Official Sandy Bridge / LGA1155 for HTPCs Thread - Page 42 - AVS Forum | Home Theater Discussions And Reviews
post #1231 of 2223 Old 05-12-2011, 12:17 AM
phy88's Avatar
Originally Posted by Abula View Post
Have you tried DEL?
Yup, tried it as well...not that I need to get into the bios, but it's still a funny issue. I probably should have just left the boot options in the bios alone since it was already booting very quickly.
On a very similar setup (still on the way) i ordered Premium picoPSU-150-XT/12.5A 150W AC-DC (just the 150W brick as the 120 has a fan) mostly out of the review of missingremote used that, and comes with 24pin n 4pin cpu so i figure was a simpler way to go, but seeing your setup is working great, im kinda wondering if Premium picoPSU-80/6.6A 80W AC-DC + 4-Pin P4 Mini Power Cable might be more efficient with how low the 2100T idles, even at load im expecting 60W max.
Yeah, I have that same 80W ac-dc adapter as well. The 4-pin mini power cable was too short though, so I bought a regular molex to p4. Works well with no issues. In terms of efficency, I doubt it's anything significant.
phy88 is offline
post #1232 of 2223 Old 05-12-2011, 03:44 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Celeron
- G540 2-core/2-thread 2.50GHz L3=2MB 65W
- G530 2-core/2-thread 2.40GHz L3=2MB 65W
- G440 1-core/1-thread 1.60GHz L3=2MB 35W
renethx is offline
post #1233 of 2223 Old 05-12-2011, 06:12 AM
babgvant's Avatar
Liked: 30
Originally Posted by phy88 View Post
On another note...the system boots so quickly that I can't even get into bios no matter how fast I press F2. Probably going to try disconnecting the boot ssd.
Start pressing/releasing F2 every 1/2 second after turning it on.
babgvant is offline
post #1234 of 2223 Old 05-12-2011, 10:37 AM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
What do you guys recommend as the best DVR Card to install in your Sandy Bridge HTPC? I'm looking for something that would allow me to record shows from my Comcast Cable in HD Quality (Including 5.1 Audio).
So far I have been looking at the Hauppauge Colossus H.264 Video Recorder PCI Express 1x card [LINK]. Just want to make sure there isn't something else better out there.
I do need the ability to schedule recordings (via software) for upcoming shows. I believe the Colossus is able to switch the station to the necessary station to record the show.
7.1.4: Polk RTi12 Fronts, RTi8 Surrounds, Monitor70 Surround Backs, CSi A6 Center, Klipsch R-14M Front Height & Rear Height + Outlaw LFM-1 EX Subwoofer.
JVC NX5 True 4K HDR Projector / Denon X6300H AVR
Intel Broadwell-E 6 Core (H2O) / EVGA RTX 2080Ti FTW3 Ultra Hybrid (H2O) HTPC
LG UBK80 UHD Blu-ray / XBOX One X
mickey79 is offline
post #1235 of 2223 Old 05-12-2011, 12:13 PM
hlkc's Avatar
Hi mickey79,
Beside what you suggested, I and most people also using Centon, see below, to watch, record and DVR the TV content from cable provider like Comcast. I have been using few weeks now and beside little bit of trial and errors and tweaking to make it to work, I am please with this product and result.
http://www.cetoncorp.com/
Asus P8H67 Evo
i3 2100
hlkc is offline
post #1236 of 2223 Old 05-12-2011, 12:23 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
Originally Posted by hlkc View Post
Hi mickey79,
Asus P8H67 Evo
i3 2100
Hey hlkc,
It looks like a pretty neat piece of equipment - but unfortunately it's more then double the cost of the Hauppage Colossus; that being the case I would prefer the Colossus card.
Thanks!!
mickey79 is offline
post #1237 of 2223 Old 05-12-2011, 12:41 PM
hlkc's Avatar
Hey hlkc,
Thanks!!
mickey79,
No problem. If I may I like to point out few differences to you. First, Ceton is doing everything natively, hints no HDMI in, component cable out and control the DVR using IR blaster. Second, we can record pay channel contents like CNN, HBO, SHW... into our HDDs. Third, we can share up to 3 tunners using Ceton with other extenders/HTPCs in our house, hints we don't need other tuners in the extender/HTPC to record and watch live TV anymore. Last, we don't need to pay $15 per DVR per month per location, I am saving $30 right there per month. To sum up, it is easily justify the $200 different between 2 products therefore I did not go to that route and end up using Ceton InfiniTV4 today.
hlkc is offline
post #1238 of 2223 Old 05-12-2011, 01:04 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
mickey79,
No problem. If I may I like to point out few differences to you. First, Ceton is doing everything natively, hints no HDMI in, component cable out and control the DVR using IR blaster. Second, we can record pay channel contents like CNN, HBO, SHW... into our HDDs. Third, we can share up to 3 tunners using Ceton to any other extenders/HTPCs in our house, hints we don't need other tuners in the extender/HTPC to record and watch live TV. Last, we don't need to pay $15 for DVR per month per location, I am saving $30 right there per month. To sum up, it is easily make up the $200 different between 2 products therefore I did not go to that route and end up using Ceton InfiniTV4 today!
Definitely some big advantages there, undoubtedly. I think for what I'm looking for - the Hauppage Colossus would suffice. There's only a few shows that I will probably need to record here & there; and only need it on one TV. It's just me & my wife and this is more of a startup DVR card - for the most part we don't have a very high-end need for a DVR.
Your setup definitely sounds awesome.
Can't wait to get my Z68/i3-2105 setup all ordered & ready to build.
mickey79 is offline
post #1239 of 2223 Old 05-12-2011, 01:11 PM
hlkc's Avatar
There was a rumor that they will have some models soon such as external box set up like Colossus, USB and few and more tuners PCI version soon. If you are not in any hurry, I would suggest you to hold on for the least expensive USB version.
hlkc is offline
post #1240 of 2223 Old 05-12-2011, 01:16 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
I can hold off a little on the DVR - I'll keep an eye on Ceton! Thanks!!
mickey79 is offline
post #1241 of 2223 Old 05-12-2011, 01:17 PM
assassin's Avatar
Quoted: 179 Post(s)
Liked: 283
Just curious why you are waiting for the 2105? I don't think it will really offer that much more for general HTPC usage.
assassin is offline
post #1242 of 2223 Old 05-12-2011, 01:32 PM
hlkc's Avatar
http://www.silicondust.com/ is another product you might want to keep an eye on it and it is compatible with Ceton IMO.
hlkc is offline
post #1243 of 2223 Old 05-12-2011, 01:36 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
HD3000. I've read too many articles/posts suggesting HD3000 is definitely a better chip for Blu-ray 3D playback then HD2000. You have to keep in mind - I own a Dune Smart D1 which is an excellent out-of-the-box media player; it can virtually play absolutely anything, brilliantly flawless, that I throw at it - EXCEPT - full Blu-ray 3D. This was unknown to me at the time I bought the device. Soon thereafter I learned that the first full Blu-ray 3D supporting media players wouldn't roll out till Q1 2012.
A major, I would say 90%, of the reason that I'm building my HTPC is because of full Blu-ray 3D playback. I can do most everything else on the Dune. So it does kinda make sense to go for the chip that has a somewhat better Blu-ray 3D playback support.
To be fair - it were another 3 months before it's release, I wouldn't have waited that long. But it doesn't make sense for me to drop the ball on it 20 days shy of it's release. I think it's worth the wait. (Actually it's only 10 days to it's release AFAIK)
mickey79 is offline
post #1244 of 2223 Old 05-12-2011, 01:36 PM
Zon2020's Avatar
I know why I'm waiting. No, I can't tell you exactly what benefit the improvement from HD2000 to HD3000 graphics will deliver today in actual practice in the context of my current contemplated needs, but it is unquestionably a stronger graphics processer and the extra $15 dollars or so is pretty insignificant in the overall cost of my planned HTPC, so it seems like a obvious choice to me to wait. I wouldn't wait 6 months, and I wouldn't pay $100 more, but 2 weeks and less than $20 seems like a no-brainer to me.
Zon2020 is offline
post #1245 of 2223 Old 05-12-2011, 01:40 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
That is exactly why!!! +2
mickey79 is offline
post #1246 of 2223 Old 05-12-2011, 03:24 PM
assassin's Avatar
Quoted: 179 Post(s)
Liked: 283
The reason I ask is because this has been discussed recently.
https://www.avsforum.com/avs-vb/showt...1#post20389981
assassin is offline
post #1247 of 2223 Old 05-12-2011, 03:27 PM
babgvant's Avatar
Liked: 30
Having tested both, I see no difference in the 3D (or media experience in general) b/w the HD3000 and HD2000.
babgvant is offline
post #1248 of 2223 Old 05-12-2011, 04:09 PM
Zon2020's Avatar
Ok, but if the 2100 and 2105 were both sitting on the store shelf in front of you and the price difference was $17, would you pick the 2100?
Is there a downside other than $17 of picking the 2105?
Zon2020 is offline
post #1249 of 2223 Old 05-12-2011, 04:12 PM
assassin's Avatar
Quoted: 179 Post(s)
Liked: 283
I guess it just depends what $17 is worth to you.
assassin is offline
post #1250 of 2223 Old 05-12-2011, 04:19 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
And that may very rightly be; I have personally not tested either - so whatever I know of is really just articles, posts - things read here & there.
But as Zon2020 pointed out - neither would I have waited 3 months for HD3000, nor spent even $50 extra on it. But for $10 & 2 weeks - it really doesn't make sense not to. I can't speak for everyone but at least in my case - I had to start my build in the month of May. Once I found out that i3-2105 was releasing on may 22nd ... it was a matter of a couple of weeks. And I was going to get i3-2100 which retails for $124. With i3-2105 expected to retail for $134 ... the $10 is really insignificant. I have no personal trumpets to blow about HD3000 for it really may not be any different then HD2000 - it was simply a matter of timing/cost for me.
It's kinda like the Z68 factor. I don't really need the Z68. Niether am I overclocking my CPU right now - nor using an SSD in my build. I can easily get the H67. But since there's no cost difference and it's out right now while I'm assembling components for my build - why not?
Now I do have a question ...
Is it Ok to use an i3-2105 CPU with a Z68 motherboard or do you have to use a "K" processor with Z68?? I got confused after reading a post in one of the threads here. I was planning to get a Z68 for my 2105 since there was no cost difference between the H67 & Z68.
mickey79 is offline
post #1251 of 2223 Old 05-12-2011, 04:49 PM
StardogChampion's Avatar
Quoted: 96 Post(s)
Liked: 161
I have the picoPSU 120-WI-32 with a 19V 6.3A AC adapter. I made that choice based on this review at JohnnyGURU.com: http://www.jonnyguru.com/modules.php...tory5&reid=207.
What kind of case are you going to be building this HTPC in?
StardogChampion is offline
post #1252 of 2223 Old 05-12-2011, 04:53 PM
hlkc's Avatar
May I "try" to put all this together
Q: Whether or not you need the i3 2105?
A1) If you have H67 and i3 2100 in your possession TODAY, we just simply don't see the need to upgrade if you don't overclock the HTPC.
A2) If you don't have H67 TODAY, you should just wait another 2 weeks for the 2105 and Z68 MB altogether since it will not much $ different and in case you are bored and nothing to do and want to overclock your HTPC in the future
A3) If you have nothing to do, some spare time to kill and just have to have the latest and greatest otherwise you can't sleep well at night, then sell your H67+2100 and get the Z68+2105
Are we in the same page now
hlkc is offline
post #1253 of 2223 Old 05-12-2011, 05:04 PM
Zon2020's Avatar
How about A4) Am never going to overclock or use a SSD cache on this pc, and thus have no need for a Z68, but if the the HD3000 and HD2000 are basically the same price, why not get the better one?
Zon2020 is offline
post #1254 of 2223 Old 05-12-2011, 05:36 PM
mickey79's Avatar
Quoted: 153 Post(s)
Liked: 37
YES we are!!!
mickey79 is offline
post #1255 of 2223 Old 05-12-2011, 05:47 PM
babgvant's Avatar
Liked: 30
If I was only going to use it for media consumption and transcoding, I'd pocket the $17. Gaming is the only reason to go HD3000 over the HD2000.
babgvant is offline
post #1256 of 2223 Old 05-12-2011, 07:38 PM
phy88's Avatar
Of course, I tried it all, but only disconnecting the ssd could I get into the bios again. Basically, enabling "general optimization" within the DH67CF bios makes the system boot so quickly (about 5-6 seconds from complete shutdown to windows desktop) that you can't even get into the bios.
phy88 is offline
post #1257 of 2223 Old 05-12-2011, 07:50 PM
assassin's Avatar
Quoted: 179 Post(s)
Liked: 283
That's what I am thinking too. Use the $17 towards more RAM, bigger/additional hard drive, etc.
assassin is offline
post #1258 of 2223 Old 05-12-2011, 08:48 PM
Zon2020's Avatar
If I accept that view, that tells me I should get an i3-2100T and have less heat, because to me it seems the only reason NOT to use the "T" would be the lack of HD3000 graphics.
Zon2020 is offline
post #1259 of 2223 Old 05-12-2011, 08:52 PM
assassin's Avatar
Quoted: 179 Post(s)
Liked: 283
I think the 2100T is one of the best CPUs out right now for HTPC. I use it in my new line of HTPCs even though it is $10 more than the 2100.
I have a few pics in my blog.
assassin is offline
post #1260 of 2223 Old 05-12-2011, 09:02 PM
Zon2020's Avatar
Guess I'll have to see what the actual street price difference is between the 2100, 2100T, and 2105 after May 22.
Microcenter actually has the 2100 for $99 right now.
Zon2020 is offline
Reply Home Theater Computers
