WTB: Runco Short Zoom 1.56:1-1.86:1 Lens - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bdht
post #1 of 3 Old 11-18-2019, 02:21 PM - Thread Starter
watchindiefilm's Avatar
Wanted: Runco Short Zoom Lens 1.56:1-1.86:1
I'm looking for one that will fit the Runco Q-750i LED DLP projector. The part # might be 997-5351-00. There is very little info to be found regarding if this was a model specific lens or if it was interchangeable with other Runco projectors. I believe it might have fit other models as well (Like the LS-5 and LS-7). Any additional information anyone has on this lens and compatibility would be really helpful.
watchindiefilm is offline
post #2 of 3 Old 11-18-2019, 02:54 PM
bdht's Avatar
Quoted: 306 Post(s)
Liked: 117
Im not 100% sure, but I believe you can buy an old Digital Projection M-Vision 260 or 400 projector with the 1.56-1.85 lens and swap them out.
The Runco 997-5351-00, Digital Projection(DPI) 110-157, and Vivitek/Delta 3797711500-S are the same lens.
Here's how you swap them: https://pdfhost.io/v/@MwyXdwrQ_MVisi...ocedurepdf.pdf
watchindiefilm likes this.
bdht is online now
post #3 of 3 Old 11-19-2019, 06:37 AM - Thread Starter
Big Thank You!
bdht,
Really can't thank you enough for this very helpful information! I've already found some options. Thanks again.
Reply Front Projector
