Mitsubishi WD-73738 + extra Lamp - $200 OBO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-13-2017, 07:04 AM - Thread Starter
gumbico's Avatar
Moving onto a 75"4K set and looking to find a home for my trusty 73" Mitsubishi DLP TV. I'm the original owner of this set, purchased from Paul's TV in October of 2010. I then purchased a new Philips OEM Lamp/Housing (https://www.amazon.com/dp/B00BBFYC8E) in November of 2014 in anticipation of the factory bulb going dim or out. But as you can see in the pics, it's still going strong after 5300 hours of use! Regardless, when it does die, you'll have another bulb ready to go.
I used the 3D feature for a bit when I first got it, but I have long since unplugged the IR Emitter and packed away the Active 3D Glasses. There have been zero problems with this set. Mostly used for PS4 gaming and watching movies.
Everything that came with the TV is included as you can see in the pics. Buyer will have to come and haul this set away. Cash and carry in Tysons Corner, VA. Asking $200 obo.
Useful Links:
https://www.mitsubishi-tv.com/suppor...ments/WD-73738
https://www.avsforum.com/forum/63-rear-projection-units/ show contact info -mitsubishi-3d-dlp-owners-thread-738-838-series.html
https://www.amazon.com/Mitsubishi-WD...ews/B003HJ5CKE
UPDATE: Gone
ID:	2329938   Click image for larger version
ID:	2329940   Click image for larger version
ID:	2329942   Click image for larger version
ID:	2329944   Click image for larger version
ID:	2329948   Click image for larger version
ID:	2329950   Click image for larger version
ID:	2329952   Click image for larger version
ID:	2329954   Click image for larger version
ID:	2329958   Click image for larger version
ID:	2329960   Click image for larger version
ID:	2329962   Click image for larger version
ID:	2329964   Click image for larger version
ID:	2329968   Click image for larger version
gumbico is offline
Reply Rear Projection
dlp
