Personal Indoor HDTV (ATSC Compatible) Transmitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-01-2006, 02:18 PM - Thread Starter
masroor's Avatar
I'm just wondering, if there's any consumer level Personal Indoor HDTV (ATSC Compatible) VHF/UHF Transmitter available?
I'm looking for a solution by which I can redistribute HDMI or combo of DVI w/SPDIF signal coming out of any of the devices listed below:
- DVD Player with HD Upsampling with HDMI output (such as Model: JSI 4127 - I'm not allowed to paste URLs, yet, because this is my 1st Post :D)
- Cable Box with HDMI or DVI output
- HTPC with HDTV (DVI or Component) Output
In other words I'm looking for a solution similar to the good old VHF / UHF Analog Video Indoor Transmitter, but for DIGITAL HD output to be wirelessly transmitted over VHF/UHF so that HDTV in different rooms to be capable of tuning onto this on one of the free channels.
I think such a solution will simplify the setup/aesthetics of any HTPC project.
Appreciate, any leads to such products or ideas for DIY projects.
masroor is offline
post #2 of 9 Old 03-01-2006, 02:47 PM
DougRuss's Avatar
Could you Please change the FONT COLOR to something we can read....besides YELLOW ?
:eek:
Yamaha RX-V479
Cambridge Audio " Azur-650c
Rega RP-1 Turntable
YAQIN MS-12B Pre-amp
GemTune BL-02 EL34*2 Hi-end Tube Amplifier
Monitor "Bronze 5" Speakers
DougRuss is offline
post #3 of 9 Old 03-01-2006, 02:54 PM
mjones73's Avatar
No, there is no easy method to distribute HD around a house yet, most distribution methods are hard wired and only work with component connections.
Please change your font color, not all of us run the black background.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #4 of 9 Old 03-01-2006, 09:10 PM - Thread Starter
masroor's Avatar
:eek:
I'm sorry. I just removed yellow color tag to none. Hope you shoud see the default color or as per your own settings.
Otherwise, please advise a suitable color tag so that everyone can read my post.
masroor is offline
post #5 of 9 Old 03-02-2006, 06:32 AM
mjones73's Avatar
You don't need to choose a color tag at all.
Matt
mjones73 is offline
post #6 of 9 Old 03-02-2006, 12:13 PM
DTC mac's Avatar
No such animal currently nor likely in the near future exists. Real time MPEG encoding and frequency agility being two major (pricey) obsticles.
DTC mac is offline
post #7 of 9 Old 03-06-2006, 01:16 PM - Thread Starter
masroor's Avatar
If we atleast know what the Broadcasters use to convert an MPEG2 HD Stream into TS (Transport Stream) HD / VHF or UHF RF Freaquency; that should probably give some idea to build our own or pursue an economical solution... I'm still dreaming :)
masroor is offline
post #8 of 9 Old 03-06-2006, 01:50 PM
Ratman's Avatar
Quoted: 2441 Post(s)
Liked: 2282
OTA uses 8VSB
Cable uses QAM256
Pick your modulation format and start pricing and designing. If you come up with something that works at an affordable price (I.E. <$1000) get it patented quickly.
Also... make sure it complies to FCC regulations.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #9 of 9 Old 03-06-2006, 02:32 PM
bfoster's Avatar
And to add to Ratman's post, both UHF and VHF!
bfoster is offline
Closed Thread HDTV Technical
