*Official* Zotac H55-ITX Mini-ITX HTPC Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 213 Old 02-19-2010, 11:17 AM - Thread Starter
Lawguy's Avatar
Liked: 24
The Eagle Has Landed.
My build commences.
Affable Nitwit
Lawguy is offline
post #2 of 213 Old 02-19-2010, 12:12 PM
tsb
tsb's Avatar
just need a usb 3.0 card instead of the wifi card
does it support i5-7xx and i7-8xx?
tsb is offline
post #3 of 213 Old 02-19-2010, 12:20 PM - Thread Starter
Lawguy's Avatar
Liked: 24
Tha manual states that it "Supports LGA 1156 socket for Intel Core i3/Core i5/ Core i7 processors."
I suppose you could plug a USB 3.0 card into the mini PCIE slot (or any other PCIE device for that matter). I sure don't need the WiFi.
Affable Nitwit
Lawguy is offline
post #4 of 213 Old 02-19-2010, 12:40 PM - Thread Starter
Lawguy's Avatar
Liked: 24
The Bios that shipped with the board says "Evaluation." The website has an update. The manual says the bios update is to be done in DOS. They have to be kidding.
Affable Nitwit
Lawguy is offline
post #5 of 213 Old 02-19-2010, 02:09 PM - Thread Starter
Lawguy's Avatar
Liked: 24
I added a few pics to the first post that show the build progress.
I need to run out and get a slimline optical cable before I install my drives.
Here are a few notes.
The case is a Travla C138. This case comes with a 20 pin ATX PSU. I pulled the board out of the case and am using a PICO PSU instead. This has the benefit of adding a little room. I got the premium 150 watt PSU so you can see that I had to do a little surgery on the back of my case to add the required connector (the hole had to be widened and screw holes added). The picture makes it look bad but it looks good in the real world.
This is my first ITX build. The board is smaller than expected. That said, working with it is not very different from working with any other board. It is fairly well laid out. I am using the stock Intel heatsink. I attached the CPU, heatsink, ram and as many cables as possible to the board before inserting it in the case. The position of the case connectors (power switch, power LED, etc.) leaves very little room to move after the board is installed.
I will be adding an 160 GB Intel X-25m SSD, a slot loading optical drive, and a 500GB Hitachi 7200RPM 2.5" HDD. I hope I still will have room to use the PCI-E slot if I want to add a CETON card to the case when it is released.
That is all for now.
Affable Nitwit
Lawguy is offline
post #6 of 213 Old 02-19-2010, 03:29 PM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
Will you test for Blu-Ray bitstreaming and, gulp, 24p? I assume you will use core i IGP.
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #7 of 213 Old 02-19-2010, 03:43 PM
hlkc's Avatar
I assume you answered my question from the other thread. Can't wait to hold one of this puppy soon.
I am very interested to know bitstream 24P from BD too. I'm sure you will going to test it VERY soon, right? Please post a quick word after test. Thanks!
hlkc is offline
post #8 of 213 Old 02-19-2010, 10:39 PM
user4avsforum's Avatar
You made my day. I have been waiting for a mini-ITX H55/57 board to be available.
How much space between the top of the CPU fan and the bottom of the drive tray, oh and what CPU are you using? I am hoping to use a lower height mini-ITX case.
user4avsforum is offline
post #9 of 213 Old 02-20-2010, 02:18 AM
BobSalita's Avatar
Me too, I'm looking for a driveless case. Smallest possible case. Any recommendations?
post #10 of 213 Old 02-20-2010, 02:43 AM - Thread Starter
Lawguy's Avatar
Liked: 24
There is (maybe) enough room for a PCI-E card. I don't think I'll put one in. Cable management is a real PITA. I should have bought short SATA cable because SATA cables are bulky. I tied them up and everything fits.
Core i5 650 is the CPU.
Installing Windows now.
Affable Nitwit
Lawguy is offline
post #11 of 213 Old 02-20-2010, 02:46 AM - Thread Starter
Lawguy's Avatar
Liked: 24
Sorry, but I don't know of any. Driveless was not an option for me so I never really looked.
Affable Nitwit
Lawguy is offline
post #12 of 213 Old 02-20-2010, 05:48 AM - Thread Starter
Lawguy's Avatar
Liked: 24
Okay. I have things up and running now. All is well.
I installed Windows 7 64 bit and the Intel 2057 drivers.
At first, I was kind of shocked at how loud the system was. The fans were running very quickly and there appeared to be no way to control them. Zotac has a bios upgrade on their website that notes that it simply removes the "Evaluation" message. Thankfully, it does more than that. It adds fan control. I changed it to thermal control and nows things are really quiet.
Updating the bios is a real PITA. This is the first motherboard I have owned in years that does not have a bios upgrade program that is accessable in the bios itself. Zotac provides a Windows utility but I could not get that to run at all. So, I created a bootable dos flash drive and did it from there.
One thing you also have to make sure you enable in the bios is the HDMI setting. Without it, you get no HDMI sound.
I installed TMT3 and the beta patch. Bitstreaming works, at least on the Watchmen disk that I tried. Video also looks smooth at 24p but I want to run some test patterns and view more clips before I declare it completely stutter free. I have some Netflix movies coming today so I give some a careful watching and report back.
I have to say that I am pretty happy with this tiny little computer.
Affable Nitwit
Lawguy is offline
post #13 of 213 Old 02-20-2010, 07:53 AM
MikeMcM1956's Avatar
What memory are you using (mfg/pn/speed/size)? My current Atom 330 mini-ITX has 4GB of DDR800, but this board supports 1066/1333. Does the manual mention if DDR800 can be used? That could be a temporary fix until I order new memory....
Mike
P.S. - The Zotac USA website now shows the driver update as including CMOS fan control.
Follow Me On Twitter: ThatGeekGuy
Tech News, Great Buys, Reviews & More....
MikeMcM1956 is offline
post #14 of 213 Old 02-20-2010, 08:17 AM - Thread Starter
Lawguy's Avatar
Liked: 24
Mike
To be honest, I don't know what memory I am using. It is the cheapest DDR3 I could find at Microcenter.
Good thing that the fan speed issue was corrected. That was WAY TOO LOUD!
Affable Nitwit
Lawguy is offline
post #15 of 213 Old 02-20-2010, 10:41 AM
nightfly85's Avatar
Quoted: 86 Post(s)
Liked: 44
Lawguy, you were able to update Bios using USB drive right? I hope they don't force you to use a floppy drive.
JVC 4910, Marantz 7010 AVR, HTPC MPC-HC/MPC-BE x64; MadVR/LAV
nightfly85 is offline
post #16 of 213 Old 02-20-2010, 11:41 AM
tsb
tsb's Avatar
http://www.mini-itx.com/store/?c=3
a few here to consider
tsb is offline
post #17 of 213 Old 02-20-2010, 03:56 PM
BobSalita's Avatar
Great link, Thanks. I'm liking the M200-LCD.
post #18 of 213 Old 02-20-2010, 04:05 PM
My current Atom 330 is in a M350 case, nice and small. Room for a 2.5 HD, no optical bay and requires a pico-PSU or mobo w/external brick. I like that it has two right angle USB connectors hiding behind the front panel for bootable USB O/S, bluetooth or IR dongle use.
$40 from a variety of sources, all of them currently backordered. Mini-Box looks like the shortest wait: http://www.mini-box.com/M350-univers...-itx-enclosure.
Mike
post #19 of 213 Old 02-20-2010, 05:42 PM - Thread Starter
Lawguy's Avatar
Liked: 24
USB works fine.
Affable Nitwit
Lawguy is offline
post #20 of 213 Old 02-20-2010, 07:06 PM
joshbish's Avatar
Any issues with wake-on-usb?
joshbish is offline
post #21 of 213 Old 02-21-2010, 12:44 AM
hlkc's Avatar
Law guy,
Do you think we can boot from OS, using OS in the USB?
hlkc is offline
post #22 of 213 Old 02-21-2010, 03:40 AM
bwoody2016's Avatar
Where did u buy it at? Amazon has it going for 149.99 but shipping is 11-14 days.
I'll be using this for my new desktop
All that is necessary for the triumph of evil is that good men do nothing-Edmund Burke
bwoody2016 is offline
post #23 of 213 Old 02-21-2010, 04:40 AM
adidino's Avatar
Quoted: 529 Post(s)
Liked: 360
Lawguy,
You are the main man on this thread! Curious what your Windows Experience Index total score is.. and what the sub scores are for video and proc. I'm assuming you are on Window 7?
Conrgats on the board.
Tony
AudioXtream
Authorized Dealer:
Trinnov, Anthem, SVS, Triad, Genelec,
Revel, JBL Synthesis/JBL Pro, Paradigm, Kaleidescape, PS Audio, JVC,
Panamorph, LG
adidino is offline
post #24 of 213 Old 02-21-2010, 04:44 AM - Thread Starter
Lawguy's Avatar
Liked: 24
Originally Posted by hlkc View Post
Law guy,
Yes. Flash drives are seen as Hard Drives.
There is also an esata port on the back if you wat to use that.
Affable Nitwit
Lawguy is offline
post #25 of 213 Old 02-21-2010, 04:45 AM - Thread Starter
Lawguy's Avatar
Liked: 24
I have not tried it yet. I will and report back.
Affable Nitwit
Lawguy is offline
post #26 of 213 Old 02-21-2010, 05:44 AM - Thread Starter
Lawguy's Avatar
Liked: 24
Stupid question but how do I test this? I see no options in the bios for wake on USB. Could it be called something else? I have a USB keyboard/Mouse. It maintains a connection to the PC but no keystrokes wake it. Also, I have a media center remote. The dongle lights when it is in sleep mode but does not wake when I press any button.
Affable Nitwit
Lawguy is offline
post #27 of 213 Old 02-21-2010, 05:48 AM - Thread Starter
Lawguy's Avatar
Liked: 24
I got it here. Call the number. The guy who runs the store is great to work with and he will let you know if it is in stock.
Affable Nitwit
Lawguy is offline
post #28 of 213 Old 02-21-2010, 05:52 AM - Thread Starter
Lawguy's Avatar
Liked: 24
Originally Posted by adidino View Post
Lawguy,
Tony
Total score is 4.8, Video is 4.8 and processor is 6.9.
Affable Nitwit
Lawguy is offline
post #29 of 213 Old 02-21-2010, 07:27 AM
samurai10's Avatar
would you be so kind to tell us if there are any oc options in the bios?
samurai10 is offline
post #30 of 213 Old 02-21-2010, 11:45 AM
nightfly85's Avatar
Quoted: 86 Post(s)
Liked: 44
Typically it's a Power Management option.. like PME support, etc. You typically are able to specify "all keys" a specific key, etc.
That's how the option exists on my current Zotac 9300 itx MB.
Reply Home Theater Computers
