External hard drive questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-13-2010, 05:18 PM - Thread Starter
mikereno1's Avatar
Right now we are using a laptop as a temporary HTPC, works well enough for now but I want to get more storage. A friend has about 1.5TB of movies that I am going to copy over so I need an external hard drive for it.
Ordering a case but wanted to make sure this hard drive will work ok. I am looking to just put all the movies on it, connect via USB and be able to play them through the laptop.
2TB Western Digital Caviar Green WD20EARS SATA Hard Drive (64MB cache)
2TB Western Digital Caviar Green WD20EADS SATA Hard Drive (32MB cache)
These use low amounts of power so run fairly cool, not designed for your main HD, but should work for my purposes right? 64 or 32MB?
mikereno1 is offline
post #2 of 10 Old 04-13-2010, 05:21 PM
The Village Idiot
Knucklehead90's Avatar
Quoted: 753 Post(s)
Liked: 703
If the price difference isn't great get the 64mb drive. 32mb should be ok since this is a single purpose drive. You won't want to do a write to the drive and try to watch a movie at the same time.
Yamaha A-S1000 Int. Amp - Salk SongTowers - Oppo 103 - Marantz TT42 - Emo XDA-2 DAC
Multi-Channel: Yamaha RX-A2070 - Custom One-Off Selah Audio Center - Emo ERD-1 Surrounds
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 10 Old 04-13-2010, 05:49 PM - Thread Starter
mikereno1's Avatar
Great, prices are about the same so I'll go with the 64
post #4 of 10 Old 04-13-2010, 07:34 PM
Bigbird999's Avatar
Format it in 64 k clusters for best performance. FWIW, a USB external drive has plenty of bandwidth (>20 MB/sec) to handle several HD programs at once.
BB
New wealth is created in 2 ways:
You dig it from the ground (mining and oil)
Or you grow it (fishing, farming and forestry).
Everything else is just processing what you dug up or grew.
Bigbird999 is offline
post #5 of 10 Old 04-15-2010, 02:29 PM - Thread Starter
mikereno1's Avatar
Got the drive and installed it into the case but it doesnt show up on my comp. On first connecting through the USB it recognized it, installed drivers successfully and I can now "safely remove" it, but it doesnt show up under my computer to add stuff too. How do I format it?
post #6 of 10 Old 04-15-2010, 02:33 PM
Fredrik's Avatar
Quoted: 39 Post(s)
Liked: 41
What you most likely want is "Disk Management".
Easiest way is to right-click on "Computer" and select "Manage".
You should have an entry in the left pane that says Storage or Disk Managment or both
21:st century Karate Kid......Logon, Logoff, Logon, Logoff..
Fredrik is offline
post #7 of 10 Old 04-15-2010, 02:57 PM - Thread Starter
mikereno1's Avatar
Set it up, still says formatting, how long does that take?
post #8 of 10 Old 04-15-2010, 04:07 PM
The Village Idiot
Quoted: 753 Post(s)
Liked: 703
2TB will take up to several hours.
post #9 of 10 Old 04-15-2010, 04:08 PM - Thread Starter
mikereno1's Avatar
Yeah, now it at least says 1%, might be several days at this rate
post #10 of 10 Old 05-10-2010, 11:07 AM
JHL
JHL's Avatar
How is the drive working for you? I purchased a 20EADS about 1 week ago and it seems to have a problem now. I was playing a video recording back and Media Center froze. When I rebooted Windows, I was told I needed to format the drive before using it.
JHL is offline
Reply Home Theater Computers
