Motorola 6200 STB w/ JVC 42WV74 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-13-2004, 06:11 PM - Thread Starter
GoSox78's Avatar
I am posting this here in the HDTV Hardware forum as well as the Plasma forum to hopefully get some views from people that have experienced the same situation as I have.
I have recently noticed that the picture on my non-HD channels have a small black bar on the left and right sides of the screen even after aspect change. It is only about .5" on both sides, but no matter what I do I can not get my plasma to fill the screen completely. I have tried everything possible - 1) Aspect ratio changes; 2) Picture adjustment via Plasma; 3) Disconnect DVI cable and only connect Component; 4) Only connect DVI. I have had no luck. Before I call Comcast or JVC I thought I would come to this forum first as I firmly believe the knowledge is much greater here than there. Is there something wrong with my STB or Plasma or the way I have it set-up?
Thanks in advance....
GoSox78 is offline
Closed Thread HDTV Technical
