Motorola 6200 Remote code?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-05-2006, 06:54 PM - Thread Starter
alexb76's Avatar
Quoted: 46 Post(s)
I have a Moto 6200 box (supplied by Shaw cable in Canada) and need to find the remote code for it, as I want my Pioneer receiver remote to control the box.
There is no entry for Motorola in the remote codes and it is not a learning one so I need to get the right code... anyone knows it? I did a lot of search but with no luck.
Pioneer Elite SC-67, B&W 805S/XTC/M1/PV1, Pioneer Elite Kuro 111FD, Elite BDP-05FD
alexb76 is offline
post #2 of 4 Old 03-05-2006, 07:22 PM
Ken H's Avatar
Try a code for General Instruments.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 4 Old 03-06-2006, 01:22 AM - Thread Starter
alexb76's Avatar
Quoted: 46 Post(s)
I did, only code available is 777 for that and that didn't work. There is a list of many different brands and I couldn't find one that matched :(
alexb76 is offline
post #4 of 4 Old 03-06-2006, 06:15 AM
Oxb
Oxb's Avatar
You could also try "Jerrold" codes
Oxb is offline
Closed Thread HDTV Technical
