AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Home Theater Computers (https://www.avsforum.com/forum/26-home-theater-computers/)
-   -   Internal MPC-HC filters or ffdshow for best quality decoding? (https://www.avsforum.com/forum/26-home-theater-computers/1100576-internal-mpc-hc-filters-ffdshow-best-quality-decoding.html)
HiPerFreak 12-26-2008 10:40 PM
Hello!
With MPC-HC and ffdshow I have basically two options: (1) use the internal MPC-HC filters to decode the movies and use ffdshow just for scaling, etc. or (2) disable all internal MPC-HC filters and use ffdshow for decoding too.
My question is, if I want the best PQ, which way should I go? What option are you using? I would really appreciate any hints and infos!
- Daniel
ray.casey 12-27-2008 12:49 AM
Not to much uptake on this... well what are your thoughts as maybe you already have the best answer
CSMR 12-27-2008 01:12 AM
I'm missing something. If you are using MPC-HC internal filter then how is ffdshow in the loop? Or are you using ffdshow and setting the MPC-HC standalone filter in ffdshow?
I prefer not to use ffdshow as it stops DXVA, adds a layer of complexity, and I find MPC-HC bicubic scaling satisfactory (although I don't know how much better you can get). The only other adjustments I would want are colour management but no player/filter does that now to my knowledge.
HiPerFreak 12-27-2008 01:52 AM
ray.casey, I don't have an answer myself :-).
CSMR, if you set the "Raw video" codec in ffdshow to "all supported', you can use the internal MPC-HC filter for decoding and ffdshow for post processing, if this was you question.
Basically I want to use ffdshow for post processing, and for decoding I have the two options described.
CSMR 12-27-2008 02:16 AM
They should both produce the same output if there are no bugs, so it's a matter of speed since bugs tend to get ironed out in both programs fairly quickly.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
