Run a command on wakeup from suspend? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-28-2008, 07:41 PM - Thread Starter
stoked's Avatar
Hi all,
I have a service that seems to hang whenever my computer suspends/hibernates and is woken up. I'd like to automatically restart the service when the computer wakes up, does anyone know of a way of doing this? I tried googling, but didn't come up with much.
stoked is offline
post #2 of 11 Old 02-29-2008, 08:19 AM
lstepnio's Avatar
I have resume from suspend events defined in Girder. This might be overkill but you might want to look into Girder as an overall solution. I think there are some Girder-like application that are free that might have such functionality.
lstepnio is offline
post #3 of 11 Old 02-29-2008, 10:05 AM
Rupert's Avatar
Originally Posted by stoked View Post
Hi all,
You can assign a task, such as "net start service", to events generated in the Windows Event Log.
In Windows XP, you can use the Eventtriggers tool.
In Vista, assigning tasks to events is built in to the Event Viewer:
http://www.microsoft.com/technet/Win....mspx?mfr=true
Rupert is offline
post #4 of 11 Old 02-29-2008, 10:51 AM - Thread Starter
stoked's Avatar
Awesome... exactly what I was looking for... thanks Rupert! Doesn't seem to be a "net restart Service" option... will have to see if I can get this to work.
stoked is offline
post #5 of 11 Old 02-29-2008, 10:56 AM
Rupert's Avatar
You would have the task run a batch file. Create a batch file using the command:
net start NameOfService
Type "net start" (without the quotes) at a command prompt for more info.
Rupert is offline
post #6 of 11 Old 02-29-2008, 11:42 AM - Thread Starter
stoked's Avatar
Thanks, yeah I just started going through the details. Already have a batch file.
stoked is offline
post #7 of 11 Old 02-29-2008, 12:50 PM
ctiq21's Avatar
Quoted: 25 Post(s)
If you go into the properties of the service, under the recovery tab you can have it restart automatically if it happens to stop. no need to create a batch file or anything.
ctiq21 is offline
post #8 of 11 Old 02-29-2008, 04:02 PM - Thread Starter
stoked's Avatar
Can't seem to get this to work. I always get a ERROR: Unable to create event trigger named "Trigger Name". Tried this on XP MCE and 2 XP Pro machines. I even copy and pasted some of the examples from eventtriggers /create /? and no luck.
UPDATE: Got it working... think it must be either order of the command switches or case sensitivity...
stoked is offline
post #9 of 11 Old 03-02-2008, 05:35 PM - Thread Starter
stoked's Avatar
Rupert,
Was able to create the eventtrigger, but it doesn't seem to trigger on the Event Log entry... have you been successful using this?
stoked is offline
post #10 of 11 Old 03-03-2008, 12:51 AM
Rupert's Avatar
Rupert,
Yes, it works on an XP Pro machine I use. It triggers when the NIC announces that it's up (Event ID 11). Here's the command line:
eventtriggers /create /tr "MyTriggerName" /eid 11 /t INFORMATION /tk c:\\windows\ est1.bat /ru MyUsername /rp MyPassword
The batch file is just this:
net start MyServiceName
Send me a PM if you have trouble with it.
Rupert is offline
post #11 of 11 Old 03-03-2008, 01:22 AM - Thread Starter
stoked's Avatar
Didn't get a chance to update my above post, but I got it working. Turns out eventtriggers run under the System user... which didn't have access to where my batch file was located. Moved it to C:\\windows\\system32 and it works now. Thanks!
stoked is offline
Reply Home Theater Computers
