Sound Quality Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-11-2008, 09:00 AM - Thread Starter
Chappie_BR's Avatar
First off, I may be getting in over my head here, so please forgive the likely basic nature of my question.
I had a hard drive on a 2 drive system die, and so I took it as an opportunity to build a whole new computer. After I had my new system, I got the other one up and running again, and now it's sitting in a corner. My plan was to sort of make it a poor man's media server and connect it to my home theater system. I figured I could run itunes through it and watch movies via the netflix watch now deal, etc.
The problem: the sound quality of my songs on itunes is horrible when played this way. When played through my PC and my $29 cheapo brand speakers, while hardly audiophile quality, it sounds MUCH better than giong through my reciever and out of my paradigm mains.
The setup, in case it's relevant: soundblaster sound card connected to a normal input on my receiver via a 1/8" to RCA plug.
What is the cause, or is it just that decent speakers really illuminate the poor quality of my itunes files? Again, I am perfectly happy with the quality of the sound when played over my normal cheap pc speakers.
Chappie_BR is offline
post #2 of 4 Old 11-11-2008, 09:08 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2384
It's quite possible, probable in fact. Does the sound sort of "smear" at the high end? A quick way to test is to see what a CD sounds like, if it sounds good, it's probably the iTunes files.
stanger89 is offline
post #3 of 4 Old 11-11-2008, 10:42 AM
Paul Bigelow's Avatar
Good speakers and headphones can reveal all sorts of problems with the source material (high compression and artifacts) that lesser speakers don't reproduce. Might take a look at the settings to make sure there isn't a sound "enhancement" process going on. Creative can do a lot of things with sound.
Paul Bigelow is offline
post #4 of 4 Old 11-11-2008, 10:49 AM
nm88's Avatar
Try SPDIF digital output and use your receiver's DAC. The analog outputs on a typical sound card are horrible whereas the digital output are often just resampled and therefore still decent.
Also, turn off all gimmicky audio processing "enhancements" in the sound card drivers, which make everything sound even worse.
You're probably happy with your cheap PC speakers because they're cheap and not detailed, thereby hide all of the flaws mentioned above.
nm88 is offline
Reply Home Theater Computers
