H20 to Lexicon MC1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-28-2006, 01:11 PM - Thread Starter
lwien's Avatar
I know this is a long shot but maybe someone here may have the answer.
Does anyone know what the code is to program the H20 remote to be able to control the volume on an MC1 as well as turn it off and on ??
I have an MX500 remote that I will eventually use but I just wanted to do a quick and dirty program on the H20 remote right now.
lwien is offline
post #2 of 4 Old 01-29-2006, 05:40 AM
dsanbo's Avatar
Iwien....
Have you run through the procedure on page 33 of the H20 OP Manual? It doesn't list specific codes for equipment....but you should be able to get a "leg up" with the listed procedure.....Good luck!
dsanbo is offline
post #3 of 4 Old 01-29-2006, 10:15 AM - Thread Starter
lwien's Avatar
Yeah.........the on-screen instructions say to keep hitting the ch-up button and go thru all the codes and that it could take upwards of 30 minutes to go thru them. I started that process, but after 10 minutes, I was ready to pull my hair out................ !!
Looking for a code here so I don't have to just sit there for a half an hour hitting the channel button.........that's insane. Who would do that? After about 10 minutes, ya have this urge to throw the remote out the window..........
lwien is offline
post #4 of 4 Old 01-29-2006, 11:37 AM
Sharon L's Avatar
Have you tried the Lexicon forum at:
http://www.smr-forums.com/
Someone there might know
Sharon L is offline
Closed Thread HDTV Technical
