something went wrong... help please. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-12-2007, 12:03 PM - Thread Starter
dmundell's Avatar
I have used an RCA attic antenna for the past year to pick up OTA signals without any problems until this weekend. Now the only station I can get is and ABC station which seems to be VHF according to AntennaWeb.org. All of the other stations which used to be fine are UHF channels. I did change anything that I am aware of. I'm a little new at this so any help would be appreciated
dmundell is offline
post #2 of 5 Old 09-12-2007, 12:38 PM
RCbridge's Avatar
Quoted: 16 Post(s)
Check your connections and cables on both ends, wiggle the ends look for changes (you will need a second person for the antenna side).
Is there an amplifier in line?
RCbridge is offline
post #3 of 5 Old 09-12-2007, 12:55 PM
Bill Johnson's Avatar
Perhaps you'll have to run a manual rescan for OTA stations, which I guess is done differently based on the system. If you've already tried that, I'm at a loss!
Bill Johnson is offline
post #4 of 5 Old 09-12-2007, 01:17 PM
kenglish's Avatar
Liked: 40
Check out the setup menu....
Is the set switched to "OTA" mode, or "Cable/CATV" mode?
It should be set for "OTA" if using an antenna. VHF channels, 2-13, are the same frequencies on both OTA and Cable. The others (14-69 OTA, and 14-125 or so in Cable) are different. So, you only get the VHFs if it's set wrong.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #5 of 5 Old 09-12-2007, 08:55 PM - Thread Starter
dmundell's Avatar
kenglish you are the man. Saved my butt before the weekend games. Dunno how that got switched but we are back in business. Thanks for everyones help.
dmundell is offline
Reply HDTV Technical
