Playing MP3s in Dolby Pro Logic II? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-25-2008, 07:56 AM - Thread Starter
jang1a's Avatar
Is there any way for me to playback mp3 files in Dolby Pro Logic II? I am using Windows media player to play back mp3 files. I'm using HDMI interface. My receiver Harman AVR 247 supports it.
I already have 5.1 surround working on movies.
jang1a is offline
post #2 of 5 Old 12-25-2008, 12:13 PM
Ben_Tech's Avatar
Configure your sound driver to output 2 channel PCM and it should work. It certainly does over spdif.
My Blog - Ask Toy Tech
Ben_Tech is offline
post #3 of 5 Old 12-26-2008, 10:49 PM - Thread Starter
jang1a's Avatar
Hello Ben_tech, can you point me where to set the sound driver to 2 channel pcm? I'm using vista Ultimate
jang1a is offline
post #4 of 5 Old 12-26-2008, 11:07 PM
undermined's Avatar
what kind motherboard? I'm assuming that you are using the hdmi port on it to go to the AVR? Or are you using a video card with hdmi?
Also what does the AVR "see" the signal as on the front panel? Because if it see "stereo" while playing mp3s then putting it into Dolby Pro Logic II music mode all you need to do.
Most lickly you are already feeding it a PCM signal since the mp3 in not a bitstream source and unless the sound from you hdmi port being encoded to Ac3 or DTS it is just PCM.
undermined is offline
post #5 of 5 Old 12-26-2008, 11:12 PM
Zachstar's Avatar
Run PCM to the receiver and use its modes. Sound's great!
Zachstar is offline
Reply Home Theater Computers
