HD DVD & Blu-ray Menu Navigation in Media Player Classic!? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-25-2008, 11:34 PM - Thread Starter
HiPerFreak's Avatar
Hi!
Is there any way to add support for HD DVD and Blu-ray menu navigation to the MPC (Media Player Classic)?
I would really appreciate any help.
- Daniel
HiPerFreak is offline
post #2 of 6 Old 12-26-2008, 03:39 AM
Mark_A_W's Avatar
"Media Player Classic Home Cinema" will play the main title of a Bluray when you open "DVD".
It will not do that for a HD-DVD, and you cannot get menus for Blurays (good think IMO - just play it and then pick the best audio through the filters menu).
If you want more, ask on Doom9, maybe they will add it.
Loving my Electric Bike!!
Mark_A_W is offline
post #3 of 6 Old 12-26-2008, 09:40 AM - Thread Starter
HiPerFreak's Avatar
I actually meant MPC-HC (forgot to mention it). So the answer is, that it is currently simply not possible. Sometimes the menu would be quite helpful, if not essential (take the "Digital Video Essentials HD" test and calibration disk as an example).
I heart something about the "HD Navigation Filter" (or so) from PowerDVD. Would it maybe be possible, to use this with MPC-HC?
Best regards,
Daniel
post #4 of 6 Old 12-26-2008, 01:33 PM
tetsuo55's Avatar
the menu's don't work yet because they require JAVA.
At the moment MPC-HC cannot connect with anything java-related.
It will take quite amount of coding to fix this. If anyone want's to help out by coding it it would be greatly appreciated
tetsuo55 is offline
post #5 of 6 Old 12-26-2008, 10:07 PM - Thread Starter
HiPerFreak's Avatar
Are there other lightweight players that support menu navigation? I don't really want to install the full blown PowerDVD just for my "Digital Video Essentials HD" disk.
post #6 of 6 Old 12-27-2008, 12:20 AM
HTPC101's Avatar
nice read
HTPC101 is offline
Reply Home Theater Computers
