FS: RUNCO LS-5 w/new lamp $800 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 11-01-2017, 12:57 PM - Thread Starter
Aztar35's Avatar
Quoted: 2502 Post(s)
Liked: 1349
FS: RUNCO LS-5 w/new OEM lamp
For sale is my Runco LS-5 projector. The LS-5 has a nearly invisible dynamic iris and some of the best black levels from a single chip DLP...it has the .95 chip.
It has a new OEM lamp that I purchased directly from Planar/Runco and now has only about 220 hours on it. Physically, this projector has some trivial small scuff marks on the plastic case; the lens looks great and the projector works flawlessly!
Asking $780 plus shipping. Accept Paypal.
Aztar35 is offline
post #2 of 19 Old 05-03-2018, 01:33 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
Bump
Aztar35 is offline
post #3 of 19 Old 05-03-2018, 05:22 PM
dan webster's Avatar
Quoted: 270 Post(s)
Liked: 267
Can you tell me what lens in installed on it and the throw ratio for a 110 screen
Dolby Atmos 7.2.4 Yamaha CX-A5200 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 panasonic ub820 Ultra HD Blu-ray Jvc RS3000 projector
silver ticket 125 2.35 screen Golden Ear Triton 5 L&R
super center XXL triton 7's sides Emotiva T1 rears
4 RSL C34 in ceiling SVS PB2-plus sub SVS PC13 ultra sub
dan webster is offline
post #4 of 19 Old 05-03-2018, 05:51 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
It has the standard throw. You will need about 15 feet between the unit and the screen for that size screen (110" diagonal).
Aztar35 is offline
post #5 of 19 Old 05-06-2018, 01:21 AM
coolgeek's Avatar
Quoted: 1734 Post(s)
Liked: 953
I have a 10 feet wide 16:9 (about 138inch diagonal) screen with a 0.9 gain. My question is i heard the projector is not as bright.. will it work for this? And how far back do i need to place it to cover my screen size?
coolgeek is offline
post #6 of 19 Old 05-06-2018, 05:42 AM
scottyb's Avatar
Quoted: 47 Post(s)
Liked: 30
http://www.projectorcentral.com/Runc...Style_LS-5.htm
It's 1000 lumens but this is calibrated so it's true lumens.
Might not be real bright on that size screen but this is a great projector.
scottyb is offline
post #7 of 19 Old 05-06-2018, 06:00 AM
airscapes's Avatar
Quoted: 516 Post(s)
Liked: 427
No it won't, if that was an Dalite HP 2.8 it would be awesome!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #8 of 19 Old 05-06-2018, 07:25 AM - Thread Starter
Aztar35's Avatar
Liked: 1349
Hi. This has the .95 chip with a premium light path/lens, so on-screen, it appears brighter than the numbers suggest. I use it in low lamp on a 1.1 gain screen, 125 inches diagonal/133 inches diagonal 1.78:1 16x9 equivalent. However, to fill your screen size at about 140 inches, you would have to move it back further to meet the throw and you also have a negative gain (0.9) screen, so I don't think it would be a good match for you, unfortunately.
Aztar35 is offline
post #9 of 19 Old 05-08-2018, 09:37 AM
coolgeek's Avatar
Liked: 953
Ok, thanks guys...
coolgeek is offline
post #10 of 19 Old 02-10-2019, 01:00 PM
Liked: 0
Is it still available?
elvinlora is offline
post #11 of 19 Old 02-10-2019, 01:09 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
Yes. I sent you a PM.
Aztar35 is offline
post #12 of 19 Old 02-18-2019, 08:49 AM
audiman's Avatar
Quoted: 35 Post(s)
Liked: 35
where are you located?
audiman is offline
post #13 of 19 Old 02-19-2019, 07:13 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
U.S.
Aztar35 is offline
post #14 of 19 Old 04-01-2019, 03:21 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
Bump
Aztar35 is offline
post #15 of 19 Old 05-07-2019, 02:38 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
Bump
Aztar35 is offline
post #16 of 19 Old 06-17-2019, 08:02 AM
chord's Avatar
Originally Posted by Aztar35 View Post
Bump
Is this RUNCO still for sale ?
chord is offline
post #17 of 19 Old 06-17-2019, 03:57 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
Yes it is.
Aztar35 is offline
post #18 of 19 Old 07-21-2019, 12:02 PM
Quoted: 4859 Post(s)
Liked: 1835
Do you know how many nits you get on the 1.1 gain 133" screen?
Dominic Chan is online now
post #19 of 19 Old 07-21-2019, 10:08 PM - Thread Starter
Aztar35's Avatar
Liked: 1349
Hi, No, I don't. Unfortunately, I put it away.
I can tell you that the 1.1 gain screen helped a lot though. In high lamp mode, the image in a darkened room never made me think the image looked off where if there really were insufficient light. However, it is lamp-based and I placed new OEM lamp in there from Planar and it has only a few hundred hours now. The down-side is that it is still lamp technology and as the lamp ages you will lose brightness.
Aztar35 is offline
Reply Front Projector
