has 6" of snow and ice on it, and no way I'm going to try getting on that anytime soon. I can't take a fall from that height anymore. I do have a channel on RF36, WAQP, and LightTv is on .3, and we watch that. So, not sure if this filter will hurt my reception of that channel. I'll know once I can install it after a good melt.
Does anybody know what sort of interference, LTE can cause to signal levels? Not sure if I'm even having any issues I could attribute to possible LTE.
post #18014 of 18323 Old 01-31-2020, 01:04 PM
lifespeed's Avatar
Quoted: 281 Post(s)
Liked: 39
The impedance match would improve significantly, which is as important as gain and compounds the improvement.
Lifespeed
91XG Yagi for San Francisco, DB4e bowtie for Fremont
SiliconDust HDHR4-2US network tuners, one per antenna
Media server PC running Emby
Rabbit Ears reception report
lifespeed is offline
post #18015 of 18323 Old 01-31-2020, 01:23 PM
rabbit73's Avatar
Liked: 448
If you have LTE interference, it is most likely to interfere with reception of UHF channels. It would probably affect signal quality rather than signal strength.
I see Light TV listed as a subchannel of WAQP:
https://www.rabbitears.info/market.p...&callsign=WAQP
This is a rabbitears.info report based on your location in 2015; I don't know if you have moved since then:
https://www.rabbitears.info/searchma...study_id=51721
Ideally, the filter should be inserted between the antenna and the preamp, but that wouldn't be safe to do now. You could try inserting it between the preamp power inserter and the tuner input as a test.
I'm still not convinced that CM has modified the filter for 14-36 reception.
Lord Kelvin, 1883
rabbit73 is offline
post #18016 of 18323 Old 01-31-2020, 01:38 PM
Quoted: 219 Post(s)
Liked: 113
We did move 2~ miles South-East of our old house in the woods, and signal levels are a bit better than the old house in the middle of the woods. I'm still using a Y10-7-13 antenna for WJRT-12 which is RF12, and a HDB91x for all my UHF channels. They are on a 25' mast pipe setup.
The Y10-7-13 goes through a MCM Electronics FM filter, then into the VHF side of a Radio Shack UVSJ. The HDB91x is pointed at WEYI-25, which is basically the center of the arc for UHF towers, and almost directly in a line beyond the low powered stations WFFC-LD & WFKB-LD. That goes into a Kitztech KT200-Coax preamp, then into the power passing UHF side of the Radio Shack UVSJ. Then Rg-6 quad-shield coax to my Tivo and tv set.
I get all my channels pretty solid, including the two low powered ones WFFC-LD & WFKB-LD, which are 32~ miles from me, as the crow flies.
post #18017 of 18323 Old 01-31-2020, 02:45 PM
Calaveras's Avatar
Liked: 427
That's possible but it's not a guarantee. The SWR has to be pretty bad to impact the gain much. An SWR of 2.0 has a mismatch loss of 0.5 dB, SWR of 2.7 has a mismatch loss of 1.0 dB and an SWR of 3.0 has a mismatch loss of 1.25 dB. Above 3.0 the mismatch loss climbs rapidly. It's a pretty bad antenna that has an SWR above 3.0. An SWR improvement of 3.0 to 2.0 only picks up 0.75 dB.
post #18018 of 18323 Old 01-31-2020, 03:07 PM
lifespeed's Avatar
Quoted: 281 Post(s)
Liked: 39
Plus the interaction with the SWR of the tuner, plus a slight improvement in gain. While 0.75dB is a small number, in linear power that's nearly 20% more. Let's say the antenna re-tuning nets you better match and better gain to the tune of 1.5dB total, probably a reasonable estimate. That's 41% more power to the tuner, something that is easily noticeable by a viewer with a marginal signal strength/quality station.
It won't be a miracle, but it could easily be noticed. The only obstacle is the manufacturer's applying their cost/benefit analysis. Are people still buying their old-design antennae, or will the first one to market with an optimized design gain market share from savvy buyers? Over in the UK they've already designed a nice Yagi called XB16A that coincides with our new UHF band. I'll probably replace my 91XG with one of these when I feel the need to bring the mast down for rework to add VHF reception for the SF bay area repack and ATSC 3.0 Silicondust tuners. Which don't exist yet.
Lifespeed
post #18019 of 18323 Old 01-31-2020, 03:39 PM
rabbit73's Avatar
Liked: 448
Thank you for the coordinates for your better OTA location. Here is a new report:
https://www.rabbitears.info/searchma...study_id=51782
and here is a new FM report, but I don't know how accurate it is:
http://www.fmfool.com/modeling/tmp/3...3/Radar-FM.png
Lord Kelvin, 1883
rabbit73 is offline
post #18020 of 18323 Old 02-01-2020, 12:00 AM
mattdp's Avatar
Quoted: 115 Post(s)
Liked: 62
LTE interference is an issue, obviously, because the 600, 700 and 800 MHz cell bands used to be part of the UHF TV spectrum. Hence, antennas and amplifiers do a good job at receiving them.
When you're close enough to a cell tower (1-2 mi or less), the level is strong enough that it can overload the amplification in your system (particularly high gain preamps).
In mild cases, it degrades the signal-to-noise ratio, but not enough to cause breakups.
In moderate cases, you'll notice random dropouts.
In severe cases, it will completely wipe out reception of a channel, as the signal-to-noise ratio drops completely below the decoding threshold.
The easiest way to tell (save for a spectrum analyzer) is simply to install an LTE filter before the first amplification stage and see what difference it makes, if any. Usually in the presence of LTE overload, the signal meter readings on a TV will jump around wildly, whereas you'd normally see very slight changes from moment to moment.
One example case from my files: 45 mi from both full-power and 15kW LP stations, running a preamp and UHF/VHF-Hi yagi's on the roof - LTE tower 75 degrees off-axis, probably 1 mi away. Without an LTE filter, full-power's all scanned in strong (but not stable) level, some LPs were exhibiting constant breakups, some didn't scan in. Installed LTE filter, SNRs improved across the board - full-power's are stable, all LPs scanned in with none breaking up, including a weaker station that had previously not scanned sitting at a stable 17dB SNR.
Not a universal rule, but I've observed LTE interference worsen in the evening, presumably as the network is more congested.
mattdp is offline
post #18021 of 18323 Old 02-01-2020, 05:00 AM
Quoted: 219 Post(s)
Liked: 113
I'm about 2.5 miles away from my closest LTE tower, and I have to aim nearly right through it on a bearing to get all my UHF stations. I don't get any wild signal swings or dips, but on my couple of lower power stations, (WFFC & WFKB) I get slight audio dips frequently. Enough to be a little annoying. Though those are broadcasting from the same tower 32 miles away, owned by the same company. So perhaps those audio dips are an artifact of their transmission. It's hard to say.
Those two stations are broadcasting on RF17 and RF19 respectively though.
post #18022 of 18323 Old 02-03-2020, 04:09 PM
Quoted: 219 Post(s)
Liked: 113
Ok, I just tried the new LTE filter on the back of my 2013 LG tv set after a PM I received from another person here that mentioned trying it that way. It did NOT drop signal or quality level on WAQP-49, which broadcasts on RF36. Checking all my other receivable channels, it didn't affect any of them adversely as far as I can tell, and the two low powered ones WFFC & WFKB seemed to have come UP a couple points. It only took me about a minute to screw the filter on, so atmospheric changes shouldn't have affected anything that quickly.
So, that at least gives me hope that once I can install it at the output of my actual antenna, and before the Kitztech KT-200 preamp, that I don't have to worry about it killing WAQP's signal, or even dropping it enough to cause issues with reception.
Question: Can LTE transmissions affect any tv channels BELOW RF36~, if the tower is close enough to you, say within 1 mile? Not sure if subharmonics can apply to LTE broadcasts.
post #18023 of 18323 Old 02-03-2020, 07:06 PM
mattdp's Avatar
Quoted: 115 Post(s)
Liked: 62
The LTE signal itself is not the issue - it is (we presume) filtered and strictly limited to its allocated frequency spectrum, otherwise the cell carrier has defective equipment/engineering and is in violation of FCC rules.
The issue is when it enters an amplifier at a strong enough level to be driving the amp into overload. The amp starts clipping, intermodulating, creating images/subharmonics, you name it. In an amp with separate UHF/VHF stages, it will likely only affects only UHF (all UHF channels - both above and below 36), but it could probably trash VHF too on a single stage amp. It's seen more on weaker channels and it may be worse depending on the frequency - YMMV.
I have personally witnessed the Kitztech's overloading from LTE.
Primestar31, rabbit73 and jkeldo like this.
mattdp is offline
post #18024 of 18323 Old 02-03-2020, 07:49 PM
labjr's Avatar
How do you go about proving that a cell company is in violation? And what can you actually do about it? Seems to me, cell companies rule the spectrum and get what ever they want. Interfering with someone's TV reception is the last thing they care about.
labjr is offline
post #18025 of 18323 Old 02-03-2020, 08:29 PM
mattdp's Avatar
Quoted: 115 Post(s)
Liked: 62
For the record, every case of cell interference I've dealt with was fixed by installing a filter prior to the first amplifier. It's the consumer receiving equipment (in the presence of strong cell signal), not the cell signal itself causing the issue.
I have never heard of a case of a cell tower spewing garbage out-of-band. They've got pretty sophisticated monitoring systems, not to mention teams of engineers that do design & monitoring. Other cell carriers in the area and probably TV stations would be affected too.
But... let's say you did actually have a cell site that was malfunctioning. You'd take a directional antenna and spectrum analyzer to isolate the tower in question and actually observe said out-of-band interference. Photographs, videos and other documentation will certainly help your case. I'd first contact the operator of said site and explain the situation. I would presume they would be highly motivated to fix the issue. If, for whatever they were delinquent in addressing it, then I would level a complaint with the FCC - who could levy all kinds of fines and whatnot.
mattdp is offline
post #18026 of 18323 Old 02-03-2020, 08:48 PM
hdtvluvr's Avatar
Quoted: 76 Post(s)
Liked: 57
So, I'm confused. Does the LTE interference potentially affect all users with OTA antennas or only for users who are using amps on their antennas?
hdtvluvr is offline
post #18027 of 18323 Old 02-03-2020, 08:56 PM
mattdp's Avatar
Quoted: 115 Post(s)
Liked: 62
LTE interference can affect anyone using OTA, with or without amplification.
In my experience as an installer, I find it's mostly an issue when using high gain preamps in close proximity to cell towers. But if you're close enough, it could potentially swamp out the IF in the receiver.
I've got a spectrum analyzer, so I know for sure if/how much of an issue it is. For the average consumer, testing with/without a filter is really the only practical way to tell for sure. At $20 and with little insertion loss, it really isn't going to hurt to have one in-line and not "need" it/
mattdp is offline
post #18028 of 18323 Old 02-04-2020, 10:28 AM
Larry Kenney's Avatar
Quoted: 842 Post(s)
Liked: 254
Matt... I just read your antenna installation guide and wanted to compliment you on the nice, easy to read and understandable writing... nice job!
Larry
My complete SF Bay Area DTV Station Lists: http://www.larrykenney.com/sfonair.html
Lots of Broadcasting links and information: http://www.larrykenney.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is offline
post #18029 of 18323 Old 02-04-2020, 10:52 AM
labjr's Avatar
I contacted the FCC about a local pirate FM station. It took over a year for anything to happen. Nobody ever followed up with me. I'm not even sure it was my complaint that led to any action. And after some searching I found they'd been shut down multiple times before only to pop up on another frequency. So I don't have much faith in the system.
labjr is offline
post #18030 of 18323 Old 02-04-2020, 11:52 AM
rabbit73's Avatar
Liked: 448
You did the right thing. The FCC resources are budget limited; their effort must be prioritized.
Lord Kelvin, 1883
rabbit73 is offline
Reply HDTV Technical
Channel Master Cm 4228 8 Bay Hdtv Uhf Antenna Cm4228hd
