Cant play The X-Files: I Want to Believe blu ray with powerdvd 8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-26-2008, 10:48 PM - Thread Starter
outbreak's Avatar
Just got The X-Files: I Want to Believe Blu Ray and its not working with PowereDVD 8 Ultra. This happens with or without anydvd hd running in the background. My drive is the LG H20LK. I updated PowereDVD thinking that would fix the problem but that did not help.
How can I get this to work?
outbreak is offline
post #2 of 4 Old 12-27-2008, 02:28 AM
talon95's Avatar
Quoted: 332 Post(s)
Liked: 186
Did you completely purge the old PDVD install before putting the newest version on? That's what I had to do. Uninstall, delete any remaining files, remove all registry entries, then re-install.
talon95 is offline
post #3 of 4 Old 12-27-2008, 03:06 AM - Thread Starter
outbreak's Avatar
Tried it again doing what you said removing everything and it worked.
thanks (:
outbreak is offline
post #4 of 4 Old 12-27-2008, 05:30 AM
captain_video's Avatar
Quoted: 682 Post(s)
Liked: 411
The latest X-Files movie is encrypted with a newer version of BD+ that AnyDVD HD can't handle yet. The folks at Slysoft say it will probably be around the middle of February before it's cracked. I believe all of the newest Fox releases are all using it. Check out the AnyDVD HD section at the Slysoft forums for details.
captain_video is offline
Reply Home Theater Computers
