channels keep disappearing from user lists - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-13-2004, 09:51 AM - Thread Starter
gregftlaud's Avatar
i live in ft lauderdale and my fox digital channels 7-1 and 7-2 keep disappearing from my user lists. i keep having to go back into "setup" then "antenna and cable" then "add remove channels"....
sometimes they stay on there for a while but most of the time they disappear within 5minutes again. those are the only channels that do this..
anyone else have this problem.
greg
gregftlaud is offline
post #2 of 5 Old 05-13-2004, 10:58 AM
leesweet's Avatar
Er, it would be nice to know what STB or system we are talking about... is this a cable system? Satellite? Sounds like cable but... You might want to find a local thread in the 'Local HD' forum for your area, as it could be a problem with those stations.
-Lee (See my profile for equipment.)
leesweet is offline
post #3 of 5 Old 05-13-2004, 11:10 AM - Thread Starter
gregftlaud's Avatar
samsung sir t350 directv/ota antenna
post #4 of 5 Old 05-13-2004, 11:19 AM
steeler's Avatar
greg
greg, you already posted this on the Master Samsung 360 thread......give people time to respond.....your answer is in that thread.........it's a common problem....Do a search....Here is a sample. https://www.avsforum.com/avs-vb/showt...30#post3755230
steeler is offline
post #5 of 5 Old 05-13-2004, 05:41 PM
Ken H's Avatar
This topic is closed.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread HDTV Technical
